ossimKmlSuperOverlayWriter Class Reference
#include <ossimKmlSuperOverlayWriter.h>
Inheritance diagram for ossimKmlSuperOverlayWriter:
ossimImageFileWriter ossimImageWriter ossimProcessInterface ossimConnectableObjectListener ossimOutputSource ossimListener ossimSource ossimConnectableObject ossimErrorStatusInterface ossimObject ossimListenerManager ossimPropertyInterface ossimReferenced
Public Member Functions
 ossimKmlSuperOverlayWriter ()
 default constructor More...
virtual ~ossimKmlSuperOverlayWriter ()
virtual void getImageTypeList (std::vector< ossimString > &imageTypeList) const
 void getImageTypeList(std::vector<ossimString>& imageTypeList)const More...
virtual bool isOpen () const
virtual bool open ()
virtual void close ()
 saves the state of the object. More...
 Will set the property whose name matches the argument "property->getName()". More...
 Pushes this's names onto the list of property names. More...
virtual ossimString getExtension () const
 Returns a 3-letter extension from the image type descriptor (theOutputImageType) that can be used for image file extensions. More...
bool hasImageType (const ossimString &imageType) const
 bool hasImageType(const ossimString& imageType) const More...
virtual bool writeStream ()
 Method to write the image to a stream. More...
- Public Member Functions inherited from ossimImageFileWriter
 ossimImageFileWriter (const ossimFilename &filename=ossimFilename(), ossimImageSource *inputSource=0, ossimObject *owner=0)
 The writer will own the sequencer. More...
virtual ~ossimImageFileWriter ()
virtual bool getOutputHasInternalOverviews (void) const
 Examples of writers that always generate internal overviews are ossim_kakadu_jp2 and ossim_kakadu_nitf_j2k. More...
virtual void setTileSize (const ossimIpt &tileSize)
 Sets the output image tiling size if supported by the writer. More...
virtual bool writeEnviHeaderFile ()
 Will write an envi header file. More...
virtual bool writeErsHeaderFile ()
 Will write an ER Mapper header file. More...
virtual bool writeExternalGeometryFile ()
 Will write an external geometry file. More...
virtual bool writeFgdcFile ()
 Will write an fgdc file. More...
virtual bool writeHistogramFile ()
 Returns true on success, false on error. More...
virtual bool writeJpegWorldFile ()
 Will write a jpeg world file. More...
virtual bool writeOverviewFile (ossim_uint16 tiff_compress_type=1, ossim_int32 jpeg_compress_quality=75, bool includeR0=false)
 Write out an ossim overview file from the source_file. More...
virtual bool writeReadmeFile ()
 Will write a readme file. More...
virtual bool writeTiffWorldFile ()
 Will write a world file. More...
virtual bool writeWorldFile ()
virtual bool writeMetaDataFiles ()
 Convenience method that calls meta data write methods that are flagged to be called. More...
virtual void setAreaOfInterest (const ossimIrect &inputRect)
virtual void changeSequencer (ossimImageSourceSequencer *sequencer)
 Sets the sequencer and connects it to the input of this. More...
virtual ossimImageSourceSequencergetSequencer ()
virtual void initialize ()
 Initialize method. More...
virtual bool execute ()
 Calls: writeFile() writeMetaDataFiles() More...
virtual bool setOutputStream (ossimRefPtr< ossimOStream > stream)
 Sets the output stream to write to. More...
virtual bool setOutputStream (std::ostream &str)
 tmp drb More...
virtual ossimRefPtr< ossimOStreamgetOutputStream () const
 Method to return the stream attached to output. More...
virtual void setOutputImageType (ossim_int32 type)
virtual void setOutputImageType (const ossimString &type)
virtual ossim_int32 getOutputImageType () const
virtual ossimString getOutputImageTypeString () const
virtual void setOutputName (const ossimString &outputName)
virtual void setFilename (const ossimFilename &file)
virtual bool canConnectMyInputTo (ossim_int32 inputIndex, const ossimConnectableObject *object) const
virtual bool getWriteImageFlag () const
 Control flags... More...
virtual bool getWriteHistogramFlag () const
virtual bool getWriteOverviewFlag () const
virtual bool getScaleToEightBitFlag () const
virtual bool getWriteEnviHeaderFlag () const
virtual bool getWriteErsHeaderFlag () const
virtual bool getWriteExternalGeometryFlag () const
virtual bool getWriteFgdcFlag () const
virtual bool getWriteJpegWorldFileFlag () const
virtual bool getWriteReadmeFlag () const
virtual bool getWriteTiffWorldFileFlag () const
virtual bool getWriteWorldFileFlag () const
virtual void setWriteImageFlag (bool flag)
virtual void setWriteOverviewFlag (bool flag)
virtual void setWriteHistogramFlag (bool flag)
virtual void setScaleToEightBitFlag (bool flag)
virtual void setWriteEnviHeaderFlag (bool flag)
virtual void setWriteErsHeaderFlag (bool flag)
virtual void setWriteExternalGeometryFlag (bool flag)
virtual void setWriteFgdcFlag (bool flag)
virtual void setWriteJpegWorldFile (bool flag)
virtual void setWriteReadme (bool flag)
virtual void setWriteTiffWorldFile (bool flag)
virtual void setWriteWorldFile (bool flag)
virtual ossim_uint16 getOverviewCompressType () const
virtual ossim_int32 getOverviewJpegCompressQuality () const
virtual void setOverviewCompressType (ossim_uint16 type)
virtual void setOverviewJpegCompressQuality (ossim_int32 quality)
 Overrides base "addListener" this will capture the pointer and then call the base class "addListener". More...
 Overrides base "removeListener". More...
virtual void setPixelType (ossimPixelType type)
 If "point" the coordinate tie points are relative to the center of the pixel. More...
virtual void setPixelType (const ossimString &type)
virtual ossimPixelType getPixelType () const
virtual void getPixelTypeString (ossimString &type) const
- Public Member Functions inherited from ossimImageWriter
 ossimImageWriter (ossimObject *owner=NULL)
 ossimImageWriter (ossimObject *owner, ossim_uint32 numberOfInputs, ossim_uint32 numberOfOutputs, bool inputListIsFixed, bool outputListIsFixed)
virtual ~ossimImageWriter ()
virtual bool setViewingRect (const ossimIrect &aRect)
virtual ossimIrect getAreaOfInterest () const
- Public Member Functions inherited from ossimOutputSource
 ossimOutputSource (ossimObject *owner=NULL)
 ossimOutputSource (ossimObject *owner, ossim_uint32 inputListSize, ossim_uint32 outputListSize, bool inputListIsFixedFlag=true, bool outputListIsFixedFlag=true)
virtual ~ossimOutputSource ()
virtual bool open (const ossimString &outputName)
virtual const ossimStringgetOutputName ()
virtual ~ossimSource ()
virtual void enableSource ()
virtual void disableSource ()
const ossimIdgetId () const
 ossimObject ()
virtual ~ossimObject ()
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
 ossimListenerManager ()
 ossimPropertyInterface ()
 ossimErrorStatusInterface ()
bool hasError () const
- Public Member Functions inherited from ossimProcessInterface
 ossimProcessInterface ()
virtual void abort ()
bool needsAborting () const
bool isAborted () const
bool isExecuting () const
void enableEvents ()
void disableEvents ()
 ProcessEvent. More...
