ossimGridRemapSource Class Reference
#include <ossimGridRemapSource.h>
Inheritance diagram for ossimGridRemapSource:
ossimImageSourceFilter ossimImageSource ossimConnectableObjectListener ossimSource ossimListener ossimConnectableObject ossimErrorStatusInterface ossimObject ossimListenerManager ossimPropertyInterface ossimReferenced
Public Member Functions
 ossimGridRemapSource ()
 ossimGridRemapSource (ossimImageSource *inputSource, ossimGridRemapEngine *engine)
void setRemapEngine (ossimGridRemapEngine *engine)
ossimGridRemapEnginegetRemapEngine ()
virtual void initialize (const ossimDrect &uv_rect, const ossimDpt &grid_spacing)
void setGridNode (const ossimDpt &view_pt, const double *value)
virtual ossimRefPtr< ossimImageDatagetTile (const ossimIrect &origin, ossim_uint32 resLevel=0)
void lock ()
void unlock ()
bool isLocked () const
ossimDblGridgetGrid (unsigned int index)
const ossimFilenamegetGridFilename () const
void setGridFilename (const ossimFilename &grid_filename)
virtual void initialize ()
virtual ~ossimImageSource ()
 Method to get a tile. More...
 For RTTI support. More...
virtual ~ossimSource ()
virtual void enableSource ()
virtual void disableSource ()
const ossimIdgetId () const
 ossimObject ()
virtual ~ossimObject ()
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
 ossimListenerManager ()
 ossimPropertyInterface ()
 ossimErrorStatusInterface ()
bool hasError () const
 ProcessEvent. More...
 ossimListener ()
virtual ~ossimListener ()
void enableListener ()
void disableListener ()
Protected Member Functions
virtual ~ossimGridRemapSource ()
void deallocateGrids ()
virtual ~ossimReferenced ()
Protected Attributes
vector< ossimDblGrid * > theGrids
ossimFilename theGridFilename
ossimGridRemapEnginetheRemapEngine
bool theRemapIsLockedFlag
bool theGridIsFilled
bool theEnableFlag
bool theInitializedFlag
ossimId theId
ossimString theDescription
ossimObjecttheOwner
bool theInputListIsFixedFlag
bool theOutputListIsFixedFlag
bool theEnabledFlag
bool theFireEventFlag
ossimErrorCode theErrorStatus
bool theListenerEnableFlag
Additional Inherited Members
Detailed Description
CLASS: ossimGridRemapSource
Definition at line 39 of file ossimGridRemapSource.h.
◆ ossimGridRemapSource() [1/2]
ossimGridRemapSource::ossimGridRemapSource ( )
Constructors:
Definition at line 47 of file ossimGridRemapSource.cpp.
References ossimSource::disableSource().
48  :
50  theGridFilename (0),
51  theRemapEngine (0),
53  theGridIsFilled(false)
54 {
55  disableSource();
56 }
ossimImageSourceFilter(ossimObject *owner=NULL)
virtual void disableSource()
Definition: ossimSource.cpp:89
ossimGridRemapEngine * theRemapEngine
◆ ossimGridRemapSource() [2/2]
ossimGridRemapSource::ossimGridRemapSource ( ossimImageSource inputSource,
ossimGridRemapEngine engine
Definition at line 62 of file ossimGridRemapSource.cpp.
64  :
65  ossimImageSourceFilter(inputSource),
66  theGridFilename (0),
69  theGridIsFilled(false)
70 {
71  disableSource();
72 }
virtual ossimObject * dup() const =0
◆ ~ossimGridRemapSource()
ossimGridRemapSource::~ossimGridRemapSource ( )
protectedvirtual
Definition at line 78 of file ossimGridRemapSource.cpp.
References deallocateGrids(), and theRemapEngine.
79 {
81  theRemapEngine = 0;
82 }
Member Function Documentation
◆ deallocateGrids()
void ossimGridRemapSource::deallocateGrids ( )
protected
Deallocates grid memory.
Definition at line 326 of file ossimGridRemapSource.cpp.
Referenced by initialize(), and ~ossimGridRemapSource().
