ossimERSFileWriter Class Reference
Class for writing a "ERS" style header. More...
#include <ossimERSFileWriter.h>
Inheritance diagram for ossimERSFileWriter:
ossimMetadataFileWriter ossimConnectableObject ossimProcessInterface ossimConnectableObjectListener ossimObject ossimListenerManager ossimPropertyInterface ossimListener ossimReferenced
Public Member Functions
 ossimERSFileWriter ()
 default constructor More...
 Initializes the state of the writer. More...
virtual void getMetadatatypeList (std::vector< ossimString > &metadatatypeList) const
 Satisfies pure virtual from ossimMetadataWriter base. More...
virtual bool hasMetadataType (const ossimString &metadataType) const
- Public Member Functions inherited from ossimMetadataFileWriter
 ossimMetadataFileWriter ()
virtual void initialize ()
virtual bool execute ()
virtual void setFilename (const ossimFilename &file)
const ossimFilenamegetFilename () const
virtual void setPixelType (ossimPixelType pixelType)
 Ossim uses a concept of "pixel is point" internally. More...
virtual ossimPixelType getPixelType () const
virtual void setAreaOfInterest (const ossimIrect &areaOfInterest)
 Sets the area of interest to write the meta data for. More...
virtual ossimIrect getAreaOfInterest () const
const ossimIdgetId () const
 ossimObject ()
virtual ~ossimObject ()
 Generic print method. More...
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
 ossimListenerManager ()
 ossimPropertyInterface ()
- Public Member Functions inherited from ossimProcessInterface
 ossimProcessInterface ()
virtual void abort ()
bool needsAborting () const
bool isAborted () const
bool isExecuting () const
void enableEvents ()
void disableEvents ()
 ProcessEvent. More...
virtual void refreshEvent (ossimRefreshEvent &)
 ossimListener ()
virtual ~ossimListener ()
void enableListener ()
void disableListener ()
Protected Member Functions
virtual ~ossimERSFileWriter ()
 virtual destructor More...
virtual bool writeFile ()
 Write out the file. More...
- Protected Member Functions inherited from ossimMetadataFileWriter
virtual ~ossimMetadataFileWriter ()
virtual ~ossimReferenced ()
Protected Attributes
ossimERS theHdr
- Protected Attributes inherited from ossimMetadataFileWriter
ossimFilename theFilename
ossimPixelType thePixelType
ossimIrect theAreaOfInterest
ossimId theId
ossimString theDescription
ossimObjecttheOwner
bool theInputListIsFixedFlag
bool theOutputListIsFixedFlag
bool theEnabledFlag
bool theFireEventFlag
- Protected Attributes inherited from ossimProcessInterface
double thePercentComplete
ossimString theMessage
bool theEventFlag
bool theListenerEnableFlag
Additional Inherited Members
- Public Types inherited from ossimProcessInterface
enum  ossimProcessStatus {
Detailed Description
Definition at line 26 of file ossimERSFileWriter.h.
◆ ossimERSFileWriter()
ossimERSFileWriter::ossimERSFileWriter ( )
default constructor
◆ ~ossimERSFileWriter()
ossimERSFileWriter::~ossimERSFileWriter ( )
protectedvirtual
virtual destructor
Definition at line 37 of file ossimERSFileWriter.cpp.
38 {
39 }
Member Function Documentation
◆ getMetadatatypeList()
void ossimERSFileWriter::getMetadatatypeList ( std::vector< ossimString > &  metadatatypeList) const
virtual
Appends the writers image types to the "metadatatypeList".
Parameters
metadatatypeListstl::vector<ossimString> list to append to.
Note
Appends to the list, does not clear it first.
Implements ossimMetadataFileWriter.
Definition at line 214 of file ossimERSFileWriter.cpp.
216 {
217  metadatatypeList.push_back(ossimString("ers_header"));
218 }
◆ hasMetadataType()
bool ossimERSFileWriter::hasMetadataType ( const ossimString metadataType) const
virtual
Parameters
imageTypestring representing image type.
Returns
true if "metadataType" is supported by writer.
Definition at line 220 of file ossimERSFileWriter.cpp.
222 {
223  return (metadataType == "ers_header");
224 }
◆ loadState()
bool ossimERSFileWriter::loadState ( const ossimKeywordlist kwl,
const char *  prefix = 0
virtual
Users should use this to set the ERS header fields that are not taken from theInputConnection prior to calling execute.