virtual void refreshEvent (ossimRefreshEvent &)
 ossimListener ()
virtual ~ossimListener ()
void enableListener ()
void disableListener ()
Protected Member Functions
virtual bool writeFile ()
 Writes the file to disk or a stream. More...
bool generateRootKml (ossimString filename, ossim_float64 north, ossim_float64 south, ossim_float64 east, ossim_float64 west, ossim_int32 tilesize)
bool generateChildKml (ossimString filename, ossim_int32 zoom, ossim_int32 yloop, ossim_int32 ix, ossim_int32 iy, ossim_int32 dxsize, ossim_int32 dysize, ossim_int32 xsize, ossim_int32 ysize, ossim_int32 maxzoom, ossimRefPtr< ossimMapProjection > proj, ossimString fileExt)
void generateTile (ossimString filename, ossim_int32 ix, ossim_int32 iy, ossim_int32 dxsize, ossim_int32 dysize)
bool zipWithMinizip (std::vector< ossimString > srcFiles, ossimString srcDirectory, ossimString targetFile)
void propagateViewChange ()
 Sends a view interface visitor to the input connetion. More...
- Protected Member Functions inherited from ossimImageFileWriter
bool writeWorldFile (const ossimFilename &file)
 Common world file writer method. More...
virtual ~ossimReferenced ()
Protected Attributes
ossimRefPtr< ossimImageFileWriterm_imageWriter
ossimRefPtr< ossimMapProjectionm_mapProjection
bool m_isKmz
bool m_isPngFormat
- Protected Attributes inherited from ossimImageFileWriter
ossimRefPtr< ossimImageSourceSequencertheInputConnection
ossimRefPtr< ossimViewControllertheViewController
ossimListenertheProgressListener
ossimFilename theFilename
ossimString theOutputImageType
bool theWriteImageFlag
bool theWriteOverviewFlag
bool theWriteHistogramFlag
bool theScaleToEightBitFlag
ossim_uint16 theOverviewCompressType
ossim_int32 theOverviewJpegCompressQuality
bool theWriteEnviHeaderFlag
 External meta data writer flags. More...
bool theWriteErsHeaderFlag
bool theWriteExternalGeometryFlag
bool theWriteFgdcFlag
bool theWriteJpegWorldFileFlag
bool theWriteReadmeFlag
bool theWriteTiffWorldFileFlag
bool theWriteWorldFileFlag
bool theAutoCreateDirectoryFlag
ossimUnitType theLinearUnits
 If not a geographic projection this allows the user to set the linear units of the output tag to be: More...
ossimPixelType thePixelType
 OSSIM_PIXEL_IS_POINT = 0, OSSIM_PIXEL_IS_AREA = 1. More...
- Protected Attributes inherited from ossimImageWriter
ossimIrect theAreaOfInterest
- Protected Attributes inherited from ossimOutputSource
ossimString theOutputName
bool theEnableFlag
bool theInitializedFlag
ossimId theId
ossimString theDescription
ossimObjecttheOwner
bool theInputListIsFixedFlag
bool theOutputListIsFixedFlag
bool theEnabledFlag
bool theFireEventFlag
ossimErrorCode theErrorStatus
- Protected Attributes inherited from ossimProcessInterface
double thePercentComplete
ossimString theMessage
bool theEventFlag
bool theListenerEnableFlag
Additional Inherited Members
- Public Types inherited from ossimProcessInterface
enum  ossimProcessStatus {
Detailed Description
Definition at line 32 of file ossimKmlSuperOverlayWriter.h.
◆ ossimKmlSuperOverlayWriter()
ossimKmlSuperOverlayWriter::ossimKmlSuperOverlayWriter ( )
default constructor
Definition at line 43 of file ossimKmlSuperOverlayWriter.cpp.
References getShortName(), and ossimImageFileWriter::setOutputImageType().
45  m_imageWriter(0),
46  m_mapProjection(0),
47  m_isKmz(false),
48  m_isPngFormat(false)
49 {
50  // Set the output image type in the base class.
52 }
virtual void setOutputImageType(ossim_int32 type)
ossimImageFileWriter(const ossimFilename &filename=ossimFilename(), ossimImageSource *inputSource=0, ossimObject *owner=0)
ossimRefPtr< ossimMapProjection > m_mapProjection
virtual ossimString getShortName() const
ossimRefPtr< ossimImageFileWriter > m_imageWriter
◆ ~ossimKmlSuperOverlayWriter()
ossimKmlSuperOverlayWriter::~ossimKmlSuperOverlayWriter ( )
virtual
Definition at line 54 of file ossimKmlSuperOverlayWriter.cpp.
References close().
55 {
56  close();
57 }
Member Function Documentation
◆ close()
void ossimKmlSuperOverlayWriter::close ( )
virtual
Generic interface to allow one to close a consumer. For displays this might minimize the window and free up internal pointers for file writers it will make sure the file stream is closed and flushed.
Implements ossimOutputSource.
Definition at line 478 of file ossimKmlSuperOverlayWriter.cpp.
References m_imageWriter, m_mapProjection, and ossimRefPtr< T >::valid().
Referenced by ~ossimKmlSuperOverlayWriter().
479 {
480  if (m_imageWriter.valid())
481  {
482  m_imageWriter = 0;
483  }
484  if (m_mapProjection.valid())
485  {
486  m_mapProjection = 0;
487  }
488 }
bool valid() const
Definition: ossimRefPtr.h:75
◆ generateChildKml()
bool ossimKmlSuperOverlayWriter::generateChildKml ( ossimString  filename,
ossim_int32  zoom,
ossim_int32  yloop,
ossim_int32  ix,
ossim_int32  iy,
ossim_int32  dxsize,
ossim_int32  dysize,
ossim_int32  xsize,
ossim_int32  ysize,
ossimRefPtr< ossimMapProjection proj,
ossimString  fileExt
protected
Definition at line 619 of file ossimKmlSuperOverlayWriter.cpp.
References ossimString::c_str(), ossimGpt::lat, ossimMapProjection::lineSampleToWorld(), ossimIrect::ll(), ossimGpt::lon, ossimIrect::lr(), m_mapProjection, ossimGpt::makeNan(), ossimIrect::ul(), ossimIrect::ur(), and ossimRefPtr< T >::valid().
