ossimGeoAnnotationMultiPolyLineObject Class Reference
#include <ossimGeoAnnotationMultiPolyLineObject.h>
Inheritance diagram for ossimGeoAnnotationMultiPolyLineObject:
ossimGeoAnnotationObject ossimAnnotationObject ossimObject ossimReferenced
Public Member Functions
 ossimGeoAnnotationMultiPolyLineObject ()
 ossimGeoAnnotationMultiPolyLineObject (const vector< ossimPolyLine > &multiPolyLine, ossim_uint8 r=255, ossim_uint8 g=255, ossim_uint8 b=255, ossim_uint8 thickness=1)
 ossimGeoAnnotationMultiPolyLineObject (const ossimGeoAnnotationMultiPolyLineObject &rhs)
virtual void transform (ossimImageGeometry *projection)
virtual void applyScale (double x, double y)
virtual void draw (ossimRgbImage &anImage) const
virtual bool intersects (const ossimDrect &rect) const
virtual ossimAnnotationObjectgetNewClippedObject (const ossimDrect &rect) const
 Generic print method. More...
virtual void getBoundingRect (ossimDrect &rect) const
virtual void addPoint (ossim_uint32 polygonIndex, const ossimGpt &pt)
virtual void setMultiPolyLine (const vector< ossimPolyLine > &multiPoly)
virtual void computeBoundingRect ()
virtual bool isPointWithin (const ossimDpt &imagePoint) const
virtual void setColor (ossim_uint8 r, ossim_uint8 g, ossim_uint8 b)
virtual void setThickness (ossim_uint8 thickness)
void setDatum (const ossimDatum *datum)
const ossimDatumgetDatum () const
const std::vector< ossimPolyLine > & getMultiPolyLine () const
 Saves the current state of this object. More...
- Public Member Functions inherited from ossimGeoAnnotationObject
 ossimGeoAnnotationObject (unsigned char r=255, unsigned char g=255, unsigned char b=255, long thickness=1)
 ossimGeoAnnotationObject (const ossimGeoAnnotationObject &rhs)
- Public Member Functions inherited from ossimAnnotationObject
virtual ~ossimAnnotationObject ()
 ossimAnnotationObject (ossim_uint8 r=255, ossim_uint8 g=255, ossim_uint8 b=255, ossim_uint8 thickness=1)
virtual void applyScale (const ossimDpt &scale)
virtual ossimDrect getBoundingRect () const
void getColor (ossim_uint8 &r, ossim_uint8 &g, ossim_uint8 &b) const
ossim_uint8 getThickness () const
virtual ossimString getName () const
virtual void setName (const ossimString &name)
ossim_uint32 getId () const
virtual ossim_uint32 setId ()
 ossimObject ()
virtual ~ossimObject ()
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
Protected Member Functions
virtual ~ossimGeoAnnotationMultiPolyLineObject ()
void allocateProjectedPolyLine ()
- Protected Member Functions inherited from ossimGeoAnnotationObject
virtual ~ossimGeoAnnotationObject ()
virtual ~ossimReferenced ()
Protected Attributes
std::vector< ossimPolyLinetheMultiPolyLine
ossimDrect theBoundingRect
const ossimDatumtheDatum
ossimRefPtr< ossimAnnotationMultiPolyLineObjecttheProjectedPolyLineObject
- Protected Attributes inherited from ossimAnnotationObject
ossim_uint8 theRed
ossim_uint8 theGreen
ossim_uint8 theBlue
ossim_uint8 theThickness
ossimString theName
ossim_uint32 theId
Additional Inherited Members
- Static Public Member Functions inherited from ossimAnnotationObject
static ossim_uint32 getNextId ()
static void restIdCounter ()
- Static Protected Attributes inherited from ossimAnnotationObject
static ossim_uint32 theIdCounter = 0
Detailed Description
Definition at line 21 of file ossimGeoAnnotationMultiPolyLineObject.h.
