data (#23) - Data appears smaller (#317) - Message List
Hi Everyone
I am trying to overlay data (nrn_rrn_bc_shp_en.zip) onto Google Maps. I have downloaded data from Canadian website as recommended by a tutorial on this website. I have changed SRID to 54004 for Victoria table. But when I display Victoria table on Google Maps then it appears smaller than Google Maps (nearly half of the size of area on Google Map). When I try to use 900913 for Victoria table it does not appear at all.
I am using OpenLayers? and my map projection is in 900913.
The Victoria tables is published as a WMS, thus I am using 900913 project for it in the mapfile.
Here is my ESPG entry for Proj4 (for MapServer)
<900913> +proj=merc +a=6378137 +b=6378137 +lat_ts=0.0 +lon_0=0.0 +x_0=0.0 +y_0=0 +k=1.0 +units=m +nadgrids=@null +no_defs
Here is the insert statement for 900913 for PostGIS (it is taken from this website as well)
INSERT INTO spatial_ref_sys (srid, auth_name, auth_srid, srtext, proj4text) VALUES (900913, 'EPSG', 900913, 'PROJCS["unnamed",GEOGCS["unnamed ellipse",DATUM["unknown",SPHEROID["unnamed",6378137,0]], PRIMEM["Greenwich",0],UNIT["degree",0.0174532925199433]], PROJECTIONMercator_2SP?,PARAMETER["standard_parallel_1",0],PARAMETER["central_meridian",0],PARAMETER["false_easting",0], PARAMETER["false_northing",0],UNIT["Meter",1],EXTENSION["PROJ4","+proj=merc +a=6378137 +b=6378137 +lat_ts=0.0 +lon_0=0.0 +x_0=0.0 +y_0=0 +k=1.0 +units=m +nadgrids=@null +wktext +no_defs"]]',
'+proj=merc +a=6378137 +b=6378137 +lat_ts=0.0 +lon_0=0.0 +x_0=0.0 +y_0=0 +k=1.0 +units=m +nadgrids=@null +wktext +no_defs');
Could any one help me in understating what is wrong?
Message #1240
here is an image of the output i get.
http://img705.imageshack.us/i/projectionproblem.jpg/
Data looks very small Why?
gisosdeveloper12/07/09 23:46:10 (12 months ago)
