Public Member Functions | Protected Member Functions | List of all members
ossimDtedFactory Class Reference
CLASS: ossimDtedFactory. More...
#include <ossimDtedFactory.h>
Inheritance diagram for ossimDtedFactory:
ossimElevSourceFactory ossimObject ossimReferenced
 ossimDtedFactory ()
 ossimDtedFactory (const ossimFilename &dir)
virtual ossimElevSourcegetNewElevSource (const ossimGpt &gpt) const
 Pure virtual method. More...
virtual void createIndex ()
- Public Member Functions inherited from ossimElevSourceFactory
 ossimElevSourceFactory ()
 default constructor More...
virtual ~ossimElevSourceFactory ()
 virtual destructor More...
virtual ossimFilename getDirectory () const
virtual void setDirectory (const ossimFilename &directory)
 ossimObject ()
virtual ~ossimObject ()
 Generic print method. More...
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
virtual ~ossimDtedFactory ()
virtual ~ossimReferenced ()
Additional Inherited Members
- Protected Attributes inherited from ossimElevSourceFactory
ossimFilename theDirectory
Detailed Description
Definition at line 22 of file ossimDtedFactory.h.
◆ ossimDtedFactory() [1/2]
ossimDtedFactory::ossimDtedFactory ( )
Definition at line 32 of file ossimDtedFactory.cpp.
34 {}
ossimElevSourceFactory()
default constructor
◆ ossimDtedFactory() [2/2]
ossimDtedFactory::ossimDtedFactory ( const ossimFilename dir)
Definition at line 36 of file ossimDtedFactory.cpp.
References ossimElevSourceFactory::theDirectory.
38 {
39  theDirectory = dir;
40 }
default constructor
◆ ~ossimDtedFactory()
ossimDtedFactory::~ossimDtedFactory ( )
protectedvirtual
Definition at line 42 of file ossimDtedFactory.cpp.
43 {}
Member Function Documentation
◆ createIndex()
void ossimDtedFactory::createIndex ( )
virtual
Definition at line 185 of file ossimDtedFactory.cpp.
186 {
187 }
◆ getNewElevSource()
ossimElevSource * ossimDtedFactory::getNewElevSource ( const ossimGpt gpt) const
virtual
return an elevation source pointer that has elevation coverage for the ground point passed in. Note the caller of this method is responsible for managing the memory allocated.
Implements ossimElevSourceFactory.
Definition at line 45 of file ossimDtedFactory.cpp.
46 {
47  if (traceDebug())
48  {
50  << "DEBUG ossimDtedFactory::getNewElevSource: Entered..."
51  << std::endl;
52  }
53
55
57  {
59  << "FATAL ossimDtedFactory::getNewElevSource: "
60  << "DTED directory has not been set!"
61  << "\nReturning null elevation source..."
62  << std::endl;
63  return dted_ptr.release();
64  }
65
66  // Build up a dted file name.
67  ossimFilename dted_file_base;
68
69  int ilon = static_cast<int>(floor(gpt.lond()));
70
71  if (ilon < 0)
72  {
73  dted_file_base = "w";
74  }
75  else
76  {
77  dted_file_base = "e";
78  }
79
80  ilon = abs(ilon);
82  s1 << std::setfill('0') << std::setw(3)<< ilon;
83
84  dted_file_base += s1.str().c_str();//ossimString::toString(ilon);
85  dted_file_base += "/";
86
87  int ilat = static_cast<int>(floor(gpt.latd()));
88  if (ilat < 0)
89  {
90  dted_file_base += "s";
91  }
92  else
93  {
94  dted_file_base += "n";
95  }
96
97  ilat = abs(ilat);
99
100  s2<< std::setfill('0') << std::setw(2)<< ilat;
101
102  dted_file_base += s2.str().c_str();
103
104  // Look for a dted file with a level 2 extension first.
105  ossimFilename dted_name = theDirectory.dirCat(dted_file_base);
106  dted_name += ".dt2";
107
108  if (traceDebug())
109  {
111  << "DEBUG ossimDtedFactory::getNewElevSource:"
112  << "\nSearching for file: " << dted_name
113  << std::endl;
114  }
115
116  if (dted_name.exists())
117  {
118  dted_ptr = new ossimDtedHandler(dted_name);
119  if ( (!(dted_ptr->getErrorStatus())) &&
120  dted_ptr->pointHasCoverage(gpt) )
121  {
122  return dted_ptr.release();
123  }
124  else
125  {
126  dted_ptr = 0;
127  }
128  }
129
130  // Look for a dted file with a level 1 extension next.
131  dted_name = theDirectory.dirCat(dted_file_base);
132  dted_name += ".dt1";
133
134  if (traceDebug())
135  {
137  << "DEBUG ossimDtedFactory::getNewElevSource:"
138  << "\nSearching for file: " << dted_name
139  << std::endl;
140  }
141
142  if (dted_name.exists() )
143  {
144  dted_ptr = new ossimDtedHandler(dted_name);
145  if ( (!(dted_ptr->getErrorStatus())) &&
146  dted_ptr->pointHasCoverage(gpt) )
147  {
148  return dted_ptr.release();
149  }
150  else
151  {
152  dted_ptr = 0;
153  }
154  }
155
156  // Look for a dted file with a level 0 extension next.
157  dted_name = theDirectory.dirCat(dted_file_base);
158  dted_name += ".dt0";
159
160  if (traceDebug())
161  {
163  << "DEBUG ossimDtedFactory::getNewElevSource:"
164  << "\nSearching for file: " << dted_name
165  << std::endl;
166  }
167
168  if (dted_name.exists() )
169  {
170  dted_ptr = new ossimDtedHandler(dted_name);
171  if ( (!(dted_ptr->getErrorStatus())) &&
172  dted_ptr->pointHasCoverage(gpt) )
173  {
174  return dted_ptr.release();
175  }
176  else
177  {
178  dted_ptr = 0;
179  }
180  }
181
182  return dted_ptr.release();
183 }
std::basic_ostringstream< char > ostringstream
Class for char output memory streams.
Definition: ossimIosFwd.h:35
static const ossimFilename NIL
This was taken from Wx widgets for performing touch and access date stamps.
Definition: ossimFilename.h:40
double lond() const
Will convert the radian measure to degrees.
Definition: ossimGpt.h:97
#define abs(a)
Definition: auxiliary.h:74
double latd() const
Definition: ossimGpt.h:87
bool exists() const
T * release()
Definition: ossimRefPtr.h:93
virtual bool pointHasCoverage(const ossimGpt &) const =0
METHOD: pointHasCoverage(gpt) Returns TRUE if coverage exists over gpt:
the DTED handler is an elevation source that allows for handling of a single cell of data...
virtual ossimErrorCode getErrorStatus() const
ossimFilename dirCat(const ossimFilename &file) const
const char * c_str() const
Definition: ossimString.h:396
