Public Member Functions | Protected Member Functions | Private Member Functions | Private Attributes | List of all members
ossimERSTileSource Class Reference
#include <ossimERSTileSource.h>
Inheritance diagram for ossimERSTileSource:
ossimGeneralRasterTileSource ossimImageHandler ossimImageSource ossimSource ossimConnectableObject ossimErrorStatusInterface ossimObject ossimListenerManager ossimPropertyInterface ossimReferenced
 ossimERSTileSource ()
 ossimERSTileSource (const ossimKeywordlist &kwl, const char *prefix=0)
virtual ossimString className () const
virtual bool open (const ossimFilename &filename)
- Public Member Functions inherited from ossimGeneralRasterTileSource
 ossimGeneralRasterTileSource ()
virtual ossimRefPtr< ossimImageDatagetTile (const ossimIrect &tile_rect, ossim_uint32 resLevel=0)
 Returns a pointer to a tile given an origin representing the upper left corner of the tile to grab from the image. More...
 Method to get a tile. More...
 Returns the number of bands in the image. More...
virtual ossim_uint32 getNumberOfLines (ossim_uint32 reduced_res_level=0) const
 Returns the number of lines in the image. More...
virtual ossim_uint32 getNumberOfSamples (ossim_uint32 reduced_res_level=0) const
 Returns the number of samples in the image. More...
 Returns the output pixel type of the tile source. More...
 Returns the width of the output tile. More...
 Returns the height of the output tile. More...
bool isValidRLevel (ossim_uint32 reduced_res_level) const
virtual void close ()
 Deletes the overview and clears the valid image vertices. More...
virtual bool isOpen () const
virtual bool open ()
 Pure virtual open. More...
virtual bool open (const ossimGeneralRasterInfo &info)
 Override base getXXXXPixValue methods since the null/min/max can be set to something different. More...
 Initializes bandList to the zero based order of output bands. More...
 ossimImageHandler ()
virtual ~ossimImageHandler ()
virtual void initialize ()
virtual bool openOverview ()
virtual void closeOverview ()
 Opens the image file. More...
 Sets the filename. More...
 Returns the filename. More...
 Connection rule. More...
virtual bool hasLut () const
virtual void loadMetaData ()
bool useEntryIndex () const
 Fetches the image ID. More...
template<class T >
template<class T >
virtual ~ossimImageSource ()
 For RTTI support. More...
virtual ~ossimSource ()
virtual void enableSource ()
virtual void disableSource ()
const ossimIdgetId () const
 ossimObject ()
virtual ~ossimObject ()
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
 ossimListenerManager ()
 ossimPropertyInterface ()
 ossimErrorStatusInterface ()
bool hasError () const
virtual ~ossimERSTileSource ()
- Protected Member Functions inherited from ossimGeneralRasterTileSource
virtual ~ossimGeneralRasterTileSource ()
virtual bool fillBuffer (const ossimIpt &origin, const ossimIpt &size)
 Methods return true on succes false on error. More...
virtual bool fillBIP (const ossimIpt &origin, const ossimIpt &size)
virtual bool fillBIL (const ossimIpt &origin, const ossimIpt &size)
virtual bool fillBSQ (const ossimIpt &origin, const ossimIpt &size)
virtual bool fillBsqMultiFile (const ossimIpt &origin, const ossimIpt &size)
virtual ossimKeywordlist getHdrInfo (ossimFilename hdrFile)
virtual ossimKeywordlist getXmlInfo (ossimFilename xmlFile)
bool initializeHandler ()
virtual void completeOpen ()
virtual ~ossimReferenced ()
void openHeader (const ossimFilename &file)
Private Attributes
ossimERStheHdr
Additional Inherited Members
- Protected Attributes inherited from ossimGeneralRasterTileSource
ossim_uint8m_buffer
ossim_uint8m_lineBuffer
ossimInterleaveType m_bufferInterleave
std::vector< std::shared_ptr< ossim::istream > > m_fileStrList
ossimGeneralRasterInfo m_rasterInfo
ossimIrect m_bufferRect
bool m_swapBytesFlag
ossim_uint32 m_bufferSizeInPixels
std::vector< ossim_uint32m_outputBandList
ossimFilename theImageFile
ossimFilename theOverviewFile
ossimString theImageID
bool theOpenOverviewFlag
ossimPixelType thePixelType
bool theEnableFlag
bool theInitializedFlag
ossimId theId
ossimString theDescription
ossimObjecttheOwner
bool theInputListIsFixedFlag
bool theOutputListIsFixedFlag
bool theEnabledFlag
bool theFireEventFlag
ossimErrorCode theErrorStatus
Detailed Description
Definition at line 24 of file ossimERSTileSource.h.
◆ ossimERSTileSource() [1/2]
ossimERSTileSource::ossimERSTileSource ( )
Definition at line 33 of file ossimERSTileSource.cpp.
