Public Member Functions | Protected Attributes | List of all members
ossimGoogleProjection Class Reference
#include <ossimGoogleProjection.h>
Inheritance diagram for ossimGoogleProjection:
ossimMapProjection ossimProjection ossimObject ossimErrorStatusInterface ossimReferenced
 ossimGoogleProjection (const ossimEllipsoid &ellipsoid=ossimEllipsoid(), const ossimGpt &origin=ossimGpt())
 ossimGoogleProjection (const ossimGoogleProjection &)
 ~ossimGoogleProjection ()
virtual ossimDpt forward (const ossimGpt &worldPoint) const
 All map projections will convert the world coordinate to an easting northing (Meters). More...
virtual ossimGpt inverse (const ossimDpt &projectedPoint) const
 Will take a point in meters and convert it to ground. More...
virtual void update ()
virtual bool operator== (const ossimProjection &projection) const
 Compares this to arg projection and returns TRUE if the same. More...
- Public Member Functions inherited from ossimMapProjection
 ossimMapProjection (const ossimEllipsoid &ellipsoid=ossimEllipsoid(), const ossimGpt &origin=ossimGpt())
 ossimMapProjection (const ossimMapProjection &src)
virtual ossimDpt worldToLineSample (const ossimGpt &worldPoint) const
virtual void worldToLineSample (const ossimGpt &worldPoint, ossimDpt &lineSample) const
virtual ossimGpt lineSampleToWorld (const ossimDpt &projectedPoint) const
virtual void lineSampleToWorld (const ossimDpt &projectedPoint, ossimGpt &gpt) const
virtual void lineSampleHeightToWorld (const ossimDpt &lineSampPt, const double &heightAboveEllipsoid, ossimGpt &worldPt) const
 This is the pure virtual that projects the image point to the given elevation above ellipsoid, thereby bypassing reference to a DEM. More...
virtual void lineSampleToEastingNorthing (const ossimDpt &liineSample, ossimDpt &eastingNorthing) const
virtual void eastingNorthingToLineSample (const ossimDpt &eastingNorthing, ossimDpt &lineSample) const
virtual void eastingNorthingToWorld (const ossimDpt &eastingNorthing, ossimGpt &worldPt) const
virtual double getFalseEasting () const
virtual double getFalseNorthing () const
virtual double getStandardParallel1 () const
 Derived classes should implement as needed. More...
virtual double getStandardParallel2 () const
virtual void setPcsCode (ossim_uint32 pcsCode)
virtual ossim_uint32 getPcsCode () const
 Returns the EPSG PCS code or 32767 if the projection is a custom (non-EPSG) projection. More...
virtual ossimString getProjectionName () const
 Returns the projection name. More...
virtual double getA () const
 ACCESS METHODS: More...
virtual double getB () const
virtual double getF () const
virtual const ossimDptgetDecimalDegreesPerPixel () const
 Returns decimal degrees per pixel as an ossimDpt with "x" representing longitude and "y" representing latitude. More...
virtual const ossimDptgetUlEastingNorthing () const
virtual const ossimGptgetUlGpt () const
virtual const ossimDatumgetDatum () const
const ossimEllipsoidgetEllipsoid () const
const ossimGptgetOrigin () const
virtual bool isGeographic () const
virtual void applyScale (const ossimDpt &scale, bool recenterTiePoint)
 Applies scale to theDeltaLonPerPixel, theDeltaLatPerPixel and theMetersPerPixel data members (eg: theDeltaLonPerPixel *= scale.x). More...
virtual void setEllipsoid (const ossimEllipsoid &ellipsoid)
 SET METHODS: More...
virtual void setAB (double a, double b)
virtual void setDatum (const ossimDatum *datum)
 Sets theDatum to datum. More...
virtual void setOrigin (const ossimGpt &origin)
 Sets theOrigin to origin. More...
virtual void setMetersPerPixel (const ossimDpt &gsd)
virtual void setDecimalDegreesPerPixel (const ossimDpt &gsd)
virtual void setUlTiePoints (const ossimGpt &gpt)
virtual void setUlTiePoints (const ossimDpt &eastingNorthing)
virtual void setUlEastingNorthing (const ossimDpt &ulEastingNorthing)
virtual void setUlGpt (const ossimGpt &ulGpt)
virtual void assign (const ossimProjection &aProjection)
 Prints data members to stream. More...
