#include <ossimGeoAnnotationMultiEllipseObject.h>
ossimGeoAnnotationMultiEllipseObject () | |
virtual | ~ossimGeoAnnotationMultiEllipseObject () |
ossimGeoAnnotationMultiEllipseObject (const std::vector< ossimGpt > ¢erPoints, const ossimDpt &widthHeight, bool enableFill=false, unsigned char r=255, unsigned char g=255, unsigned char b=255, long thickness=1) | |
ossimGeoAnnotationMultiEllipseObject (const ossimDpt &widthHeight, bool enableFill=false, unsigned char r=255, unsigned char g=255, unsigned char b=255, long thickness=1) | |
ossimGeoAnnotationMultiEllipseObject (const ossimGeoAnnotationMultiEllipseObject &rhs) | |
virtual ossimObject * | dup () const |
virtual ossimAnnotationObject * | getNewClippedObject (const ossimDrect &rect) const |
virtual void | transform (ossimImageGeometry *projection) |
virtual void | applyScale (double x, double y) |
virtual void | draw (ossimRgbImage &anImage) const |
virtual bool | intersects (const ossimDrect &rect) const |
virtual void | addPoint (const ossimGpt &point) |
virtual void | setColor (unsigned char r, unsigned char g, unsigned char b) |
virtual void | setThickness (ossim_uint8 thickness) |
virtual void | setPoint (int i, const ossimGpt &point) |
virtual void | setWidthHeight (const ossimDpt &widthHeight) |
virtual void | resize (ossim_uint32 newSize) |
virtual void | setFillFlag (bool fillFlag) |
virtual std::ostream & | print (std::ostream &out) const |
Generic print method. More... | |
virtual void | getBoundingRect (ossimDrect &rect) const |
virtual void | computeBoundingRect () |
ossimGeoAnnotationObject (unsigned char r=255, unsigned char g=255, unsigned char b=255, long thickness=1) | |
ossimGeoAnnotationObject (const ossimGeoAnnotationObject &rhs) | |
virtual bool | saveState (ossimKeywordlist &kwl, const char *prefix=0) const |
Saves the current state of this object. More... | |
virtual bool | loadState (const ossimKeywordlist &kwl, const char *prefix=0) |
Method to the load (recreate) the state of an object from a keyword list. More... | |
virtual | ~ossimAnnotationObject () |
ossimAnnotationObject (ossim_uint8 r=255, ossim_uint8 g=255, ossim_uint8 b=255, ossim_uint8 thickness=1) | |
virtual void | applyScale (const ossimDpt &scale) |
virtual ossimDrect | getBoundingRect () const |
void | getColor (ossim_uint8 &r, ossim_uint8 &g, ossim_uint8 &b) const |
ossim_uint8 | getThickness () const |
virtual bool | isPointWithin (const ossimDpt &imagePoint) const |
virtual ossimString | getName () const |
virtual void | setName (const ossimString &name) |
ossim_uint32 | getId () const |
virtual ossim_uint32 | setId () |
ossimObject () | |
virtual | ~ossimObject () |
virtual ossimString | getShortName () const |
virtual ossimString | getLongName () const |
virtual ossimString | getDescription () const |
virtual ossimString | getClassName () const |
virtual RTTItypeid | getType () const |
virtual bool | canCastTo (ossimObject *obj) const |
virtual bool | canCastTo (const RTTItypeid &id) const |
virtual bool | canCastTo (const ossimString &parentClassName) const |
virtual bool | isEqualTo (const ossimObject &obj, ossimCompareType compareType=OSSIM_COMPARE_FULL) const |
virtual void | accept (ossimVisitor &visitor) |
ossimReferenced () | |
ossimReferenced (const ossimReferenced &) | |
ossimReferenced & | operator= (const ossimReferenced &) |
void | ref () const |
increment the reference count by one, indicating that this object has another pointer which is referencing it. More... | |
void | unref () const |
decrement the reference count by one, indicating that a pointer to this object is referencing it. More... | |
void | unref_nodelete () const |
int | referenceCount () const |
Protected Attributes | |
ossimAnnotationMultiEllipseObject * | theProjectedObject |
std::vector< ossimGpt > | thePointList |
ossimDpt | theWidthHeight |
bool | theFillFlag |
ossim_uint8 | theRed |
ossim_uint8 | theGreen |
ossim_uint8 | theBlue |
ossim_uint8 | theThickness |
ossimString | theName |
ossim_uint32 | theId |
static ossim_uint32 | getNextId () |
static void | restIdCounter () |
virtual | ~ossimGeoAnnotationObject () |
virtual | ~ossimReferenced () |
static ossim_uint32 | theIdCounter = 0 |
Definition at line 14 of file ossimGeoAnnotationMultiEllipseObject.h.
ossimGeoAnnotationMultiEllipseObject::ossimGeoAnnotationMultiEllipseObject | ( | ) |
Definition at line 16 of file ossimGeoAnnotationMultiEllipseObject.cpp.
References ossimAnnotationMultiEllipseObject::setFillFlag(), and theProjectedObject.
Referenced by dup().
Definition at line 24 of file ossimGeoAnnotationMultiEllipseObject.cpp.