327 {
328  static const char MODULE[] = "ossimGridRemapSource::deallocateMemory()";
329  if (traceExec()) CLOG << "entering..." << endl;
330
331  vector<ossimDblGrid*>::iterator grid = theGrids.begin();
332  while (grid != theGrids.end())
333  {
334  delete *grid;
335  grid++;
336  }
337  theGrids.clear();
338
339  if (traceExec()) CLOG << "returning..." << endl;
340  return;
341 }
#define CLOG
Definition: ossimTrace.h:23
◆ getGrid()
ossimDblGrid * ossimGridRemapSource::getGrid ( unsigned int  index)
Provides access to individual grids (pointer) given an index. Null pointer returned if index out of range.
Definition at line 314 of file ossimGridRemapSource.cpp.
References theGrids.
315 {
316  if (index >= theGrids.size())
317  return 0;
318
319  return theGrids[index];
320 }
◆ getGridFilename()
const ossimFilename& ossimGridRemapSource::getGridFilename ( ) const
inline
Returns grid filename (may be empty)
Definition at line 120 of file ossimGridRemapSource.h.
References theGridFilename.
120 { return theGridFilename; }
◆ getRemapEngine()
ossimGridRemapEngine* ossimGridRemapSource::getRemapEngine ( )
inline
Provides access to the remap engine:
Definition at line 59 of file ossimGridRemapSource.h.
References theRemapEngine.
59 { return theRemapEngine; }
◆ getTile()
ossimRefPtr< ossimImageData > ossimGridRemapSource::getTile ( const ossimIrect origin,
ossim_uint32  resLevel = 0
virtual
Implementation of virtual method to return remapped tile.
Definition at line 118 of file ossimGridRemapSource.cpp.
References ossimDataObject::getDataObjectStatus(), ossimImageSource::getTile(), ossimSource::isSourceEnabled(), OSSIM_EMPTY, OSSIM_NULL, ossimGridRemapEngine::remapTile(), theGridIsFilled, theGrids, ossimImageSourceFilter::theInputConnection, theRemapEngine, ossimIrect::ul(), ossimRefPtr< T >::valid(), and ossimImageData::validate().
120 {
121  if(!theInputConnection)
122  return NULL;
123
124  //***
125  // Fetch tile from input source:
126  //***
128  resLevel);
129
130  //---
131  // Bypass this filter if it is not initialized, or if input tile is bogus:
132  //---
133  if ((!isSourceEnabled()) || (!tile.valid()) || (!theRemapEngine) ||
134  (tile->getDataObjectStatus()==OSSIM_NULL) ||
135  (tile->getDataObjectStatus()==OSSIM_EMPTY))
136  {
137  return tile;
138  }
139
140  //***
141  // Insure that the grid has been filled in case nodes were being randomly set
142  //***
143  if (!theGridIsFilled)
144  {
145  vector<ossimDblGrid*>::iterator grid = theGrids.begin();
146  while (grid != theGrids.end())
147  {
148 // (*grid)->setInterpolationType(ossimDblGrid::BILINEAR);
149  (*grid)->interpolateNullValuedNodes();
150  grid++;
151  }
152  theGridIsFilled = true;
153  }
154
155  //***
156  // hand off the actual remap to the ATB engine. This object knows how to
157  // interpret the grids for the particular remap algorithm selected:
158  //***
159  theRemapEngine->remapTile(rect.ul(), this, tile);
160
161  tile->validate();
162  return tile;
163 }
bool valid() const
Definition: ossimRefPtr.h:75
virtual void remapTile(const ossimDpt &origin_point, ossimGridRemapSource *remapper, ossimRefPtr< ossimImageData > &tile)=0
◆ initialize()
void ossimGridRemapSource::initialize ( const ossimDrect uv_rect,
const ossimDpt grid_spacing
virtual
Permits initializing the remap grid after construction.
Definition at line 88 of file ossimGridRemapSource.cpp.
References deallocateGrids(), ossimGridRemapEngine::getNumberOfParams(), theGridFilename, theGridIsFilled, theGrids, theRemapEngine, and ossimString::toString().