35  theHdr(NULL)
36 {
37 }
◆ ossimERSTileSource() [2/2]
ossimERSTileSource::ossimERSTileSource ( const ossimKeywordlist kwl,
const char *  prefix = 0
Definition at line 42 of file ossimERSTileSource.cpp.
References loadState(), ossimErrorCodes::OSSIM_ERROR, and ossimErrorStatusInterface::theErrorStatus.
45  theHdr(NULL)
46 {
47  if (loadState(kwl, prefix) == false)
48  {
50  }
51 }
static const ossimErrorCode OSSIM_ERROR
virtual bool loadState(const ossimKeywordlist &kwl, const char *prefix=NULL)
◆ ~ossimERSTileSource()
ossimERSTileSource::~ossimERSTileSource ( )
protectedvirtual
Definition at line 56 of file ossimERSTileSource.cpp.
References theHdr.
57 {
58  if (theHdr)
59  {
60  delete theHdr;
61  theHdr = NULL;
62  }
63 }
Member Function Documentation
◆ className()
ossimString ossimERSTileSource::className ( ) const
virtual
Definition at line 215 of file ossimERSTileSource.cpp.
216 {
217  return ossimString("ossimERSTileSource");
218 }
◆ getImageGeometry()
ossimRefPtr< ossimImageGeometry > ossimERSTileSource::getImageGeometry ( )
virtual
Returns the image geometry object associated with this tile source or NULL if not defined.
The geometry contains full-to-local image transform as well as projection (image-to-world)
Reimplemented from ossimGeneralRasterTileSource.
Definition at line 144 of file ossimERSTileSource.cpp.
References ossimImageGeometryRegistry::extendGeometry(), ossimRefPtr< T >::get(), ossimImageHandler::getExternalImageGeometry(), ossimImageGeometry::getProjection(), ossimImageHandler::initImageParameters(), ossimImageGeometryRegistry::instance(), ossimImageGeometry::loadState(), ossimImageHandler::theGeometry, theHdr, and ossimERS::toOssimProjectionGeom().
145 {
146  if ( !theGeometry )
147  {
148  // Check for external geom:
150
151  if ( !theGeometry )
152  {
153
155
156  if(theHdr)
157  {
158  ossimKeywordlist kwl;
159  if ( theHdr->toOssimProjectionGeom(kwl) )
160  {
161  theGeometry->loadState(kwl);
162  }
163  }
164
165  // At this point it is assured theGeometry is set.
166
167  //---
168  // WARNING:
169  // Must create/set the geometry at this point or the next call to
170  // ossimImageGeometryRegistry::extendGeometry will put us in an infinite loop
171  // as it does a recursive call back to ossimImageHandler::getImageGeometry().
172  //---
173
174  // Check for set projection.
175  if ( !theGeometry->getProjection() )
176  {
177  // Try factories for projection.
179  }
180  }
181
182  // Set image things the geometry object should know about.
184  }
185  return theGeometry;
186 }
static ossimImageGeometryRegistry * instance()
ossimRefPtr< ossimImageGeometry > theGeometry
Attempts to initialize a transform and a projection given the KWL.
bool toOssimProjectionGeom(ossimKeywordlist &kwl, const char *prefix=NULL) const
Definition: ossimERS.cpp:531
virtual bool extendGeometry(ossimImageHandler *handler) const
void initImageParameters(ossimImageGeometry *geom) const
Convenience method to set things needed in the image geometry from the image handler.
virtual ossimRefPtr< ossimImageGeometry > getExternalImageGeometry() const
Returns the image geometry object associated with this tile source or NULL if non defined...
◆ getLongName()
ossimString ossimERSTileSource::getLongName ( ) const
virtual
Definition at line 210 of file ossimERSTileSource.cpp.
211 {
212  return ossimString("ER Mapper Raster");
213 }
◆ getShortName()
ossimString ossimERSTileSource::getShortName ( ) const
virtual
Definition at line 205 of file ossimERSTileSource.cpp.
206 {
207  return ossimString("ERS");
208 }
◆ loadState()
bool ossimERSTileSource::loadState ( const ossimKeywordlist kwl,
const char *  prefix = NULL
virtual
Definition at line 188 of file ossimERSTileSource.cpp.
References ossimKeywordNames::FILENAME_KW, ossimKeywordlist::find(), ossimGeneralRasterTileSource::loadState(), ossimImageSource::loadState(), and ossimGeneralRasterTileSource::open().
Referenced by ossimERSTileSource().
190 {
191  const char* lookup = kwl.find(prefix, ossimKeywordNames::FILENAME_KW);
192
193  if (lookup)
194  {
195  ossimFilename fileName = lookup;
196
197  bool result = open(fileName);
198  ossimImageSource::loadState(kwl, prefix);
199  return result;
200  }
201
202  return ossimGeneralRasterTileSource::loadState(kwl, prefix);
203 }
virtual bool open()
Pure virtual open.
static const char * FILENAME_KW
◆ open()
bool ossimERSTileSource::open ( const ossimFilename filename)
virtual
Definition at line 65 of file ossimERSTileSource.cpp.