References theProjectedObject.
ossimGeoAnnotationMultiEllipseObject::ossimGeoAnnotationMultiEllipseObject | ( | const std::vector< ossimGpt > & | centerPoints, |
const ossimDpt & | widthHeight, | ||
bool | enableFill = false , |
unsigned char | r = 255 , |
unsigned char | g = 255 , |
unsigned char | b = 255 , |
long | thickness = 1 |
Definition at line 32 of file ossimGeoAnnotationMultiEllipseObject.cpp.
ossimGeoAnnotationMultiEllipseObject::ossimGeoAnnotationMultiEllipseObject | ( | const ossimDpt & | widthHeight, |
Definition at line 48 of file ossimGeoAnnotationMultiEllipseObject.cpp.
ossimGeoAnnotationMultiEllipseObject::ossimGeoAnnotationMultiEllipseObject | ( | const ossimGeoAnnotationMultiEllipseObject & | rhs | ) |
Definition at line 61 of file ossimGeoAnnotationMultiEllipseObject.cpp.
Definition at line 164 of file ossimGeoAnnotationMultiEllipseObject.cpp.
References thePointList.
Referenced by ossimGdalOgrVectorAnnotation::loadMultiPoint().
Implements ossimAnnotationObject.
Definition at line 110 of file ossimGeoAnnotationMultiEllipseObject.cpp.
References ossimNotify(), and ossimNotifyLevel_NOTICE.
Definition at line 145 of file ossimGeoAnnotationMultiEllipseObject.cpp.
References ossimAnnotationMultiEllipseObject::computeBoundingRect(), and theProjectedObject.
Referenced by transform().
Definition at line 118 of file ossimGeoAnnotationMultiEllipseObject.cpp.
References ossimAnnotationMultiEllipseObject::draw(), and theProjectedObject.
Definition at line 150 of file ossimGeoAnnotationMultiEllipseObject.cpp.
References ossimGeoAnnotationMultiEllipseObject().
Referenced by getNewClippedObject().
Definition at line 140 of file ossimGeoAnnotationMultiEllipseObject.cpp.
References ossimAnnotationMultiEllipseObject::getBoundingRect(), and theProjectedObject.
Will allocate a new object that is clipped to the passed. in rect. Look at derived classes to see if the object is actually clipped or not. A new object is returned if it clips to the rect else NULL should be returned it doesn't clip.
Definition at line 155 of file ossimGeoAnnotationMultiEllipseObject.cpp.
References dup(), ossimNotify(), and ossimNotifyLevel_NOTICE.
Definition at line 123 of file ossimGeoAnnotationMultiEllipseObject.cpp.
References ossimAnnotationMultiEllipseObject::intersects(), and theProjectedObject.
Derived classes should re-implement as they see fit.
Reimplemented from ossimAnnotationObject.
Definition at line 134 of file ossimGeoAnnotationMultiEllipseObject.cpp.
References ossimAnnotationMultiEllipseObject::print(), and theProjectedObject.
Definition at line 175 of file ossimGeoAnnotationMultiEllipseObject.cpp.
Definition at line 89 of file ossimGeoAnnotationMultiEllipseObject.cpp.
References ossimAnnotationObject::setColor(), and theProjectedObject.
Referenced by ossimVpfAnnotationFeatureInfo::buildPointFeature(), and ossimVpfAnnotationFeatureInfo::setDrawingFeaturesToAnnotation().
Definition at line 83 of file ossimGeoAnnotationMultiEllipseObject.cpp.
References ossimAnnotationMultiEllipseObject::setFillFlag(), theFillFlag, and theProjectedObject.
Definition at line 169 of file ossimGeoAnnotationMultiEllipseObject.cpp.
Definition at line 100 of file ossimGeoAnnotationMultiEllipseObject.cpp.
References ossimAnnotationObject::setThickness(), and theProjectedObject.
Definition at line 128 of file ossimGeoAnnotationMultiEllipseObject.cpp.
References ossimAnnotationMultiEllipseObject::setWidthHeight(), theProjectedObject, and theWidthHeight.
Add the projection interface to all geographically defined objects.
Implements ossimGeoAnnotationObject.
Definition at line 70 of file ossimGeoAnnotationMultiEllipseObject.cpp.
References computeBoundingRect(), ossimAnnotationMultiEllipseObject::resize(), thePointList, theProjectedObject, and ossimImageGeometry::worldToLocal().
protected |
Definition at line 67 of file ossimGeoAnnotationMultiEllipseObject.h.
Referenced by setFillFlag().
protected |
Definition at line 65 of file ossimGeoAnnotationMultiEllipseObject.h.
Referenced by addPoint(), resize(), setPoint(), and transform().
protected |
Definition at line 63 of file ossimGeoAnnotationMultiEllipseObject.h.
Referenced by computeBoundingRect(), draw(), getBoundingRect(), intersects(), ossimGeoAnnotationMultiEllipseObject(), print(), setColor(), setFillFlag(), setThickness(), setWidthHeight(), transform(), and ~ossimGeoAnnotationMultiEllipseObject().
protected |
Definition at line 66 of file ossimGeoAnnotationMultiEllipseObject.h.
Referenced by setWidthHeight().