90 {
92  int num_params;
93
94  if (theRemapEngine)
95  {
96  num_params = theRemapEngine->getNumberOfParams();
97
98  for (int p=0; p<num_params; p++)
99  {
100  ossimDblGrid* grid = new ossimDblGrid(uv_rect, grid_spacing);
101  theGrids.push_back(grid);
102  }
103
104  theGridFilename = "ogrs";
105  theGridFilename += ossimString::toString(reinterpret_cast<ossim_int64>(this));
106  theGridFilename += ".org";
107
108  theGridIsFilled = false;
109  }
110 }
Numeric to string methods.
◆ isLocked()
bool ossimGridRemapSource::isLocked ( ) const
inline
Returns the status of the lock flag.
Definition at line 109 of file ossimGridRemapSource.h.
References theRemapIsLockedFlag.
◆ loadState()
bool ossimGridRemapSource::loadState ( const ossimKeywordlist kwl,
const char *  prefix = 0
virtual
Restore the state of the object from a keywordlist.
Definition at line 169 of file ossimGridRemapSource.cpp.
171 {
172  static const char MODULE[] = "ossimGridRemapSource::loadState()";
173  if (traceExec()) CLOG << "entering..." << endl;
174
175  bool successful = false;
176  const char* value;
177
178  //***
179  // Reset object in preparation for reassignment:
180  //***
181  deallocateGrids();
182  theRemapEngine = 0;
183
184  //***
185  // Read the remap engine type:
186  //***
187  value = kwl.find(prefix, REMAP_ENGINE_KW);
189  if (!theRemapEngine)
190  {
191 // CLOG << "ERROR: could not instantiate remap engine. Aborting..." << endl;
192 // if (traceExec()) CLOG << "returning..." << endl;
193 // return false;
194  }
195
196  //***
197  // Read the grid filename and open input stream:
198  //***
199  theGridIsFilled = false;
200  value = kwl.find(prefix, GRID_FILENAME_KW);
201  if (value)
202  {
203  theGridFilename = value;
205
206  //***
207  // Create an input stream from the grid file to pass to the
208  // corresponding grid:
209  //***
210  int num_grids = theRemapEngine->getNumberOfParams();
211  for (int i=0; (i<num_grids) && successful; i++)
212  {
213  ossimDblGrid* grid = new ossimDblGrid;
214  successful = grid->load(is);
215  if (successful)
216  theGrids.push_back(grid);
217  }
218  if (!successful)
219  {
220  CLOG << "ERROR: Encountered errorloading remap grids at file: "
221  << theGridFilename << ". Remapper disabled." << endl;
222  if (traceExec()) CLOG << "returning..." << endl;
223  return false;
224  }
225  theGridIsFilled = true;
226  }
227
228  //***
229  // Allow base class to parse list:
230  //***
231  bool rtn_stat = ossimImageSourceFilter::loadState(kwl, prefix);
232
233  //***
234  // Enable source only if KWL read was successful:
235  //***
236  if (theRemapEngine && successful && rtn_stat)
237  enableSource();
238
239  if (traceExec()) CLOG << "returning..." << endl;
240  return rtn_stat;
241 }
static ossimGridRemapEngine * create(const char *spec)
#define CLOG
std::basic_ifstream< char > ifstream
Class for char input file streams.
Definition: ossimIosFwd.h:44
bool load(std::istream &is)
const char * chars() const
For backward compatibility.
Definition: ossimString.h:77
virtual void enableSource()
Definition: ossimSource.cpp:84
◆ lock()
void ossimGridRemapSource::lock ( )
inline
Locks the image to prevent grid adjustment. The remapper continues to remap given the current grid (if enabled), but all target values computed are such that no change in the grids will occur in an adjsutment. If more than one overlapping image is locked, the target will may be influenced by all locked images, but the remap grids will not be updated.
Definition at line 99 of file ossimGridRemapSource.h.
Referenced by ossimAtbController::lockImage(), and ossimAtbController::unlockImage().
◆ saveState()
bool ossimGridRemapSource::saveState ( ossimKeywordlist kwl,
) const
virtual
Save the state of the object to a keywordlist.
Definition at line 247 of file ossimGridRemapSource.cpp.
References ossimKeywordlist::add(), theGridFilename, and theRemapEngine.
