Public Member Functions | Private Attributes | List of all members
ossimKakaduCompressedTarget Class Reference
ossimKakaduCompressedTarget JPEG2000 (J2K) kdu_compressed_target that uses an ostream for writing to the file. More...
#include <ossimKakaduCompressedTarget.h>
Inheritance diagram for ossimKakaduCompressedTarget:
 ossimKakaduCompressedTarget ()
 default construtor More...
virtual ~ossimKakaduCompressedTarget ()
 virtural destructor More...
void setStream (std::ostream *stream)
 Sets the output stream. More...
virtual bool write (const kdu_core::kdu_byte *buf, int num_bytes)
 Write method. More...
virtual bool start_rewrite (kdu_core::kdu_long backtrack)
virtual bool end_rewrite ()
Private Attributes
std::ostream * m_stream
std::streamoff m_restorePosition
Detailed Description
Definition at line 27 of file ossimKakaduCompressedTarget.h.
◆ ossimKakaduCompressedTarget()
ossimKakaduCompressedTarget::ossimKakaduCompressedTarget ( )
default construtor
Definition at line 19 of file ossimKakaduCompressedTarget.cpp.
◆ ~ossimKakaduCompressedTarget()
ossimKakaduCompressedTarget::~ossimKakaduCompressedTarget ( )
virtual
virtural destructor
Definition at line 25 of file ossimKakaduCompressedTarget.cpp.
26 {
27 }
Member Function Documentation
◆ end_rewrite()
bool ossimKakaduCompressedTarget::end_rewrite ( )
virtual
Definition at line 89 of file ossimKakaduCompressedTarget.cpp.
References m_restorePosition, and m_stream.
90 {
91  bool result = false;
92  if (m_stream)
93  {
94  m_stream->seekp(m_restorePosition, std::ios_base::beg);
95  result = m_stream->good();
96  }
97  return result;
98 }
◆ setStream()
void ossimKakaduCompressedTarget::setStream ( std::ostream *  stream)
Note the ossimKakaduCompressedTarget only uses the stream it does not take over(delete) memory on destruction.
Parameters
streamThe output stream.
Definition at line 29 of file ossimKakaduCompressedTarget.cpp.
30 {
31  if ( stream )
32  {
33  m_stream = stream;
34
35  //---
36  // Keep track of the stream position for the start_rewrite call.
37  // ostream::tellp() on windows visual studio 10 x64 fails past
38  // 2^31-1(2GB) even though the std::streamoff held in the
39  // std::streampos is eight bytes.
40  // This call is safe as the stream is typically at 0.
41  //---
42  m_restorePosition = stream->tellp();
43  }
44 }
◆ start_rewrite()
bool ossimKakaduCompressedTarget::start_rewrite ( kdu_core::kdu_long  backtrack)
virtual
Definition at line 77 of file ossimKakaduCompressedTarget.cpp.
78 {
79  bool result = false;
80  if (m_stream)
81  {
82  std::streamoff off = m_restorePosition - static_cast<std::streamoff>(backtrack);
83  m_stream->seekp(off, std::ios_base::beg);
84  result = m_stream->good();
85  }
86  return result;
87 }
◆ write()
bool ossimKakaduCompressedTarget::write ( const kdu_core::kdu_byte *  buf,
int  num_bytes
virtual
Write method.
Parameters
bufThe buffer to pull from.
num_bytesThe number of bytes to write.
Returns
Definition at line 46 of file ossimKakaduCompressedTarget.cpp.
47 {
48  if ( m_restorePosition == 0 )
49  {
50  //---
51  // First write call. Do a tellp in case the stream was moved as in the case of
52  // nitf where the nitf header and nitf image header get written before we write
53  // pixel data.
54  //---
55  m_restorePosition = m_stream->tellp();
56  }
57
58  bool result = false;
59  if (m_stream)
60  {
61  m_stream->write((const char*)buf,
62  static_cast<std::streamsize>(num_bytes));
63
64  //---
65  // Keep track of the stream postition for the start_rewrite call. Do it
66  // manually as ostream::tellp() on windows visual studio 10 x64 fails
67  // past 2^31-1(2GB) even though the std::streamoff held in the
68  // std::streampos is eight bytes.
69  //---
70  m_restorePosition += static_cast<std::streamoff>(num_bytes);
71
72  result = m_stream->good();
73  }
74  return result;
75 }
Member Data Documentation
◆ m_restorePosition
std::streamoff ossimKakaduCompressedTarget::m_restorePosition
private
Definition at line 63 of file ossimKakaduCompressedTarget.h.
Referenced by end_rewrite(), setStream(), start_rewrite(), and write().
◆ m_stream
std::ostream* ossimKakaduCompressedTarget::m_stream
private
Definition at line 62 of file ossimKakaduCompressedTarget.h.