631 {
632  ossim_int32 yIndex = yloop-iy-1;
633  ossimIpt ul(dxsize*ix, dysize*(iy+1));
634  ossimIpt ur(dxsize*(ix+1), dysize*(iy+1));
635  ossimIpt lr(dxsize*(ix+1), dysize*iy);
636  ossimIpt ll(dxsize*ix, dysize*iy);
637  ossimIrect rect(ul, ur, lr, ll);
638
639  ossim_float64 tnorth = 0.0;
640  ossim_float64 tsouth = 0.0;
641  ossim_float64 teast = 0.0;
642  ossim_float64 twest = 0.0;
643
644  ossim_float64 upperleftT = 0.0;
645  ossim_float64 lowerleftT = 0.0;
646
647  ossim_float64 rightbottomT = 0.0;
648  ossim_float64 leftbottomT = 0.0;
649
650  ossim_float64 lefttopT = 0.0;
651  ossim_float64 righttopT = 0.0;
652
653  ossim_float64 lowerrightT = 0.0;
654  ossim_float64 upperrightT = 0.0;
655
656  ossimGpt ulg;
657  ossimGpt llg;
658  ossimGpt lrg;
659  ossimGpt urg;
660
661  if (m_mapProjection.valid())
662  {
663  m_mapProjection->lineSampleToWorld(rect.ul(), ulg);
664  m_mapProjection->lineSampleToWorld(rect.ll(), llg);
665  m_mapProjection->lineSampleToWorld(rect.lr(), lrg);
666  m_mapProjection->lineSampleToWorld(rect.ur(), urg);
667
668  twest = llg.lon;
669  tsouth = llg.lat;
670  teast = urg.lon;
671  tnorth = urg.lat;
672
673  upperleftT = ulg.lon;
674  lefttopT = ulg.lat;
675
676  lowerleftT = llg.lon;
677  leftbottomT = llg.lat;
678
679  lowerrightT = lrg.lon;
680  rightbottomT = lrg.lat;
681
682  upperrightT = urg.lon;
683  righttopT = urg.lat;
684  }
685
686  std::vector<ossim_int32> xchildren;
687  std::vector<ossim_int32> ychildern;
688  std::vector<ossim_int32> ychildernIndex;
689
690  ossim_int32 maxLodPix = -1;
691  if ( zoom < maxzoom )
692  {
693  ossim_float64 zareasize = pow(2.0, (maxzoom - zoom - 1))*dxsize;
694  ossim_float64 zareasize1 = pow(2.0, (maxzoom - zoom - 1))*dysize;
695  xchildren.push_back(ix*2);
696  ossim_int32 tmp = ix*2 + 1;
697  ossim_int32 tmp1 = (ossim_int32)ceil(xsize/zareasize);
698  if (tmp < tmp1)
699  {
700  xchildren.push_back(ix*2+1);
701  }
702
703  ychildern.push_back(iy*2);
704  tmp = iy*2 + 1;
705  tmp1 = (ossim_int32)ceil(ysize/zareasize1);
706  if (tmp < tmp1)
707  {
708  ychildern.push_back(iy*2+1);
709  }
710
711  ychildernIndex.push_back(yIndex*2);
712  tmp = yIndex*2 + 1;
713  tmp1 = (ossim_int32)ceil(ysize/zareasize1);
714  if (tmp < tmp1)
715  {
716  ychildernIndex.push_back(yIndex*2+1);
717  }
718  maxLodPix = 2048;
719  }
720
721  FILE* fp = fopen(filename.c_str(), "wb");
722  if (fp == NULL)
723  {
724  return false;
725  }
726
727  fprintf(fp, "<kml xmlns=\"http://earth.google.com/kml/2.1\" xmlns:gx=\"http://www.google.com/kml/ext/2.2\">\n");
728  fprintf(fp, "\t<Document>\n");
729  fprintf(fp, "\t\t<name>%d/%d/%d.kml</name>\n", zoom, ix, yIndex);
730  fprintf(fp, "\t\t<Style>\n");
731  fprintf(fp, "\t\t\t<ListStyle id=\"hideChildren\">\n");
732  fprintf(fp, "\t\t\t\t<listItemType>checkHideChildren</listItemType>\n");
733  fprintf(fp, "\t\t\t</ListStyle>\n");
734  fprintf(fp, "\t\t</Style>\n");
735  fprintf(fp, "\t\t<Region>\n");
736  fprintf(fp, "\t\t\t<Lod>\n");
737  fprintf(fp, "\t\t\t\t<minLodPixels>%d</minLodPixels>\n", 128);
738  fprintf(fp, "\t\t\t\t<maxLodPixels>%d</maxLodPixels>\n", maxLodPix);
739  fprintf(fp, "\t\t\t</Lod>\n");
740  fprintf(fp, "\t\t\t<LatLonAltBox>\n");
741  fprintf(fp, "\t\t\t\t<north>%f</north>\n", tnorth);
742  fprintf(fp, "\t\t\t\t<south>%f</south>\n", tsouth);
743  fprintf(fp, "\t\t\t\t<east>%f</east>\n", teast);
744  fprintf(fp, "\t\t\t\t<west>%f</west>\n", twest);
745  fprintf(fp, "\t\t\t</LatLonAltBox>\n");
746  fprintf(fp, "\t\t</Region>\n");
747  fprintf(fp, "\t\t<GroundOverlay>\n");
748  fprintf(fp, "\t\t\t<drawOrder>%d</drawOrder>\n", zoom);
749  fprintf(fp, "\t\t\t<Icon>\n");
750  fprintf(fp, "\t\t\t\t<href>%d%s</href>\n", yIndex, fileExt.c_str());
751  fprintf(fp, "\t\t\t</Icon>\n");
752  fprintf(fp, "\t\t\t<gx:LatLonQuad>\n");
753  fprintf(fp, "\t\t\t\t<coordinates>\n");
754  fprintf(fp, "\t\t\t\t\t%f, %f, 0\n", lowerleftT, leftbottomT);
755  fprintf(fp, "\t\t\t\t\t%f, %f, 0\n", lowerrightT, rightbottomT);
756  fprintf(fp, "\t\t\t\t\t%f, %f, 0\n", upperrightT, righttopT);
757  fprintf(fp, "\t\t\t\t\t%f, %f, 0\n", upperleftT, lefttopT);
758  fprintf(fp, "\t\t\t\t</coordinates>\n");
759  fprintf(fp, "\t\t\t</gx:LatLonQuad>\n");
760  fprintf(fp, "\t\t</GroundOverlay>\n");
761
762  //generate lat, lon info and links for the previous zoom of kml
763  for (ossim_uint32 i = 0; i < xchildren.size(); i++)
764  {
765  int cx = xchildren[i];
766  for (ossim_uint32 j = 0; j < ychildern.size(); j++)
767  {
768  ossim_int32 cy = ychildern[j];
769  ossim_int32 cyIndex = ychildernIndex[ychildernIndex.size()-j-1];
770
771  ossimIpt ulc(dxsize*cx, dysize*(cy+1));
772  ossimIpt urc(dxsize*(cx+1), dysize*(cy+1));
773  ossimIpt lrc(dxsize*(cx+1), dysize*cy);
774  ossimIpt llc(dxsize*cx, dysize*cy);
