tsp (#20) - librouting_tsp.dll: missing magic block (#155) - Message List
Hi
I am trying to run the TSP function. I'm running the postgres 8.2 on windows. I've downloaded the 'pgRouting-1.02_pg-8.2.9.zip' windows binaries.
When creating the routing functions in postgres, the 'routing_core.sql', 'routing_core_wrappers.sql', 'routing_dd.sql', 'routing_dd_wrappers.sql' and 'routing_tsp_wrappers.sql' SQL scripts all run OK, and associated functions are created.
But when I run the 'routing_tsp.sql' script, I get the error,
ERROR: incompatible library "C:/Program Files/PostgreSQL/8.2/lib/librouting_tsp.dll": missing magic block SQL state: XX000 Hint: Extension libraries are required to use the PG_MODULE_MAGIC macro.
Any ideas how to fix? Is this a problem with the librouting_tsp.dll build (all other routing functions seem to work OK)?
Many thanks David
Message #536
Hi David,
Thanks for reporting this. Can you please file a bug?
anton07/09/08 08:01:33 (2 years ago)-
Message #542
That's not a bug.
I've forgot to add a line in the build.make from routing.
I've just fixed todays for PostgreSQL 8.3! I will do it for PG 8.2 a next time!
Sorry for this!
david.techer07/12/08 06:09:39 (2 years ago)
