package (#21) - librouting.so: missing magic block (#254) - Message List
Hejsan,
I'm trying to install pgrouting. It compiles fine but creating the functions in my DB results in the Error
psql:/usr/share/postlbs/routing_core.sql:32: ERROR: incompatible library "/usr/lib/postgresql/8.3/lib/librouting.so": missing magic block
HINT: Extension libraries are required to use the PG_MODULE_MAGIC macro.
The installed versions are as follows:
- debian 4.0
- postgresql-8.3 8.3.6-1-bp
- postgis 1.3.3-1-bp
- postgresql-8.3-postgis 1.3.3-1-bp
Here is what I did:
- svn checkout http://pgrouting.postlbs.org/svn/pgrouting/trunk pgroutingSvn2 //no errors here
- cd pgroutingSvn2 //no errors here
- cmake . //no errors here
Boost headers were found here: /usr/include Output directory for libraries is set to /usr/lib/postgresql/8.3/lib Installation directory for libraries is set to /usr/lib/postgresql/8.3/lib and for SQL files is set to /usr/share/postlbs -- Configuring done -- Generating done -- Build files have been written to: /var/www/web0/files/pgroutingSvn2
- make //no errors here
Scanning dependencies of target routing [ 16%] Building C object core/src/CMakeFiles/routing.dir/dijkstra.o [ 33%] Building C object core/src/CMakeFiles/routing.dir/astar.o [ 50%] Building C object core/src/CMakeFiles/routing.dir/shooting_star.o [ 66%] Building CXX object core/src/CMakeFiles/routing.dir/boost_wrapper.o [ 83%] Building CXX object core/src/CMakeFiles/routing.dir/astar_boost_wrapper.o [100%] Building CXX object core/src/CMakeFiles/routing.dir/shooting_star_boost_wrapper.o
- make install //no errors here
[100%] Built target routing Install the project... -- Install configuration: "" -- Install configuration: "" -- Install configuration: "" -- Install configuration: "" -- Installing /usr/lib/postgresql/8.3/lib/librouting.so -- Install configuration: "" -- Installing /usr/share/postlbs/routing_core.sql -- Installing /usr/share/postlbs/routing_core_wrappers.sql -- Installing /usr/share/postlbs/routing_topology.sql -- Installing /usr/share/postlbs/matching.sql
- /etc/init.d/postgresql-8.3 restart //no errors here
- psql -U web0 -f /usr/share/postlbs/routing_core.sql gis //returned errors
psql:/usr/share/postlbs/routing_core.sql:21: ERROR: relation "path_result" already exists psql:/usr/share/postlbs/routing_core.sql:22: ERROR: relation "vertex_result" already exists psql:/usr/share/postlbs/routing_core.sql:32: ERROR: incompatible library "/usr/lib/postgresql/8.3/lib/librouting.so": missing magic block HINT: Extension libraries are required to use the PG_MODULE_MAGIC macro. psql:/usr/share/postlbs/routing_core.sql:43: ERROR: incompatible library "/usr/lib/postgresql/8.3/lib/librouting.so": missing magic block HINT: Extension libraries are required to use the PG_MODULE_MAGIC macro. psql:/usr/share/postlbs/routing_core.sql:53: ERROR: incompatible library "/usr/lib/postgresql/8.3/lib/librouting.so": missing magic block HINT: Extension libraries are required to use the PG_MODULE_MAGIC macro. CREATE FUNCTION
I tried to google the error message, tried to modify the .c-files (inserting a #ifdef PG_MODULE_MAGIC // PG_MODULE_MAGIC; // #endif) but without any luck.
I would be very happy if someone could look into this problem and give me a hint.
Kind regards from Hamburg,
Christof
Message #907
Hi Christof,
Oh, so this is strange, because the magic block is in our source code since version 1.01. See it for yourself - http://pgrouting.postlbs.org/browser/trunk/core/src/dijkstra.c#L45
Where did you try to insert it to?
anton04/25/09 22:57:53 (19 months ago)-
Message #908
Hej Anton,
thanks for your reply.
I saw the magic block in dijkstra.c but as it haven't done the trick I tried to add it in shooting_star.c and astar.c as well. Apparently without any luck.
I just deleted /usr/lib/postgresql/8.3/lib/librouting.so checked that posgres does not see it any more and "maked install" it again. But routing_core.sql gave the same then above.
Do you have any idea what I possibly do wrong?
Christof04/25/09 23:39:28 (19 months ago)
