osm2pgrouting (#24) - other alternative tools for converting OSM Data into PostgreSQL (#306) - Message List
Hi, due to the fact, that osm2pgsql only imports attributes that are necessary for rendering the map, I created some new JAVA - Tools to convert OSM-Data into PostgreSQL - Scripts. You can find them right here: http://pgrouting.postlbs.org/wiki/ProgramsToConvert They also import attributes that are NOT necessary for rendering a map from those data (for example "surface"). One of the programs is for automatically resampling the geometries in a table from geographical reference system into the google projection.
Maybe someone enjoys those little tools or finds them usefull.
Best regards
René Westerholt
Message #1145
but it doesnt create topology ?
ole10/20/09 16:31:41 (13 months ago)-
Message #1150
Hi, no. I created them in the context of a software project at the university. We worked with OSM2PGROUTING for creating topology. But this new tools have the function to import ALL the attributes for each point or line. OSM2PGSQL only import attributes that are necessary for rendering. So, if you desire to create a database just for displaying some data maybe as WMS - Layer this tools (nodes2postgis, etc.) are very good because they give you the opportunity to display really all attributes of the osm - data. But they don't create topology for routing (because this wasn't the reason I created them for).
Best regards
René Westerholt
ReneWesterholt10/21/09 03:57:42 (13 months ago)
Message #1188
Thanks! It's very nice!
RikiKiki11/01/09 13:44:36 (13 months ago)-
Message #1195
how does it import the osm data ?
by first writing all nodes to db and then querying the nodes from db for making multilinestring ways ? this would be a bit slow
ole11/03/09 18:22:55 (13 months ago)-
Message #1200
it runs through an OSM - File with an JAVA - XML Parser and saves the nodes (or lines, depending on using lines2postgis or nodes2postgis) as java-objects. Then it creates .sql - scripts by evaluating those objects. One of the scripts creates the accordant table and the other one imports the data with "insert into" commands. If you use it for importing the data of a medium-size city (for example Osnabrueck) it works fine and only needs a few seconds (I think it took 8 seconds...). Once I tried to import the data of the federal state of the Saarland and it also worked. Admittedly, I didn't check it out for bigger datasets.
Best regards
René Westerholt
ReneWesterholt11/07/09 07:37:53 (13 months ago)-
Message #1439
doesn't work for me under WinXP
osnabrueck.osm from tutorial http://pgrouting.postlbs.org/wiki/workingwithosmdata
tools from http://pgrouting.postlbs.org/wiki/ProgramsToConvert
java -jar nodes2postgis.jar osnabrueck.osm successfully creates nodefuellen.sql and nodeerstellen.sql
java -jar lines2postgis.jar osnabrueck.osm gives Exception in thread "main" java.lang.NullPointerException?
at Main.TabelleFuellenWays?(Main.java:170) at Main.main(Main.java:64)
Any ideas?
Thanks and Regards, R.L.
LongRed03/18/10 01:10:36 (8 months ago)