◆ ossimGeoAnnotationMultiPolyLineObject() [1/3]
ossimGeoAnnotationMultiPolyLineObject::ossimGeoAnnotationMultiPolyLineObject ( )
Definition at line 23 of file ossimGeoAnnotationMultiPolyLineObject.cpp.
References allocateProjectedPolyLine(), ossimDrect::makeNan(), and theBoundingRect.
Referenced by dup().
24  :
30 {
33 }
void makeNan()
Definition: ossimDrect.h:388
ossimRefPtr< ossimAnnotationMultiPolyLineObject > theProjectedPolyLineObject
static ossimDatumFactory * instance()
ossimGeoAnnotationObject(unsigned char r=255, unsigned char g=255, unsigned char b=255, long thickness=1)
◆ ossimGeoAnnotationMultiPolyLineObject() [2/3]
ossimGeoAnnotationMultiPolyLineObject::ossimGeoAnnotationMultiPolyLineObject ( const vector< ossimPolyLine > &  multiPolyLine,
ossim_uint8  r = 255,
ossim_uint8  g = 255,
ossim_uint8  b = 255,
ossim_uint8  thickness = 1
Definition at line 35 of file ossimGeoAnnotationMultiPolyLineObject.cpp.
41  :
42  ossimGeoAnnotationObject(r, g, b, thickness),
43  theMultiPolyLine(multiPoly),
47 {
50 }
void makeNan()
◆ ossimGeoAnnotationMultiPolyLineObject() [3/3]
ossimGeoAnnotationMultiPolyLineObject::ossimGeoAnnotationMultiPolyLineObject ( const ossimGeoAnnotationMultiPolyLineObject rhs)
◆ ~ossimGeoAnnotationMultiPolyLineObject()
ossimGeoAnnotationMultiPolyLineObject::~ossimGeoAnnotationMultiPolyLineObject ( )
protectedvirtual
Definition at line 67 of file ossimGeoAnnotationMultiPolyLineObject.cpp.
References theProjectedPolyLineObject.
68 {
70 }
Member Function Documentation
◆ addPoint()
void ossimGeoAnnotationMultiPolyLineObject::addPoint ( ossim_uint32  polygonIndex,
const ossimGpt pt
virtual
Definition at line 165 of file ossimGeoAnnotationMultiPolyLineObject.cpp.
References theMultiPolyLine, and theProjectedPolyLineObject.
167 {
168  if(polygonIndex < theMultiPolyLine.size())
169  {
170  theMultiPolyLine[polygonIndex].addPoint(pt);
171
172  // we will have to reset the projected polygon
174  }
175 }
◆ allocateProjectedPolyLine()
void ossimGeoAnnotationMultiPolyLineObject::allocateProjectedPolyLine ( )
protected
◆ applyScale()
void ossimGeoAnnotationMultiPolyLineObject::applyScale ( double  x,
double  y
virtual
Implements ossimAnnotationObject.
Definition at line 72 of file ossimGeoAnnotationMultiPolyLineObject.cpp.
References ossimNotify(), and ossimNotifyLevel_NOTICE.
73 {
75  << "ossimGeoAnnotationPolyLineObject::applyScale NOT IMPLEMENTED!!!!"
76  << endl;
77 }
◆ computeBoundingRect()
void ossimGeoAnnotationMultiPolyLineObject::computeBoundingRect ( )
virtual
◆ draw()
void ossimGeoAnnotationMultiPolyLineObject::draw ( ossimRgbImage anImage) const
virtual
Definition at line 152 of file ossimGeoAnnotationMultiPolyLineObject.cpp.
References ossimAnnotationMultiPolyLineObject::draw(), theProjectedPolyLineObject, and ossimRefPtr< T >::valid().
153 {
155  {
157  }
158 }
virtual void draw(ossimRgbImage &anImage) const
bool valid() const
Definition: ossimRefPtr.h:75
◆ dup()
ossimObject * ossimGeoAnnotationMultiPolyLineObject::dup ( ) const
virtual
◆ getBoundingRect()
void ossimGeoAnnotationMultiPolyLineObject::getBoundingRect ( ossimDrect rect) const
virtual
◆ getDatum()
const ossimDatum * ossimGeoAnnotationMultiPolyLineObject::getDatum ( ) const
Definition at line 230 of file ossimGeoAnnotationMultiPolyLineObject.cpp.