249 {
250  static const char MODULE[] = "ossimGridRemapSource::saveState()";
251
252  //***
253  // No filename indicates that this remapper has not been initialized:
254  //***
255  if (!theGridFilename)
256  return false;
257
258  //***
259  // Write the remap engine type:
260  //***
261  if (theRemapEngine)
262  kwl.add(prefix, REMAP_ENGINE_KW, theRemapEngine->getClassName());
263
264  //***
265  // Write the filename to the KWL:
266  //***
267  if (!theGridFilename.empty())
268  {
269  kwl.add(prefix, GRID_FILENAME_KW, theGridFilename);
270
271  //***
272  // Loop over each remap component to write out the grid:
273  //***
275  bool successful = true;
276  int num_components = theRemapEngine->getNumberOfParams();
277  for (int p=0; (p<num_components)&&successful; p++)
278  successful = theGrids[p]->save(os, "Remap-Grid");
279
280  if (!successful)
281  {
282  CLOG << "ERROR: Encountered saving remap grids to file: "
283  << theGridFilename << ". State not properly saved."
284  << endl;
285  return false;
286  }
287  }
288
289  return ossimImageSourceFilter::saveState(kwl, prefix);
290 }
#define CLOG
virtual ossimString getClassName() const
Definition: ossimObject.cpp:64
const char * c_str() const
Definition: ossimString.h:396
bool empty() const
Definition: ossimString.h:411
std::basic_ofstream< char > ofstream
Class for char output file streams.
Definition: ossimIosFwd.h:47
◆ setGridFilename()
void ossimGridRemapSource::setGridFilename ( const ossimFilename grid_filename)
Sets the grid filename and initiates read.
Definition at line 359 of file ossimGridRemapSource.cpp.
360 {
361  theGridFilename = grid_filename;
362  //***
363  // NOT COMPLETE###
364  //***
365 }
◆ setGridNode()
void ossimGridRemapSource::setGridNode ( const ossimDpt view_pt,
const double *  value
Sets a node of the member grid to the value specified. The grid is flagged as unfilled.
Definition at line 298 of file ossimGridRemapSource.cpp.
References theGridIsFilled, and theGrids.
300 {
301  int numGrids = (int)theGrids.size();
302  for (int i=0; i<numGrids; i++)
303  theGrids[i]->setNearestNode(view_pt, value[i]);
304
305  theGridIsFilled = false;
306
307  return;
308 }
◆ setRemapEngine()
void ossimGridRemapSource::setRemapEngine ( ossimGridRemapEngine engine)
ossimAtbPointSource Initializes the remap engine. This object implements specific algorithms for interpreting the grids owned by this remapper. It actually performs the remapping.
Definition at line 348 of file ossimGridRemapSource.cpp.
References theGridIsFilled, and theRemapEngine.
349 {
350
351  theRemapEngine = engine;
352  theGridIsFilled = false;
353 }
◆ unlock()
void ossimGridRemapSource::unlock ( )
inline
Unlocks the grids for adjustment.
Definition at line 104 of file ossimGridRemapSource.h.
Member Data Documentation
◆ theGridFilename
ossimFilename ossimGridRemapSource::theGridFilename
protected
Definition at line 136 of file ossimGridRemapSource.h.
Referenced by getGridFilename(), initialize(), saveState(), and setGridFilename().
◆ theGridIsFilled
bool ossimGridRemapSource::theGridIsFilled
protected
Definition at line 139 of file ossimGridRemapSource.h.
Referenced by getTile(), initialize(), setGridNode(), and setRemapEngine().
◆ theGrids
vector<ossimDblGrid*> ossimGridRemapSource::theGrids
protected
Definition at line 135 of file ossimGridRemapSource.h.
Referenced by getGrid(), getTile(), initialize(), and setGridNode().
◆ theRemapEngine
ossimGridRemapEngine* ossimGridRemapSource::theRemapEngine
protected
◆ theRemapIsLockedFlag
bool ossimGridRemapSource::theRemapIsLockedFlag
protected
Definition at line 138 of file ossimGridRemapSource.h.
Referenced by isLocked(), lock(), and unlock().
