osm2pgrouting (#24) - importing doesn't work (#272) - Message List
I tried to import the map of Germany, and all I get are messages like these: We need a way of type highway and class footway We DON'T need a way of type and class We DON'T need a way of type and class We DON'T need a way of type and class We need a way of type highway and class residential We DON'T need a way of type and class We need a way of type highway and class path We need a way of type highway and class residential
No data get's inserted into the database :(
Ciao,
palmcron
Message #958
Well, these messages are the visual output of parsing mapconfig.xml
In that file you can define, which OSM attributes should be imported and you can set a class name.I think the most common issue when osm2pgrouting fails is when you run out of memory. If you use Linux you could increase your Swap partition as a workaround, but I must admit that this is not the way it should be.
Though we are still looking for a volunteer to fix this issue #140daniel05/19/09 08:08:29 (18 months ago) -
Message #963
I have the exact same problem. I have tried with a estonia.osm (200 mb) downloaded from cloudmade and with estonia.osm converted with osmosis.
vercingetorix05/20/09 22:38:52 (18 months ago)-
Message #965
Well, just to make sure it's caused by the size of your data, you could once try it with less data to see if it's generally working.
daniel05/21/09 07:24:41 (18 months ago)-
Message #996
I am having the same issue with the minnesota.osm and minnesota.osm.highway cloudmade downloads. I watched the memory usage with top while osm2pgrouting ran and it doesn't seem to be running out of memory during the import.
Carl08/01/09 05:22:55 (16 months ago)-
Message #1000
Could you provide me with a link to the data you're using?
daniel08/03/09 13:52:21 (16 months ago)-
Message #1002
I am using the cloudmade file from here: http://downloads.cloudmade.com/north_america/united_states/minnesota/minnesota.osm.bz2
Though it might have changed since I had this error. I downloaded an earlier one and was running into many parsing errors because of a poorly formatted osm file, then I ran into this problem when I downloaded a later copy. I could send you a copy of the file I am having the issue with if you would like.
Carl08/05/09 02:26:05 (16 months ago)-
Message #1003
OK, you can send the file to kastl at orkney.co.jp, because I don't think it's a good idea to attach large files to TRAC.
daniel08/05/09 08:50:41 (16 months ago)
