osm2pgrouting (#24) - Compiling error (#293) - Message List
Compiling error
Hi everyone. I'm trying to compile osm2pgrotuing and i'm receiving this error:
g++ -o osm2pgrouting src/osm2pgrouting.cpp *.o -I./ -Isrc -I/usr/include/pgsql -I/usr/include/postgresql -lexpat -ggdb3 -lpq /usr/bin/ld: can't find -lpq collect2: ld returned 1 exit status make: *** [all] Error 1
Could someone help me?. Thank you.
calvorota
09/03/09 17:50:42 (15 months ago)
Message #1045
Can you give us a bit more information for example about the OS you use?
daniel09/04/09 08:47:38 (15 months ago) -
Message #1047
Ok, i've finally compiled the sources. I'm using Debian.
1.- Modifying Makefile instruction
adding the directory where libpq is installed like this
g++ -o osm2pgrouting src/osm2pgrouting.cpp *.o -I./ -Isrc -I/usr/include/pgsql -I/usr/include/postgresql -lexpat -ggdb3 -L/usr/lib/postgresql8/lib -lpq
2.- It compiled correctly, but then when i executed osm2pgrouting i received this error:
/osm2pgrouting: error while loading shared libraries: libpq.so.5: cannot open shared object file: No such file or directory
What i did was adding the directory where libpq is installed to the file /etc/ld.so.conf, and after that executed ldconfig
Now application runs correctly. But i'm having another problem, i'm reciving
host=127.0.0.1 user=postgres dbname=demo port=5432 connection failed
where i really have database created. Please,could you help me?. Thank you.
calvorota09/04/09 17:48:05 (15 months ago)