775  ossimIrect rectc(ulc, urc, lrc, llc);
776
777  ossim_float64 cnorth = 0.0;
778  ossim_float64 csouth = 0.0;
779  ossim_float64 ceast = 0.0;
780  ossim_float64 cwest = 0.0;
781
782  if (proj.valid())
783  {
784  ulg.makeNan();
785  lrg.makeNan();
786  proj->lineSampleToWorld(rectc.ll(), llg);
787  proj->lineSampleToWorld(rectc.ur(), urg);
788
789  cwest = llg.lon;
790  csouth = llg.lat;
791
792  ceast = urg.lon;
793  cnorth = urg.lat;
794  }
795
796  fprintf(fp, "\t\t<NetworkLink>\n");
797  fprintf(fp, "\t\t\t<name>%d/%d/%d%s</name>\n", zoom+1, cx, cyIndex, fileExt.c_str());
798  fprintf(fp, "\t\t\t<Region>\n");
799  fprintf(fp, "\t\t\t\t<Lod>\n");
800  fprintf(fp, "\t\t\t\t\t<minLodPixels>128</minLodPixels>\n");
801  fprintf(fp, "\t\t\t\t\t<maxLodPixels>-1</maxLodPixels>\n");
802  fprintf(fp, "\t\t\t\t</Lod>\n");
803  fprintf(fp, "\t\t\t\t<LatLonAltBox>\n");
804  fprintf(fp, "\t\t\t\t\t<north>%f</north>\n", cnorth);
805  fprintf(fp, "\t\t\t\t\t<south>%f</south>\n", csouth);
806  fprintf(fp, "\t\t\t\t\t<east>%f</east>\n", ceast);
807  fprintf(fp, "\t\t\t\t\t<west>%f</west>\n", cwest);
808  fprintf(fp, "\t\t\t\t</LatLonAltBox>\n");
809  fprintf(fp, "\t\t\t</Region>\n");
810  fprintf(fp, "\t\t\t<Link>\n");
811  fprintf(fp, "\t\t\t\t<href>../../%d/%d/%d.kml</href>\n", zoom+1, cx, cyIndex);
812  fprintf(fp, "\t\t\t\t<viewRefreshMode>onRegion</viewRefreshMode>\n");
813  fprintf(fp, "\t\t\t\t<viewFormat/>\n");
814  fprintf(fp, "\t\t\t</Link>\n");
815  fprintf(fp, "\t\t</NetworkLink>\n");
816  }
817  }
818
819  fprintf(fp, "\t</Document>\n");
820  fprintf(fp, "</kml>\n");
821  fclose(fp);
822  return true;
823 }
bool valid() const
void makeNan()
Definition: ossimGpt.h:130
double ossim_float64
virtual ossimGpt lineSampleToWorld(const ossimDpt &projectedPoint) const
ossim_float64 lon
Definition: ossimGpt.h:266
unsigned int ossim_uint32
const char * c_str() const
Definition: ossimString.h:396
ossim_float64 lat
Definition: ossimGpt.h:265
int ossim_int32
◆ generateRootKml()
bool ossimKmlSuperOverlayWriter::generateRootKml ( ossimString  filename,
ossim_float64  east,
ossim_float64  west,
protected
Definition at line 561 of file ossimKmlSuperOverlayWriter.cpp.
References ossimString::c_str(), ossimFilename::fileNoExtension(), and ossimImageFileWriter::theFilename.
567 {
568  FILE* fp = fopen(filename.c_str(), "wb");
569  if (fp == NULL)
570  {
571  return false;
572  }
573  ossim_int32 minlodpixels = tilesize/2;
574
575  ossimString tmpfilename = theFilename.fileNoExtension();
576  // If we haven't writen any features yet, output the layer's schema
577  fprintf(fp, "<kml xmlns=\"http://earth.google.com/kml/2.1\">\n");
578  fprintf(fp, "\t<Document>\n");
579  fprintf(fp, "\t\t<name>%s</name>\n", tmpfilename.c_str());
580  fprintf(fp, "\t\t<description></description>\n");
581  fprintf(fp, "\t\t<Style>\n");
582  fprintf(fp, "\t\t\t<ListStyle id=\"hideChildren\">\n");
583  fprintf(fp, "\t\t\t\t<listItemType>checkHideChildren</listItemType>\n");
584  fprintf(fp, "\t\t\t</ListStyle>\n");
585  fprintf(fp, "\t\t</Style>\n");
586  fprintf(fp, "\t\t<Region>\n \t\t<LatLonAltBox>\n");
587  fprintf(fp, "\t\t\t\t<north>%f</north>\n", north);
588  fprintf(fp, "\t\t\t\t<south>%f</south>\n", south);
589  fprintf(fp, "\t\t\t\t<east>%f</east>\n", east);
590  fprintf(fp, "\t\t\t\t<west>%f</west>\n", west);
591  fprintf(fp, "\t\t\t</LatLonAltBox>\n");
592  fprintf(fp, "\t\t</Region>\n");
593  fprintf(fp, "\t\t<NetworkLink>\n");
594  fprintf(fp, "\t\t\t<open>1</open>\n");
595  fprintf(fp, "\t\t\t<Region>\n");
596  fprintf(fp, "\t\t\t\t<Lod>\n");
597  fprintf(fp, "\t\t\t\t\t<minLodPixels>%d</minLodPixels>\n", minlodpixels);
598  fprintf(fp, "\t\t\t\t\t<maxLodPixels>-1</maxLodPixels>\n");
599  fprintf(fp, "\t\t\t\t</Lod>\n");
600  fprintf(fp, "\t\t\t\t<LatLonAltBox>\n");
601  fprintf(fp, "\t\t\t\t\t<north>%f</north>\n", north);
602  fprintf(fp, "\t\t\t\t\t<south>%f</south>\n", south);
603  fprintf(fp, "\t\t\t\t\t<east>%f</east>\n", east);
604  fprintf(fp, "\t\t\t\t\t<west>%f</west>\n", west);
605  fprintf(fp, "\t\t\t\t</LatLonAltBox>\n");
606  fprintf(fp, "\t\t\t</Region>\n");
607  fprintf(fp, "\t\t\t<Link>\n");
608  fprintf(fp, "\t\t\t\t<href>0/0/0.kml</href>\n");
609  fprintf(fp, "\t\t\t\t<viewRefreshMode>onRegion</viewRefreshMode>\n");
610  fprintf(fp, "\t\t\t</Link>\n");
611  fprintf(fp, "\t\t</NetworkLink>\n");
612  fprintf(fp, "\t</Document>\n");
613  fprintf(fp, "</kml>\n");
614
615  fclose(fp);
616  return true;
617 }
ossimFilename fileNoExtension() const
int ossim_int32
◆ generateTile()
void ossimKmlSuperOverlayWriter::generateTile ( ossimString  filename,
ossim_int32  ix,
ossim_int32  iy,
ossim_int32  dxsize,
ossim_int32  dysize
protected
Definition at line 543 of file ossimKmlSuperOverlayWriter.cpp.