References theDatum.
231 {
232  return theDatum;
233 }
◆ getMultiPolyLine() [1/2]
const std::vector< ossimPolyLine > & ossimGeoAnnotationMultiPolyLineObject::getMultiPolyLine ( ) const
Definition at line 236 of file ossimGeoAnnotationMultiPolyLineObject.cpp.
References theMultiPolyLine.
237 {
238  return theMultiPolyLine;
239 }
◆ getMultiPolyLine() [2/2]
Definition at line 242 of file ossimGeoAnnotationMultiPolyLineObject.cpp.
243 {
244  return theMultiPolyLine;
245 }
◆ getNewClippedObject()
ossimAnnotationObject * ossimGeoAnnotationMultiPolyLineObject::getNewClippedObject ( const ossimDrect rect) const
virtual
Will allocate a new object that is clipped to the passed. in rect. Look at derived classes to see if the object is actually clipped or not. A new object is returned if it clips to the rect else NULL should be returned it doesn't clip.
Definition at line 142 of file ossimGeoAnnotationMultiPolyLineObject.cpp.
References dup(), ossimNotify(), and ossimNotifyLevel_NOTICE.
144 {
146  << "ossimGeoAnnotationMultiPolyObject::getNewClippedObject "
147  << "NOT IMPLEMENTED" << endl;
148
149  return (ossimAnnotationObject*)(dup());
150 }
◆ intersects()
bool ossimGeoAnnotationMultiPolyLineObject::intersects ( const ossimDrect rect) const
virtual
Definition at line 134 of file ossimGeoAnnotationMultiPolyLineObject.cpp.
135 {
137  << "ossimGeoAnnotationMultiPolyObject::intersects NOT IMPLEMENTED"
138  << endl;
139  return false;
140 }
◆ isPointWithin()
bool ossimGeoAnnotationMultiPolyLineObject::isPointWithin ( const ossimDpt imagePoint) const
virtual
This method allows you to pick an object. It will return true or false if the point falls somewhere on an object. Look at derived classes for further information.
Reimplemented from ossimAnnotationObject.
Definition at line 195 of file ossimGeoAnnotationMultiPolyLineObject.cpp.
References ossimAnnotationMultiPolyLineObject::isPointWithin(), theProjectedPolyLineObject, and ossimRefPtr< T >::valid().
196 {
198  {
199  return theProjectedPolyLineObject->isPointWithin(imagePoint);
200  }
201
202  return false;
203 }
bool valid() const
virtual bool isPointWithin(const ossimDpt &imagePoint) const
◆ loadState()
bool ossimGeoAnnotationMultiPolyLineObject::loadState ( const ossimKeywordlist kwl,
const char *  prefix = 0
virtual
Reimplemented from ossimGeoAnnotationObject.
Definition at line 271 of file ossimGeoAnnotationMultiPolyLineObject.cpp.
References ossimPolyLine::addPoint(), ossimString::c_str(), ossimPolyLine::clear(), ossimKeywordlist::find(), ossimKeywordlist::getNumberOfSubstringKeys(), ossimGeoAnnotationObject::loadState(), ossimPolyLine::size(), status, theMultiPolyLine, ossimString::toString(), x, and y.
273 {
274  //---
275  // Base class state must be called first to pick up colors...
