Public Member Functions | Static Public Member Functions | Private Member Functions | List of all members
ossimH5InfoFactory Class Reference
Info factory. More...
#include <ossimH5InfoFactory.h>
Inheritance diagram for ossimH5InfoFactory:
ossimInfoFactoryInterface
virtual ~ossimH5InfoFactory ()
 virtual destructor More...
virtual ossimInfoBasecreate (const ossimFilename &file) const
 create method. More...
- Public Member Functions inherited from ossimInfoFactoryInterface
 ossimInfoFactoryInterface ()
 default constructor More...
virtual ~ossimInfoFactoryInterface ()
virtual std::shared_ptr< ossimInfoBasecreate (std::shared_ptr< ossim::istream > &str, const std::string &connectionString) const =0
static ossimH5InfoFactoryinstance ()
 hidden from use default constructor More...
 ossimH5InfoFactory (const ossimH5InfoFactory &obj)
 hidden from use copy constructor More...
const ossimH5InfoFactoryoperator= (const ossimH5InfoFactory &rhs)
 hidden from use operator = More...
Detailed Description
Info factory.
Definition at line 27 of file ossimH5InfoFactory.h.
◆ ~ossimH5InfoFactory()
ossimH5InfoFactory::~ossimH5InfoFactory ( )
virtual
virtual destructor
Definition at line 23 of file ossimH5InfoFactory.cpp.
24 {}
◆ ossimH5InfoFactory() [1/2]
ossimH5InfoFactory::ossimH5InfoFactory ( )
private
Definition at line 47 of file ossimH5InfoFactory.cpp.
48 {}
◆ ossimH5InfoFactory() [2/2]
ossimH5InfoFactory::ossimH5InfoFactory ( const ossimH5InfoFactory obj)
private
Definition at line 50 of file ossimH5InfoFactory.cpp.
51 {}
Member Function Documentation
◆ create()
ossimInfoBase * ossimH5InfoFactory::create ( const ossimFilename file) const
virtual
create method.
Parameters
fileSome file you want info for.
Returns
ossimInfoBase* on success 0 on failure. Caller is responsible for memory.
Implements ossimInfoFactoryInterface.
Definition at line 33 of file ossimH5InfoFactory.cpp.
References ossimInfoBase::open(), and ossimRefPtr< T >::release().
34 {
35  ossimRefPtr<ossimInfoBase> result = 0;
36
37  // cout << "Calling ossimH5Info ***********************" << endl;
38  result = new ossimH5Info();
39  if ( result->open(file) )
40  {
41  return result.release();
42  }
43
44  return 0;
45 }
virtual bool open(const ossimFilename &file)
open method.
T * release()
Definition: ossimRefPtr.h:93
TIFF info class.
Definition: ossimH5Info.h:29
◆ instance()
ossimH5InfoFactory * ossimH5InfoFactory::instance ( )
static
Definition at line 26 of file ossimH5InfoFactory.cpp.
Referenced by ossimSharedLibraryFinalize(), and ossimSharedLibraryInitialize().
27 {
28  static ossimH5InfoFactory sharedInstance;
29
30  return &sharedInstance;
31 }
◆ operator=()
const ossimH5InfoFactory & ossimH5InfoFactory::operator= ( const ossimH5InfoFactory rhs)
private
Definition at line 53 of file ossimH5InfoFactory.cpp.
55 {
56  return *this;
57 }