References ossimImageFileWriter::execute(), m_imageWriter, ossimImageFileWriter::setAreaOfInterest(), and ossimImageFileWriter::setFilename().
548 {
549  ossimFilename file = filename;
550  ossimIpt ul(dxsize*ix, dysize*(iy+1));
551  ossimIpt ur(dxsize*(ix+1), dysize*(iy+1));
552  ossimIpt lr(dxsize*(ix+1), dysize*iy);
553  ossimIpt ll(dxsize*ix, dysize*iy);
554  ossimIrect rect(ul, ur, lr, ll);
555
556  m_imageWriter->setFilename(file);
559 }
virtual void setFilename(const ossimFilename &file)
virtual void setAreaOfInterest(const ossimIrect &inputRect)
virtual bool execute()
◆ getClassName()
ossimString ossimKmlSuperOverlayWriter::getClassName ( ) const
virtual
Returns
"ossimKmlSuperOverlayWriter"
Definition at line 69 of file ossimKmlSuperOverlayWriter.cpp.
Referenced by zipWithMinizip().
70 {
71  return ossimString("ossimKmlSuperOverlayWriter");
72 }
◆ getExtension()
ossimString ossimKmlSuperOverlayWriter::getExtension ( ) const
virtual
Parameters
imageTypestring representing image type.
Returns
the 3-letter string extension.
Reimplemented from ossimImageFileWriter.
Definition at line 495 of file ossimKmlSuperOverlayWriter.cpp.
References ossimString::empty(), ossimFilename::ext(), and ossimImageFileWriter::theFilename.
496 {
497  if (!theFilename.empty())
498  {
499  return theFilename.ext();
500  }
501  return ossimString("kml");
502 }
bool empty() const
Definition: ossimString.h:411
ossimString ext() const
◆ getImageTypeList()
void ossimKmlSuperOverlayWriter::getImageTypeList ( std::vector< ossimString > &  imageTypeList) const
virtual
Appends this writer image types to list "imageTypeList".
This writer has type "kml" or "kmz".
Parameters
imageTypeListstl::vector<ossimString> list to append to.
Implements ossimImageFileWriter.
Definition at line 490 of file ossimKmlSuperOverlayWriter.cpp.
References getShortName().
491 {
492  imageTypeList.push_back(getShortName());
493 }
◆ getLongName()
ossimString ossimKmlSuperOverlayWriter::getLongName ( ) const
virtual
Returns
"ossim kmlsuperoverlay writer"
Definition at line 64 of file ossimKmlSuperOverlayWriter.cpp.
65 {
66  return ossimString("ossim kmlsuperoverlay writer");
67 }
◆ getProperty()
ossimRefPtr< ossimProperty > ossimKmlSuperOverlayWriter::getProperty ( const ossimString name) const
virtual
Parameters
nameName of property to return.
Returns
A pointer to a property object which matches "name".
Definition at line 531 of file ossimKmlSuperOverlayWriter.cpp.
References ossimImageFileWriter::getProperty().
533 {
535 }
◆ getPropertyNames()
void ossimKmlSuperOverlayWriter::getPropertyNames ( std::vector< ossimString > &  propertyNames) const
virtual
Parameters
propertyNamesarray to add this's property names to.
Definition at line 537 of file ossimKmlSuperOverlayWriter.cpp.
References ossimImageFileWriter::getPropertyNames().
539 {
541 }
◆ getShortName()
ossimString ossimKmlSuperOverlayWriter::getShortName ( ) const
virtual
Returns
"ossim_kmlsuperoverlay_writer"
Definition at line 59 of file ossimKmlSuperOverlayWriter.cpp.
Referenced by getImageTypeList(), hasImageType(), and ossimKmlSuperOverlayWriter().
60 {
61  return ossimString("ossim_kmlsuperoverlay");
62 }
◆ hasImageType()
bool ossimKmlSuperOverlayWriter::hasImageType ( const ossimString imageType) const
virtual
Parameters
Returns
true if "imageType" is supported by writer.
Definition at line 504 of file ossimKmlSuperOverlayWriter.cpp.
505 {
506  bool result = false;
507  if ( (imageType == getShortName()) ||
508  (imageType == "image/kmlsuperoverlay") )
509  {
510  result = true;
511  }
512  return result;
513 }
◆ isOpen()
bool ossimKmlSuperOverlayWriter::isOpen ( ) const
virtual
Definition at line 448 of file ossimKmlSuperOverlayWriter.cpp.
References ossimString::size(), and ossimImageFileWriter::theFilename.
Referenced by writeFile().
449 {
450  if (theFilename.size() > 0)
451  {
452  return true;
453  }
454  return false;
455 }
std::string::size_type size() const
Definition: ossimString.h:405
◆ loadState()
bool ossimKmlSuperOverlayWriter::loadState ( const ossimKeywordlist kwl,
const char *  prefix = 0
virtual
Definition at line 442 of file ossimKmlSuperOverlayWriter.cpp.
References ossimImageFileWriter::loadState().
444 {
445  return ossimImageFileWriter::loadState(kwl, prefix);
446 }
◆ open()
bool ossimKmlSuperOverlayWriter::open ( )
virtual
Allows a generic interface to open a consumer for writing. If you are a display writer then you would probably show the window or init the device context for writing.
Definition at line 457 of file ossimKmlSuperOverlayWriter.cpp.
458 {
459  bool result = false;
460
461  // Check for empty filenames.
462  if (theFilename.size())
463  {
464  result = true;
465  }
466
467  if (traceDebug())
468  {
470  << "ossimKmlSuperOverlayWriter::open()\n"
471  << "File " << theFilename << (result ? " opened" : " not opened")
472  << std::endl;
473  }
474
475  return result;
476 }
◆ propagateViewChange()
void ossimKmlSuperOverlayWriter::propagateViewChange ( )
protected
This will find all view interfaces, set the view, and send a property event to output so that the combiner, if present, can reinitialize.
Definition at line 923 of file ossimKmlSuperOverlayWriter.cpp.
References ossimConnectableObject::accept(), ossimRefPtr< T >::get(), m_mapProjection, ossimImageFileWriter::theInputConnection, ossimRefPtr< T >::valid(), ossimVisitor::VISIT_CHILDREN, and ossimVisitor::VISIT_INPUTS.
924 {
926  {
927  //---
928  // Send a view interface visitor to the input connection. This will find all view
929  // interfaces, set the view, and send a property event to output so that the combiner,
930  // if present, can reinitialize.
931  //---
936  }
937 }
bool valid() const
Visitor to update view and then propagate property event to outputs.
Definition: ossimVisitor.h:179
ossimRefPtr< ossimImageSourceSequencer > theInputConnection
virtual void accept(ossimVisitor &visitor)
We will add a visitor interface for all connectable objects.