276  //---
277  bool status = ossimGeoAnnotationObject::loadState(kwl, prefix);
278
279  ossim_uint32 index = 0;
280  ossimString copyPrefix = prefix;
281  ossim_uint32 count = kwl.getNumberOfSubstringKeys(copyPrefix+
282  "v[0-9]");
283
284  ossim_uint32 numberOfMatches = 0;
285  const ossim_uint32 MAX_INDEX = count + 100;
286  ossimPolyLine pl;
287
288  while(numberOfMatches < count)
289  {
290  ossimString key = "v";
291  key += ossimString::toString(index);
292
293  const char* lookup = kwl.find(prefix, key.c_str());
294  if (lookup)
295  {
296  ++numberOfMatches;
297  ossimDpt dpt;
298  ossimString x,y;
299  std::istringstream is(lookup);
300  is >> x >> y;
301  pl.addPoint(ossimDpt(x.toDouble(), y.toDouble()));
302  }
303
304  if (pl.size() == 2)
305  {
306  theMultiPolyLine.push_back(pl);
307  pl.clear();
308  }
309
310  ++index;
311
312  if (index > MAX_INDEX) // Avoid infinite loop...
313  {
314  break;
315  }
316  }
317
318  return status;
319 }
ossim_uint32 x
ossim_uint32 getNumberOfSubstringKeys(const ossimString &regularExpression) const
ossim_uint32 y
Numeric to string methods.
ossim_uint32 size()
unsigned int ossim_uint32
void addPoint(const ossimDpt &pt)
return status
const char * c_str() const
Definition: ossimString.h:396
std::basic_istringstream< char > istringstream
Class for char input memory streams.
Definition: ossimIosFwd.h:32
◆ print()
std::ostream & ossimGeoAnnotationMultiPolyLineObject::print ( std::ostream &  out) const
virtual
Derived classes should re-implement as they see fit.
Returns
std::ostream&
Definition at line 126 of file ossimGeoAnnotationMultiPolyLineObject.cpp.
References ossimNotify(), ossimNotifyLevel_INFO, and theMultiPolyLine.
127 {
129  << "ossimGeoAnnotationMultiPolyLineObject::print\n"
130  << "Poly line size: " << theMultiPolyLine.size() << endl;
131  return out;
132 }
◆ saveState()
bool ossimGeoAnnotationMultiPolyLineObject::saveState ( ossimKeywordlist kwl,
) const
virtual
Definition at line 247 of file ossimGeoAnnotationMultiPolyLineObject.cpp.
References ossimKeywordlist::add(), ossimString::c_str(), ossimPolyLine::getNumberOfVertices(), ossimGeoAnnotationObject::saveState(), theMultiPolyLine, ossimString::toString(), ossimDpt::x, and ossimDpt::y.
249 {
250  ossim_uint32 vIdx = 0;
251
252  for(ossim_uint32 i = 0; i < theMultiPolyLine.size(); ++i)
253  {
255  for(ossim_uint32 j = 0; j < pl.getNumberOfVertices(); ++j)
256  {
257  ossimDpt dpt = pl[j];
259  os << setprecision(15) << dpt.x << " " << dpt.y << endl;
260
261  ossimString key = "v";
262  key += ossimString::toString(vIdx);
263  kwl.add(prefix, key.c_str(), os.str().c_str());
264  ++vIdx;
265  }
266  }
267
268  return ossimGeoAnnotationObject::saveState(kwl, prefix);
269 }
std::basic_ostringstream< char > ostringstream
Class for char output memory streams.
Definition: ossimIosFwd.h:35
double y
Definition: ossimDpt.h:165
ossim_uint32 getNumberOfVertices() const
Definition: ossimPolyLine.h:70
double x
Definition: ossimDpt.h:164
◆ setColor()
void ossimGeoAnnotationMultiPolyLineObject::setColor ( ossim_uint8  r,
ossim_uint8  g,
ossim_uint8  b
virtual
Definition at line 205 of file ossimGeoAnnotationMultiPolyLineObject.cpp.
References ossimAnnotationObject::setColor(), theProjectedPolyLineObject, and ossimRefPtr< T >::valid().
Referenced by ossimVpfAnnotationFeatureInfo::buildEdgFeature(), and ossimVpfAnnotationFeatureInfo::setDrawingFeaturesToAnnotation().