Returns
true on success, false on failure.
Reimplemented from ossimMetadataFileWriter.
Definition at line 41 of file ossimERSFileWriter.cpp.
References ossimMetadataFileWriter::loadState().
43 {
44  // To pick up output filename.
45  return ossimMetadataFileWriter::loadState(kwl, prefix);
46 }
Load state method:
◆ writeFile()
bool ossimERSFileWriter::writeFile ( )
protectedvirtual
Write out the file.
Returns
Definition at line 48 of file ossimERSFileWriter.cpp.
References ossimString::after(), ossimString::before(), ossim::byteOrder(), ossimKeywordNames::DATUM_KW, ossimKeywordlist::find(), ossimMapProjectionInfo::getGeom(), ossimImageSource::getImageGeometry(), ossimImageSource::getNumberOfOutputBands(), ossimImageSource::getOutputScalarType(), ossimImageGeometry::getProjection(), ossimIrect::height(), ossimKeywordNames::HEMISPHERE_KW, OSSIM_BIG_ENDIAN, OSSIM_DEGREES, OSSIM_METERS, OSSIM_PIXEL_IS_POINT, ossimNotify(), ossimNotifyLevel_WARN, ossimKeywordNames::PIXEL_SCALE_XY_KW, PTR_CAST, ossimMetadataFileWriter::theAreaOfInterest, ossimERS::theBands, ossimERS::theByteorder, ossimERS::theCellSizeX, ossimERS::theCellSizeY, ossimERS::theCelltype, ossimERS::theCoordSysType, ossimERS::theDatasetType, ossimERS::theDatatype, ossimERS::theDatum, ossimMetadataFileWriter::theFilename, theHdr, ossimMetadataFileWriter::theInputConnection, ossimERS::theLine, ossimERS::theOriginX, ossimERS::theOriginY, ossimMetadataFileWriter::thePixelType, ossimERS::theProjection, ossimERS::theSample, ossimERS::theTieUnitType, ossimKeywordNames::TIE_POINT_XY_KW, ossimString::toDouble(), ossimString::trim(), ossimKeywordNames::TYPE_KW, ossimRefPtr< T >::valid(), ossimIrect::width(), ossimERS::writeFile(), and ossimKeywordNames::ZONE_KW.
49 {
50  ossimString tmp;
51
52  theHdr.theDatasetType = "ERStorage";
53  theHdr.theDatatype = "Raster";
57
58  ossimByteOrder byteorder = ossim::byteOrder();
59  if (byteorder == OSSIM_BIG_ENDIAN)
60  {
61  theHdr.theByteorder = "MSBFirst";
62  }
63  else
64  {
65  theHdr.theByteorder = "LSBFirst";
66  }
67
69
70  // Get the geometry from the input.
71  ossimMapProjection* mapProj = 0;
73  if ( inputGeom.valid() ) mapProj = PTR_CAST(ossimMapProjection, inputGeom->getProjection());
74  if (mapProj)
75  {
76  // Create the projection info.
79
80  // Set the tie points in the keyword list.
81  ossimKeywordlist kwl;
82  projectionInfo->getGeom(kwl);
83
84  // Get the projection type.
85  const char* lookup;
86  ossimString projection;
87  lookup = kwl.find(ossimKeywordNames::TYPE_KW);
88  if (lookup)
89  {
90  projection = lookup;
91  }
92  else
93  {
95  << "ossimERSFileWriter::writeFile WARNING:"
96  << "\nNo projection type found!\nReturning..."
97  << std::endl;
98  return false; // Have to have the projection type!