◆ saveState()
bool ossimKmlSuperOverlayWriter::saveState ( ossimKeywordlist kwl,
) const
virtual
Definition at line 436 of file ossimKmlSuperOverlayWriter.cpp.
References ossimImageFileWriter::saveState().
438 {
439  return ossimImageFileWriter::saveState(kwl, prefix);
440 }
◆ setProperty()
void ossimKmlSuperOverlayWriter::setProperty ( ossimRefPtr< ossimProperty property)
virtual
Parameters
propertyObject containing property to set.
Definition at line 515 of file ossimKmlSuperOverlayWriter.cpp.
References ossimString::downcase(), ossimRefPtr< T >::get(), ossimProperty::getName(), m_isPngFormat, and ossimImageFileWriter::setProperty().
516 {
517  if (property.get())
518  {
519  if(property->getName().downcase() == "format")
520  {
521  ossimString format = property->valueToString();
522  if (format.downcase() == "png")
523  {
524  m_isPngFormat = true;
525  }
526  }
528  }
529 }
const ossimString & getName() const
◆ writeFile()
bool ossimKmlSuperOverlayWriter::writeFile ( )
protectedvirtual
Returns
Definition at line 74 of file ossimKmlSuperOverlayWriter.cpp.
References ossimErrorStatusInterface::getErrorStatus(), ossimImageSourceSequencer::isMaster(), isOpen(), open(), ossimErrorCodes::OSSIM_OK, ossimImageSourceSequencer::setAreaOfInterest(), ossimImageSourceSequencer::setToStartOfSequence(), ossimImageSourceSequencer::slaveProcessTiles(), ossimImageWriter::theAreaOfInterest, ossimImageFileWriter::theInputConnection, ossimRefPtr< T >::valid(), and writeStream().
75 {
76  // This method is called from ossimImageFileWriter::execute().
77  bool result = false;
78
79  if( theInputConnection.valid() &&
81  {
84
85  //---
86  // Note only the master process used for writing...
87  //---
89  {
90  if (!isOpen())
91  {
92  open();
93  }
94  if ( isOpen() )
95  {
96  result = writeStream();
97  }
98  }
99  else // Slave process.
100  {
101  // This will return after all tiles for this node have been processed.
103  result = true;
104  }
105  }
106
107  return result;
108 }
static const ossimErrorCode OSSIM_OK
bool valid() const
virtual bool writeStream()
virtual void setAreaOfInterest(const ossimIrect &areaOfInterest)
virtual ossimErrorCode getErrorStatus() const
◆ writeStream()
bool ossimKmlSuperOverlayWriter::writeStream ( )
virtual
Returns
Definition at line 110 of file ossimKmlSuperOverlayWriter.cpp.
111 {
112  static const char MODULE[] = "ossimKmlSuperOverlayWriter::writeStream";
113
114  if (traceDebug())
115  {
117  << MODULE << " entered..." << endl;
118  }
119
121  if (bands != 1 && bands != 3)
122  {
124  << MODULE << " Range Error:"
125  << "\nInvalid number of input bands! Must be one or three."
126  << "\nInput bands = " << bands
127  << "\nReturning from method." << endl;
128
129  return false;
130  }
131
132  if (theFilename.ext().downcase() == "kmz")
133  {
134  m_isKmz = true;
135  }
136
137  ossimString fileExt = ".jpg";
138  ossimString ext = "jpg";
139  if (m_isPngFormat)
140  {
141  fileExt = ".png";
142  ext = "png";
143  }
145  if (!m_imageWriter.valid())
146  {
147  return false;
148  }
149  if (m_isPngFormat)//add alpha channel for png
150  {
151  ossimKeywordlist kwl;
152  kwl.add("add_alpha_channel", "true", true);
153  m_imageWriter->loadState(kwl);
154  }
156
157  ossimString outDir = theFilename.path();
158  if (outDir.empty())
159  outDir = ".";
160
162  {
163  return false;
164  }
165
168
169  ossimGpt ulg;
170  ossimGpt llg;
171  ossimGpt lrg;
172  ossimGpt urg;
173  ossimDpt scale;
175  ossimRefPtr<ossimMapProjection> projDup = 0;
176  if (geom.valid())
177  {
178  geom->localToWorld(theAreaOfInterest.ul(), ulg);
179  geom->localToWorld(theAreaOfInterest.ll(), llg);
180  geom->localToWorld(theAreaOfInterest.lr(), lrg);
181  geom->localToWorld(theAreaOfInterest.ur(), urg);
182
185  if (m_mapProjection.valid())
186  {
187  //make a copy of map projection for lat, lon conversion of the previous zoom in child kml since m_mapProjection set the scale
188  //for the current zoom
190
192  {
193  // Get the scale.
196  }
197  else
198  {
199  // Get the scale.
202  }
203  }
204  else
205  {
206  return false;
207  }
208  }
209  else
210  {
211  return false;
212  }
213
214  //Zoom levels of the pyramid.
215  ossim_int32 maxzoom;
216  ossim_int32 tilexsize;
217  ossim_int32 tileysize;
218  // Let the longer side determine the max zoom level and x/y tilesizes.
219  if ( xsize >= ysize )
220  {
221  ossim_float64 dtilexsize = xsize;
222  while (dtilexsize > 400) //calculate x tile size
223  {
224  dtilexsize = dtilexsize/2;
225  }
226
227  maxzoom = static_cast<ossim_int32>(log( (ossim_float64)xsize / dtilexsize ) / log(2.0));
228  tilexsize = (ossim_int32)dtilexsize;
229  tileysize = (ossim_int32)( (ossim_float64)(dtilexsize * ysize) / xsize );
230  }
231  else
232  {
233  ossim_float64 dtileysize = ysize;
234  while (dtileysize > 400) //calculate y tile size
235  {
236  dtileysize = dtileysize/2;
237  }
238
239  maxzoom = static_cast<ossim_int32>(log( (ossim_float64)ysize / dtileysize ) / log(2.0));
240  tileysize = (ossim_int32)dtileysize;
241  tilexsize = (ossim_int32)( (ossim_float64)(dtileysize * xsize) / ysize );
242  }
243
244  std::vector<ossim_float64> zoomScaleX;
245  std::vector<ossim_float64> zoomScaleY;
246  for (int zoom = 0; zoom < maxzoom + 1; zoom++)
247  {
248  zoomScaleX.push_back(scale.x * pow(2.0, (maxzoom - zoom)));
249  zoomScaleY.push_back(scale.y * pow(2.0, (maxzoom - zoom)));
250  }
251
252  ossimString tmpFileName;
253  std::vector<ossimString> dirVector;
254  std::vector<ossimString> fileVector;
255  bool isKmlGenerated = false;
256  if (m_isKmz)
257  {
258  tmpFileName = ossimString(outDir + "/" + "tmp.kml");
259  isKmlGenerated = generateRootKml(tmpFileName.c_str(), ulg.lat, lrg.lat, lrg.lon, ulg.lon, (ossim_int32)tilexsize);
260  fileVector.push_back(tmpFileName);
261  }
262  else
263  {
264  isKmlGenerated = generateRootKml(theFilename, ulg.lat, lrg.lat, lrg.lon, ulg.lon, (ossim_int32)tilexsize);
265  }
266  if (!isKmlGenerated)
267  {
268  return false;
269  }
270
271  for (ossim_int32 zoom = maxzoom; zoom >= 0; --zoom)
272  {
273  ossim_int32 rmaxxsize = static_cast<ossim_int32>(pow(2.0, (maxzoom-zoom)) * tilexsize);
274  ossim_int32 rmaxysize = static_cast<ossim_int32>(pow(2.0, (maxzoom-zoom)) * tileysize);
275
276  ossim_int32 xloop = (ossim_int32)xsize/rmaxxsize;
277  ossim_int32 yloop = (ossim_int32)ysize/rmaxysize;
278
279  xloop = xloop>0 ? xloop : 1;
280  yloop = yloop>0 ? yloop : 1;
281
282  //set scale for the current zoom
283  if (m_mapProjection.valid())
284  {
286  {
287  m_mapProjection->setDecimalDegreesPerPixel(ossimDpt(zoomScaleX[zoom],zoomScaleY[zoom]));
288  }
289  else
290  {
291  m_mapProjection->setMetersPerPixel(ossimDpt(zoomScaleX[zoom],zoomScaleY[zoom]));
292  }
293  }
294
295  // Set all views and send property event out for combiner if needed.