208 {
211  {
213  }
214 }
bool valid() const
virtual void setColor(ossim_uint8 r, ossim_uint8 g, ossim_uint8 b)
◆ setDatum()
void ossimGeoAnnotationMultiPolyLineObject::setDatum ( const ossimDatum datum)
Definition at line 225 of file ossimGeoAnnotationMultiPolyLineObject.cpp.
226 {
227  theDatum = datum;
228 }
◆ setMultiPolyLine()
void ossimGeoAnnotationMultiPolyLineObject::setMultiPolyLine ( const vector< ossimPolyLine > &  multiPoly)
virtual
Definition at line 177 of file ossimGeoAnnotationMultiPolyLineObject.cpp.
179 {
180  theMultiPolyLine = multiPoly;
182 }
◆ setThickness()
void ossimGeoAnnotationMultiPolyLineObject::setThickness ( ossim_uint8  thickness)
virtual
◆ transform()
void ossimGeoAnnotationMultiPolyLineObject::transform ( ossimImageGeometry projection)
virtual
Add the projection interface to all geographically defined objects.
Implements ossimGeoAnnotationObject.
Definition at line 79 of file ossimGeoAnnotationMultiPolyLineObject.cpp.
References allocateProjectedPolyLine(), ossimAnnotationMultiPolyLineObject::getMultiPolyLine(), ossimDpt::hasNans(), ossimGpt::latd(), ossimGpt::lond(), ossim::nan(), theDatum, theMultiPolyLine, theProjectedPolyLineObject, and ossimImageGeometry::worldToLocal().
80 {
81  if(!projection)
82  {
83  return;
84  }
85
87
88  //---
89  // NOTE:
90  // allocateProjectedPolygon() will set theProjectedPolyLineObject to 0 if
91  // theMultiPolyLine is empty (theMultiPolyLine.size() == 0). So check
92  // before accessing pointer to avoid a core dump.
93  //---
95  {
96  return;
97  }
98
99  std::vector<ossimPolyLine>& multiPolyLine =
101  ossimGpt tempPoint(0,0, ossim::nan(), theDatum);
102
103  for(std::vector<ossimPolyLine>::size_type polyI = 0;
104  polyI < theMultiPolyLine.size();
105  ++polyI)
106  {
107  ossimPolyLine polyLine;
108
109  ossim_uint32 numberOfVertices =
110  theMultiPolyLine[polyI].getNumberOfVertices();
111  for(ossim_uint32 pointI = 0; pointI < numberOfVertices; ++pointI)
112  {
113  tempPoint.latd(theMultiPolyLine[polyI][pointI].lat);
114  tempPoint.lond(theMultiPolyLine[polyI][pointI].lon);
115  ossimDpt temp;
116  projection->worldToLocal(tempPoint, temp);
117  if(!temp.hasNans())
118  {
119  multiPolyLine[polyI].addPoint(temp);
120  }
121  }
122  multiPolyLine[polyI].roundToIntegerBounds(true);
123  }
124 }
double nan()
Definition: ossimCommon.h:135
const std::vector< ossimPolyLine > & getMultiPolyLine() const
bool hasNans() const
Definition: ossimDpt.h:67
bool worldToLocal(const ossimGpt &world_pt, ossimDpt &local_pt) const
Exposes the 3D world-to-local image coordinate reverse projection.
Member Data Documentation
◆ theBoundingRect
ossimDrect ossimGeoAnnotationMultiPolyLineObject::theBoundingRect
protected
◆ theDatum
const ossimDatum* ossimGeoAnnotationMultiPolyLineObject::theDatum
protected
Definition at line 84 of file ossimGeoAnnotationMultiPolyLineObject.h.
Referenced by getDatum(), setDatum(), and transform().
◆ theMultiPolyLine
std::vector<ossimPolyLine> ossimGeoAnnotationMultiPolyLineObject::theMultiPolyLine
protected
◆ theProjectedPolyLineObject
ossimRefPtr<ossimAnnotationMultiPolyLineObject> ossimGeoAnnotationMultiPolyLineObject::theProjectedPolyLineObject
protected