99  }
100
101  if (projection == "ossimUtmProjection")
102  {
103  ossimString utm;
105  if (lookup)
106  {
107  utm = lookup;
108  utm += "UTM";
109  }
110  else
111  return false;
112
113  lookup = kwl.find(ossimKeywordNames::ZONE_KW);
114  if (lookup)
115  utm += lookup;
116  else
117  return false;
118
119  theHdr.theProjection = utm;
120  theHdr.theCoordSysType = "EN";
121
122
123  //we get tie points
125  tmp = lookup;
126  if (lookup)
127  {
128  tmp = tmp.trim("(");
129  tmp = tmp.trim(")");
130  ossimString a = tmp.before(",", 0);
131  ossimString b = tmp.after(",", 0);
132  theHdr.theOriginX = a.toDouble();
133  theHdr.theOriginY = b.toDouble();
134  }
135  //set the tie point unit type to meters
137
138  }
139  else if (projection == "ossimEquDistCylProjection")
140  {
141  theHdr.theProjection = "GEODETIC";
142  theHdr.theCoordSysType = "LL";
143
144  //we get tie points
146  tmp = lookup;
147  if (lookup)
148  {
149  tmp = tmp.trim("(");
150  tmp = tmp.trim(")");
151  ossimString a = tmp.before(",", 0);
152  ossimString b = tmp.after(",", 0);
153  theHdr.theOriginX = a.toDouble();
154  theHdr.theOriginY = b.toDouble();
155  }
156  //set the tie point unit type to degrees
158
159  }
160  else
161  {
163  << "ossimERSFileWriter::writeFile WARNING:"
164  << "\nOnly LatLon and UTM supported!\nReturning..."
165  << std::endl;
166  return false;
167  }
168
169  // Get the datum.
170  ossimString datum = "WGS-84";
171  lookup = kwl.find(ossimKeywordNames::DATUM_KW);
172  if (lookup)
173  {
174  ossimString os = lookup;
175  if (os == "WGE")
176  {
177  theHdr.theDatum = "WGS84";
178  }
179  else
180  {
182  << "ossimERSFileWriter::writeFile WARNING:"
183  << "\nOnly WGS84 supported!\nReturning..."
184  << std::endl;
185  return false; // Datum has to be WGS84 for now...
186  }
187  }
188
189  //get cell size
191  tmp = lookup;
192  if (lookup)
193  {
194  tmp = tmp.trim("(");
195  tmp = tmp.trim(")");
196  ossimString a = tmp.before(",", 0);
197  ossimString b = tmp.after(",", 0);
198
201  }
202
203  //get pixel is area or point
205  {
208  }
209  }
210
211  return theHdr.writeFile(theFilename);
212 }
double theOriginX
Definition: ossimERS.h:66
ossimString before(const ossimString &str, std::string::size_type pos=0) const
METHOD: before(str, pos) Returns string beginning at pos and ending one before the token str If strin...
static const char * DATUM_KW
ossimUnitType theTieUnitType
Definition: ossimERS.h:56
ossimString theCoordSysType
Definition: ossimERS.h:52
bool valid() const
Definition: ossimRefPtr.h:75
ossim_uint32 height() const
Definition: ossimIrect.h:487
ossimString theDatum
Definition: ossimERS.h:50
ossimString theByteorder
Definition: ossimERS.h:46
OSSIM_DLL ossimByteOrder byteOrder()
Definition: ossimCommon.cpp:54
static const char * TYPE_KW
ossimScalarType theCelltype
Definition: ossimERS.h:58
double theCellSizeX
Definition: ossimERS.h:62
static const char * PIXEL_SCALE_XY_KW
static const char * ZONE_KW
ossim_int32 theBands
Definition: ossimERS.h:68
static const char * TIE_POINT_XY_KW
ossimString trim(const ossimString &valueToTrim=ossimString(" \\)) const
this will strip lead and trailing character passed in.
double toDouble() const
#define PTR_CAST(T, p)
Definition: ossimRtti.h:321
ossimByteOrder
double theCellSizeY
Definition: ossimERS.h:63
ossim_uint32 width() const
Definition: ossimIrect.h:500
virtual ossimRefPtr< ossimImageGeometry > getImageGeometry()
Returns the image geometry object associated with this tile source or NULL if not defined...
void getGeom(ossimKeywordlist &kwl, const char *prefix=0) const
Adds tie point to keyword list.
double theOriginY
Definition: ossimERS.h:67
static const char * HEMISPHERE_KW
ossimString theDatatype
Definition: ossimERS.h:45
ossim_int32 theSample
Definition: ossimERS.h:65
bool writeFile(const ossimFilename &file)
Definition: ossimERS.cpp:411
ossimString theProjection
Definition: ossimERS.h:51
ossim_int32 theLine
Definition: ossimERS.h:64
ossimString after(const ossimString &str, std::string::size_type pos=0) const
METHOD: after(str, pos) Returns string immediately after the token str.
ossimString theDatasetType
Definition: ossimERS.h:44
Member Data Documentation
◆ theHdr
ossimERS ossimERSFileWriter::theHdr
protected
Definition at line 70 of file ossimERSFileWriter.h.
Referenced by writeFile().