297
298  //set the scale for the previous zoom in child kml for lat, lon conversion
299  if (zoom < maxzoom)
300  {
301  if (projDup.valid())
302  {
303  if (projDup->isGeographic())
304  {
305  projDup->setDecimalDegreesPerPixel(ossimDpt(zoomScaleX[zoom+1],zoomScaleY[zoom+1]));
306  }
307  else
308  {
309  projDup->setMetersPerPixel(ossimDpt(zoomScaleX[zoom+1],zoomScaleY[zoom+1]));
310  }
311  }
312  }
313
314  for (ossim_int32 ix = 0; ix < xloop; ix++)
315  {
316  ossim_int32 rxsize = (ossim_int32)(rmaxxsize);
317  // ossim_int32 rx = (ossim_int32)(ix * rmaxxsize);
318
319  for (ossim_int32 iy = 0; iy < yloop; iy++)
320  {
321  ossim_int32 rysize = (ossim_int32)(rmaxysize);
322  // ossim_int32 ry = (ossim_int32)(ysize - (iy * rmaxysize)) - rysize;
323
324  ossim_int32 dxsize = (ossim_int32)(rxsize/rmaxxsize * tilexsize);
325  ossim_int32 dysize = (ossim_int32)(rysize/rmaxysize * tileysize);
326
327  std::stringstream zoomStr;
328  std::stringstream ixStr;
329  std::stringstream iyStr;
330
331  zoomStr << zoom;
332  ixStr << ix;
333  iyStr << iy;
334
335  ossimFilename zoomDir = ossimString(outDir + "/" + ossimString(zoomStr.str()));
336  zoomDir.createDirectory();
337
338  zoomDir = ossimString(zoomDir + "/") + ossimString::toString(ix);
339  zoomDir.createDirectory();
340
341  if (m_isKmz)
342  {
343  dirVector.push_back(zoomDir);
344  }
345
346  ossimString filename = ossimString(zoomDir + "/" + ossimString::toString(yloop-iy-1) + fileExt);
347  if (m_isKmz)
348  {
349  fileVector.push_back(filename);
350  }
351
352  generateTile(filename, ix, iy, dxsize, dysize);
353
354  ossimString childKmlfile = ossimString(zoomDir + "/" + ossimString::toString(yloop-iy-1) + ".kml");
355  if (m_isKmz)
356  {
357  fileVector.push_back(childKmlfile);
358  }
359
360  isKmlGenerated = generateChildKml(childKmlfile, zoom, yloop, ix, iy, dxsize, dysize, xsize, ysize, maxzoom, projDup, fileExt);
361  if (!isKmlGenerated)
362  {
363  return false;
364  }
365  }
366  }
367  }
368
369
370  if (m_isKmz)
371  {
372  if (zipWithMinizip(fileVector, outDir, theFilename) == false)
373  {
374  return false;
375  }
376
377  //remove sub-directories and the files under those directories
378  for (ossim_uint32 i = 0; i < dirVector.size(); ++i)
379  {
380  ossimFilename zoomDir = dirVector[i];
381
382  ossimDirectory dir;
383  std::vector<ossimFilename> filesInDir;
384  if(dir.open(zoomDir))
385  {
386  ossimFilename file;
387  //if (dir.getFirst(file, ossimDirectory::OSSIM_DIR_DEFAULT))
389  {
390  filesInDir.push_back(file);
391  }
392  do
393  {
394  filesInDir.push_back(file);
395  }while(dir.getNext(file));
396  }
397
398  for(ossim_uint32 j = 0; j < filesInDir.size(); ++j)
399  {
400  ossimFilename fi = filesInDir[j];
401  if (!fi.empty())
402  {
403  fi.remove();
404  }
405  }
406  if (zoomDir.exists())
407  {
408  ossimString cmd = "rmdir \"";
409  cmd += zoomDir + "\"";
410  std::system(cmd.c_str());
411  }
412  }
413
414  //remove the top directories
415  for (int zoom = maxzoom; zoom >= 0; --zoom)
416  {
417  std::stringstream zoomStr;
418  zoomStr << zoom;
419  ossimFilename zoomZipDir = ossimString(outDir + "/" + ossimString(zoomStr.str()));
420  if (zoomZipDir.exists())
421  {
422  ossimString cmd = "rmdir \"";
423  cmd += zoomZipDir + "\"";
424  std::system(cmd.c_str());
425  }
426  }
427  if (ossimFilename(tmpFileName).exists())
428  {
429  ossimFilename(tmpFileName).remove();
430  }
431  }
432
433  return true;
434 }
virtual const ossimDpt & getDecimalDegreesPerPixel() const
Returns decimal degrees per pixel as an ossimDpt with "x" representing longitude and "y" representing...
ossimImageFileWriter * createWriterFromExtension(const ossimString &fileExtension) const
virtual ossimObject * dup() const =0
static bool remove(const ossimFilename &pathname)
Removes pathname from filesystem if supported by platform.
std::basic_stringstream< char > stringstream
Class for char mixed input and output memory streams.
