data (#23) - Utm Zones (#361) - Message List
Utm Zones
Hello Postgis & pg-Routing Friends,
at the moment i am working on a little scaled routing project where occoured some problems. Normally i was working with pg-routing in big scales (Cities) and had utm koordinates = metres but now i have degree koordinates in wgs84. probably i work on the whole ethiopia but there are 3 utm zones splitting this country so i can´t easily use utm koordinates? is there a way to transform the streetdata directly from degree into kilometres?
Thanks for your help...
cKaatz
ckaatz
05/17/10 07:47:08 (6 months ago)