virtual void computeDegreesPerPixel ()
 Computes the approximate resolution in degrees/pixel. More...
virtual void computeMetersPerPixel ()
 This will go from the ground point and give you an approximate meters per pixel. More...
void setMatrix (double rotation, const ossimDpt &scale, const ossimDpt &translation)
void setMatrixScale (const ossimDpt &scale)
void setMatrixRotation (double rotation)
void setMatrixTranslation (const ossimDpt &translation)
void snapTiePointTo (ossim_float64 multiple, ossimUnitType unitType)
 Utility method to snap the tie point to some multiple. More...
void snapTiePointToOrigin ()
void setElevationLookupFlag (bool flag)
bool getElevationLookupFlag () const
ossimUnitType getModelTransformUnitType () const
void setModelTransformUnitType (ossimUnitType unit)
bool hasModelTransform () const
void setProjectionUnits (ossimUnitType units)
ossimUnitType getProjectionUnits () const
 OSSIM considers all map projection coordinates (including false eastings and northings) to be in meters. More...
 ossimProjection ()
virtual ~ossimProjection ()
 ossimObject ()
virtual ~ossimObject ()
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
 ossimErrorStatusInterface ()
bool hasError () const
 TYPE_DATA
- Protected Attributes inherited from ossimMapProjection
ossimEllipsoid theEllipsoid
 This method verifies that the projection parameters match the current pcs code. More...
ossimGpt theOrigin
const ossimDatumtheDatum
 This is only set if we want to have built in datum shifting. More...
ossimDpt theMetersPerPixel
 Holds the number of meters per pixel. More...
ossimDpt theDegreesPerPixel
 Hold the decimal degrees per pixel. More...
ossimGpt theUlGpt
 Hold tie point in decimal degrees. More...
ossimDpt theUlEastingNorthing
 Hold tie point as easting northing. More...
ossimDpt theFalseEastingNorthing
 Hold the false easting northing. More...
ossim_uint32 thePcsCode
 Projection Coordinate System(PCS) code. More...
bool theElevationLookupFlag
ossimMatrix4x4 theModelTransform
ossimMatrix4x4 theInverseModelTransform
ossimUnitType theModelTransformUnitType
ossimUnitType theProjectionUnits
 Linear units of the projection as indicated in the projection's specification: More...
ossimErrorCode theErrorStatus
Additional Inherited Members
- Protected Member Functions inherited from ossimMapProjection
virtual ~ossimMapProjection ()
void updateFromTransform ()
virtual ~ossimReferenced ()
Detailed Description
Definition at line 13 of file ossimGoogleProjection.h.
◆ ossimGoogleProjection() [1/2]
ossimGoogleProjection::ossimGoogleProjection ( const ossimEllipsoid ellipsoid = ossimEllipsoid(),
const ossimGpt origin = ossimGpt()
Definition at line 37 of file ossimGoogleProjection.cpp.
References ossimMapProjection::thePcsCode, and update().
39  :ossimMapProjection(ellipsoid, origin)
40 {
41  thePcsCode = 3857;
42  update();
43 }
virtual ossimGpt origin() const
ossimMapProjection(const ossimEllipsoid &ellipsoid=ossimEllipsoid(), const ossimGpt &origin=ossimGpt())
◆ ossimGoogleProjection() [2/2]
ossimGoogleProjection::ossimGoogleProjection ( const ossimGoogleProjection src)
Definition at line 44 of file ossimGoogleProjection.cpp.
45  :ossimMapProjection(src)
46 {
47  thePcsCode = 3857;
48  update();
49 }
◆ ~ossimGoogleProjection()
ossimGoogleProjection::~ossimGoogleProjection ( )
Definition at line 51 of file ossimGoogleProjection.cpp.
52 {
53
54 }
Member Function Documentation
◆ dup()
virtual ossimObject* ossimGoogleProjection::dup ( ) const
inlinevirtual
Implements ossimProjection.
Definition at line 20 of file ossimGoogleProjection.h.