Definition: ossimIosFwd.h:38
void generateTile(ossimString filename, ossim_int32 ix, ossim_int32 iy, ossim_int32 dxsize, ossim_int32 dysize)
bool valid() const
bool getFirst(ossimFilename &filename, int flags=OSSIM_DIR_DEFAULT)
double y
Definition: ossimDpt.h:165
ossim_uint32 height() const
Definition: ossimIrect.h:487
static ossimImageWriterFactoryRegistry * instance()
Numeric to string methods.
virtual bool isGeographic() const
const ossimIpt & ul() const
Definition: ossimIrect.h:274
virtual void setDecimalDegreesPerPixel(const ossimDpt &gsd)
const ossimIpt & ll() const
Definition: ossimIrect.h:277
bool getNext(ossimFilename &filename) const
virtual void setMetersPerPixel(const ossimDpt &gsd)
void push_back(char c)
Equivalent to insert(end(), c).
Definition: ossimString.h:905
bool zipWithMinizip(std::vector< ossimString > srcFiles, ossimString srcDirectory, ossimString targetFile)
bool exists() const
ossim_float64 lon
bool localToWorld(const ossimDpt &local_pt, ossimGpt &world_pt) const
Exposes the 3D projection from image to world coordinates.
#define PTR_CAST(T, p)
Definition: ossimRtti.h:321
const ossimIpt & lr() const
Definition: ossimIrect.h:276
virtual ossim_int32 connectMyInputTo(ossimConnectableObject *inputObject, bool makeOutputConnection=true, bool createEventFlag=true)
Will try to connect this objects input to the passed in object.
ossim_uint32 width() const
Definition: ossimIrect.h:500
bool generateChildKml(ossimString filename, ossim_int32 zoom, ossim_int32 yloop, ossim_int32 ix, ossim_int32 iy, ossim_int32 dxsize, ossim_int32 dysize, ossim_int32 xsize, ossim_int32 ysize, ossim_int32 maxzoom, ossimRefPtr< ossimMapProjection > proj, ossimString fileExt)
virtual ossimRefPtr< ossimImageGeometry > getImageGeometry()
Returns the image geometry object associated with this tile source or NULL if not defined...
const ossimIpt & ur() const
Definition: ossimIrect.h:275
bool open(const ossimFilename &dir)
double x
Definition: ossimDpt.h:164
bool empty() const
bool hasNans() const
Definition: ossimIrect.h:337
ossim_float64 lat
virtual ossimDpt getMetersPerPixel() const
bool generateRootKml(ossimString filename, ossim_float64 north, ossim_float64 south, ossim_float64 east, ossim_float64 west, ossim_int32 tilesize)
bool createDirectory(bool recurseFlag=true, int perm=0775) const
ossimFilename path() const
void propagateViewChange()
int ossim_int32
◆ zipWithMinizip()
bool ossimKmlSuperOverlayWriter::zipWithMinizip ( std::vector< ossimString srcFiles,
protected
Definition at line 825 of file ossimKmlSuperOverlayWriter.cpp.
References ossimString::c_str(), ossimString::find(), getClassName(), ossimErrorCodes::OSSIM_ERROR, ossimSetError(), ossimString::size(), and ossimString::string().
826 {
827  zipFile zipfile = zipOpen(targetFile.c_str(), 0);
828  if (!zipfile)
829  {
832  "Unable to open target zip file..");
833  return false;
834  }
835
836  std::vector<ossimString>::iterator v1_Iter;
837  for(v1_Iter = srcFiles.begin(); v1_Iter != srcFiles.end(); v1_Iter++)
838  {
839  ossimString fileRead = *v1_Iter;
840
841  // Find relative path and open new file with zip file
842  std::string relativeFileReadPath = fileRead;
843  ossim_int32 remNumChars = srcDirectory.size();
844  if(remNumChars > 0)
845  {
846  ossim_int32 f = fileRead.find(srcDirectory.string());
847  if( f >= 0 )
848  {
849  relativeFileReadPath.erase(f, remNumChars + 1); // 1 added for backslash at the end
850  }
851  }
852
853  std::basic_string<char>::iterator iter1;
854  for (iter1 = relativeFileReadPath.begin(); iter1 != relativeFileReadPath.end(); iter1++)
855  {
856  int f = relativeFileReadPath.find("\\");
857  if (f >= 0)
858  {
859  relativeFileReadPath.replace(f, 1, "/");
860  }
861  else
862  {
863  break;
864  }
865  }
866  if (zipOpenNewFileInZip(zipfile, relativeFileReadPath.c_str(), 0, 0, 0, 0, 0, 0, Z_DEFLATED, Z_DEFAULT_COMPRESSION) != ZIP_OK)
867  {
870  "Unable to create file within the zip file..");
871  return false;
872  }
873
874  // Read source file and write to zip file
875  std::fstream inFile (fileRead.c_str(), std::ios::binary | std::ios::in);
876  if (!inFile.is_open())
877  {
880  "Could not open source file..");
881  return false;
882  }
883  if (!inFile.good())
884  {
887  "Error reading source file..");
888  return false;
889  }
890
891  // Read file in buffer
892  std::string fileData;
893  const unsigned int bufSize = 1024;
894  char buf[bufSize];
895  do
896  {
897  inFile.read(buf, bufSize);
898  fileData.append(buf, inFile.gcount());
899  } while (!inFile.eof() && inFile.good());
900
901  if (zipWriteInFileInZip(zipfile, static_cast<const void*>(fileData.data()), static_cast<unsigned int>(fileData.size())) != ZIP_OK )
902  {
905  "Could not write to file within zip file..");
906  return false;
907  }
908
909  // Close one src file zipped completely
910  if ( zipCloseFileInZip(zipfile) != ZIP_OK )
911  {
914  "Could not close file written within zip file..");
915  return false;
916  }
917  }
918
919  zipClose(zipfile, 0);
920  return true;
921 }
OSSIMDLLEXPORT void ossimSetError(const char *className, ossim_int32 error, const char *fmtString=0,...)
std::basic_fstream< char > fstream
Class for char mixed input and output file streams.
Definition: ossimIosFwd.h:50
static const ossimErrorCode OSSIM_ERROR
virtual ossimString getClassName() const
std::string::size_type find(const std::string &s, std::string::size_type pos=0) const
Searches for s as a substring of *this, beginning at character pos of *this.
Definition: ossimString.h:753
int ossim_int32
const std::string & string() const
Definition: ossimString.h:414
Member Data Documentation
◆ m_imageWriter
ossimRefPtr<ossimImageFileWriter> ossimKmlSuperOverlayWriter::m_imageWriter
protected
Definition at line 166 of file ossimKmlSuperOverlayWriter.h.
Referenced by close(), and generateTile().
◆ m_isKmz
bool ossimKmlSuperOverlayWriter::m_isKmz
protected
Definition at line 168 of file ossimKmlSuperOverlayWriter.h.
◆ m_isPngFormat
bool ossimKmlSuperOverlayWriter::m_isPngFormat
protected
Definition at line 169 of file ossimKmlSuperOverlayWriter.h.
Referenced by setProperty().
◆ m_mapProjection
ossimRefPtr<ossimMapProjection> ossimKmlSuperOverlayWriter::m_mapProjection
protected
Definition at line 167 of file ossimKmlSuperOverlayWriter.h.
Referenced by close(), generateChildKml(), and propagateViewChange().