References ossimKeywordlist::addFile(), ossimString::c_str(), ossimString::empty(), ossimERS::errorStatus(), ossimFilename::exists(), ossimFilename::fileNoExtension(), ossimGeneralRasterInfo::getImageMetaData(), ossimImageMetaData::getMaxPix(), ossimImageMetaData::getMaxValuesValidFlag(), ossimImageMetaData::getMinPix(), ossimImageMetaData::getMinValuesValidFlag(), ossimImageMetaData::getNullPix(), ossimImageMetaData::getNullValuesValidFlag(), ossimImageMetaData::loadState(), ossimGeneralRasterInfo::NONE, ossimGeneralRasterTileSource::open(), OSSIM_BIL, ossimErrorCodes::OSSIM_ERROR, ossimNotify(), ossimNotifyLevel_INFO, ossimFilename::path(), ossimGeneralRasterInfo::print(), ossimString::push_back(), ossimImageMetaData::setMaxPix(), ossimImageMetaData::setMinPix(), ossimImageMetaData::setNullPix(), ossimERS::theBands, ossimERS::theCelltype, ossimERS::theHasNullCells, theHdr, ossimERS::theLine, ossimImageHandler::theMetaData, ossimERS::theNullCell, and ossimERS::theSample.
66 {
67  // Open and parse the header file
68  theHdr = new ossimERS(fileName);
69
70 // theHdr->dump(cout);
71
73  {
74  delete theHdr;
75  theHdr = NULL;
76  return false;
77  }
78  else
79  {
80  vector<ossimFilename> f;
81  ossimFilename fne;
82  ossimFilename fpath = fileName.path();
83  if (fpath.empty())
84  fne = fileName.fileNoExtension();
85  else
86  fne = fpath+"/"+fileName.fileNoExtension();
87  f.push_back(fne);
88  ossimGeneralRasterInfo genRasterInfo(f,
90  OSSIM_BIL,
92  theHdr->theLine,
94  0,
96  0);
98  {
99  ossim_uint32 i = 0;
100  ossim_uint32 bands = static_cast<ossim_uint32>(theHdr->theBands);
101  for(i = 0; i < bands; ++i)
102  {
103  genRasterInfo.getImageMetaData().setNullPix(i, theHdr->theNullCell);
104  }
105  }
106  ossimFilename metadataFile = fne;
107  metadataFile = metadataFile + ".omd";
108
109  if(metadataFile.exists())
110  {
111  ossimKeywordlist kwl;
112
113  kwl.addFile(metadataFile.c_str());
114
115  theMetaData.loadState(kwl);
116  ossim_uint32 i = 0;
117  ossim_uint32 bands = static_cast<ossim_uint32>(theHdr->theBands);
118  for(i = 0; i < bands; ++i)
119  {
121  {
122  genRasterInfo.getImageMetaData().setMinPix(i, theMetaData.getMinPix(i));
123  }
125  {
126  genRasterInfo.getImageMetaData().setMaxPix(i, theMetaData.getMaxPix(i));
127  }
129  {
130  genRasterInfo.getImageMetaData().setNullPix(i, theMetaData.getNullPix(i));
131  }
132  }
133  }
135  << "general raster info is\n";
136  genRasterInfo.print(ossimNotify(ossimNotifyLevel_INFO));
137  ossimGeneralRasterTileSource::open(genRasterInfo);
138  }
139
140  return true;
141 }
bool loadState(const ossimKeywordlist &kwl, const char *prefix=0)
virtual bool open()
Pure virtual open.
double getMinPix(ossim_uint32 band) const
bool getMinValuesValidFlag() const
bool addFile(const char *file)
double getMaxPix(ossim_uint32 band) const
bool getNullValuesValidFlag() const
double getNullPix(ossim_uint32 band) const
ossimScalarType theCelltype
Definition: ossimERS.h:58
void push_back(char c)
Equivalent to insert(end(), c).
Definition: ossimString.h:905
bool theHasNullCells
Definition: ossimERS.h:60
double theNullCell
Definition: ossimERS.h:61
ossim_int32 theBands
Definition: ossimERS.h:68
bool exists() const
unsigned int ossim_uint32
ossimImageMetaData theMetaData
ossim_int32 errorStatus() const
Definition: ossimERS.h:79
bool getMaxValuesValidFlag() const
ossimFilename fileNoExtension() const
const char * c_str() const
Definition: ossimString.h:396
bool empty() const
Definition: ossimString.h:411
ossim_int32 theSample
Definition: ossimERS.h:65
ossim_int32 theLine
Definition: ossimERS.h:64
ossimFilename path() const
◆ openHeader()
void ossimERSTileSource::openHeader ( const ossimFilename file)
private
Member Data Documentation
◆ theHdr
ossimERS* ossimERSTileSource::theHdr
private
Definition at line 51 of file ossimERSTileSource.h.
Referenced by getImageGeometry(), open(), and ~ossimERSTileSource().