20 {return new ossimGoogleProjection(*this);}
ossimGoogleProjection(const ossimEllipsoid &ellipsoid=ossimEllipsoid(), const ossimGpt &origin=ossimGpt())
◆ forward()
ossimDpt ossimGoogleProjection::forward ( const ossimGpt worldPoint) const
virtual
Definition at line 75 of file ossimGoogleProjection.cpp.
References lat2y_m(), ossimGpt::latd(), lon2x_m(), and ossimGpt::lond().
76 {
77  /*
78  double easting = 0.0;
79  double northing = 0.0;
80  ossimGpt gpt = latLon;
81
82  if (theDatum)
83  {
84  if (theDatum->code() != latLon.datum()->code())
85  {
86  gpt.changeDatum(theDatum); // Shift to our datum.
87  }
88  }
89  //double y = Math.Log(Math.Tan((90 + lat) * Math.PI / 360)) / (Math.PI / 180);
90  easting = gpt.lond()*20037508.34/180.0;
91  northing = log(tan((90.0 + gpt.latd())*M_PI/360.0))/(M_PI/180.0);
92  northing *=20037508.34/180.0;
93
94  return ossimDpt(easting, northing);
95  */
96
97  return ossimDpt(lon2x_m(latLon.lond()), lat2y_m(latLon.latd()));
98 }
double lat2y_m(double lat)
double lon2x_m(double lon)
◆ inverse()
ossimGpt ossimGoogleProjection::inverse ( const ossimDpt projectedPoint) const
virtual
Definition at line 61 of file ossimGoogleProjection.cpp.
References ossimMapProjection::theDatum, ossimDpt::x, x2lon_m(), ossimDpt::y, and y2lat_m().
62 {
63  /*
64  double lon = (eastingNorthing.x / 20037508.34) * 180.0;
65  double lat = (eastingNorthing.y / 20037508.34) * 180.0;
66
67  lat = 180.0/M_PI * (2.0 * atan(exp(lat * M_PI / 180)) - M_PI / 2.0);
68
69  return ossimGpt(lat, lon, 0, theDatum);
70  */
71  //return ossimGpt(merc_lat(eastingNorthing.y), merc_lon(eastingNorthing.x), 0, theDatum);
72  return ossimGpt(y2lat_m(eastingNorthing.y), x2lon_m(eastingNorthing.x), 0, theDatum);
73 }
double y2lat_m(double y)
double x2lon_m(double x)
const ossimDatum * theDatum
◆ loadState()
bool ossimGoogleProjection::loadState ( const ossimKeywordlist kwl,
const char *  prefix = 0
virtual
Definition at line 105 of file ossimGoogleProjection.cpp.
References ossimMapProjection::loadState(), ossimMapProjection::thePcsCode, and update().
106 {
107  thePcsCode = 3857;
108  // Must do this first.
109  bool flag = ossimMapProjection::loadState(kwl, prefix);
110
111  update();
112  return flag;
113 }
◆ operator==()
bool ossimGoogleProjection::operator== ( const ossimProjection projection) const
virtual
NOTE: As currently implemented in OSSIM, map projections also contain image geometry information like tiepoint and scale. This operator is only concerned with the map specification and ignores image geometry differences.
Definition at line 115 of file ossimGoogleProjection.cpp.
116 {
117  if (!ossimMapProjection::operator==(projection))
118  return false;
119
120  const ossimGoogleProjection* p = dynamic_cast<const ossimGoogleProjection*>(&projection);
121
122  return (p != 0);
123 }
◆ saveState()
bool ossimGoogleProjection::saveState ( ossimKeywordlist kwl,
) const
virtual
Definition at line 100 of file ossimGoogleProjection.cpp.
References ossimMapProjection::saveState().
101 {
102  return ossimMapProjection::saveState(kwl, prefix);
103 }
◆ update()
void ossimGoogleProjection::update ( )
virtual
Definition at line 56 of file ossimGoogleProjection.cpp.
References ossimMapProjection::update().
Referenced by loadState(), and ossimGoogleProjection().
57 {
59 }
Member Data Documentation
◆ TYPE_DATA
ossimGoogleProjection::TYPE_DATA
protected
Definition at line 32 of file ossimGoogleProjection.h.
