ossimNitf20Writer Class Reference
#include <ossimNitf20Writer.h>
Inheritance diagram for ossimNitf20Writer:
ossimNitfWriterBase ossimImageFileWriter ossimImageWriter ossimProcessInterface ossimConnectableObjectListener ossimOutputSource ossimListener ossimSource ossimConnectableObject ossimErrorStatusInterface ossimObject ossimListenerManager ossimPropertyInterface ossimReferenced
Public Member Functions
 ossimNitf20Writer (const ossimFilename &filename=ossimFilename(""), ossimImageSource *inputSource=(ossimImageSource *) NULL)
virtual ~ossimNitf20Writer ()
virtual bool isOpen () const
virtual bool open ()
virtual void close ()
virtual void getImageTypeList (std::vector< ossimString > &imageTypeList) const
 void getImageTypeList(std::vector<ossimString>& imageTypeList)const More...
 Set the properties. More...
 Gets a property. More...
void addRegisteredTag (ossimRefPtr< ossimNitfRegisteredTag > registeredTag)
 Saves the state of the writer to kwl with prefix then calls base class ossimImageFileWriter::saveState. More...
 Initializes the state of the writer from kwl with prefix then calls base class ossimImageFileWriter::loadState. More...
- Public Member Functions inherited from ossimNitfWriterBase
 ossimNitfWriterBase ()
 default constructor More...
 ossimNitfWriterBase (const ossimFilename &filename, ossimImageSource *inputSource)
 Constructor that takes filename and input source. More...
virtual ~ossimNitfWriterBase ()
virtual ossimString getExtension () const
 Returns a 3-letter extension from the image type descriptor (theOutputImageType) that can be used for image file extensions. More...
virtual void addRegisteredTag (ossimRefPtr< ossimNitfRegisteredTag > registeredTag, bool unique)
virtual void addRegisteredTag (ossimRefPtr< ossimNitfRegisteredTag > registeredTag, bool unique, const ossim_uint32 &ownerIndex, const ossimString &tagType)
virtual void setFileHeaderV2_1 (ossimRefPtr< ossimNitfFileHeaderV2_1 >, bool preferSource=false)
virtual void setImageHeaderV2_1 (ossimRefPtr< ossimNitfImageHeaderV2_1 >, bool preferSource=false)
- Public Member Functions inherited from ossimImageFileWriter
 ossimImageFileWriter (const ossimFilename &filename=ossimFilename(), ossimImageSource *inputSource=0, ossimObject *owner=0)
 The writer will own the sequencer. More...
virtual ~ossimImageFileWriter ()
virtual bool getOutputHasInternalOverviews (void) const
 Examples of writers that always generate internal overviews are ossim_kakadu_jp2 and ossim_kakadu_nitf_j2k. More...
virtual bool hasImageType (const ossimString &imageType) const
 bool hasImageType(const ossimString& imageType) const More...
virtual void setTileSize (const ossimIpt &tileSize)
 Sets the output image tiling size if supported by the writer. More...
virtual bool writeEnviHeaderFile ()
 Will write an envi header file. More...
virtual bool writeErsHeaderFile ()
 Will write an ER Mapper header file. More...
virtual bool writeExternalGeometryFile ()
 Will write an external geometry file. More...
virtual bool writeFgdcFile ()
 Will write an fgdc file. More...
virtual bool writeHistogramFile ()
 Returns true on success, false on error. More...
virtual bool writeJpegWorldFile ()
 Will write a jpeg world file. More...
virtual bool writeOverviewFile (ossim_uint16 tiff_compress_type=1, ossim_int32 jpeg_compress_quality=75, bool includeR0=false)
 Write out an ossim overview file from the source_file. More...
virtual bool writeReadmeFile ()
 Will write a readme file. More...
virtual bool writeTiffWorldFile ()
 Will write a world file. More...
virtual bool writeWorldFile ()
virtual bool writeMetaDataFiles ()
 Convenience method that calls meta data write methods that are flagged to be called. More...
virtual void setAreaOfInterest (const ossimIrect &inputRect)
virtual void changeSequencer (ossimImageSourceSequencer *sequencer)
 Sets the sequencer and connects it to the input of this. More...
virtual ossimImageSourceSequencergetSequencer ()
virtual void initialize ()
 Initialize method. More...
virtual bool execute ()
 Calls: writeFile() writeMetaDataFiles() More...
virtual bool writeStream ()
 Method to write the image to a stream. More...
virtual bool setOutputStream (ossimRefPtr< ossimOStream > stream)
 Sets the output stream to write to. More...
virtual bool setOutputStream (std::ostream &str)
 tmp drb More...
virtual ossimRefPtr< ossimOStreamgetOutputStream () const
 Method to return the stream attached to output. More...
virtual void setOutputImageType (ossim_int32 type)
virtual void setOutputImageType (const ossimString &type)
virtual ossim_int32 getOutputImageType () const
virtual ossimString getOutputImageTypeString () const
virtual void setOutputName (const ossimString &outputName)
virtual void setFilename (const ossimFilename &file)
virtual bool canConnectMyInputTo (ossim_int32 inputIndex, const ossimConnectableObject *object) const
virtual bool getWriteImageFlag () const
 Control flags... More...
virtual bool getWriteHistogramFlag () const
virtual bool getWriteOverviewFlag () const
virtual bool getScaleToEightBitFlag () const
virtual bool getWriteEnviHeaderFlag () const
virtual bool getWriteErsHeaderFlag () const
virtual bool getWriteExternalGeometryFlag () const
virtual bool getWriteFgdcFlag () const
virtual bool getWriteJpegWorldFileFlag () const
virtual bool getWriteReadmeFlag () const
virtual bool getWriteTiffWorldFileFlag () const
virtual bool getWriteWorldFileFlag () const
virtual void setWriteImageFlag (bool flag)
virtual void setWriteOverviewFlag (bool flag)
virtual void setWriteHistogramFlag (bool flag)
virtual void setScaleToEightBitFlag (bool flag)
virtual void setWriteEnviHeaderFlag (bool flag)
virtual void setWriteErsHeaderFlag (bool flag)
virtual void setWriteExternalGeometryFlag (bool flag)
virtual void setWriteFgdcFlag (bool flag)
virtual void setWriteJpegWorldFile (bool flag)
virtual void setWriteReadme (bool flag)
virtual void setWriteTiffWorldFile (bool flag)
virtual void setWriteWorldFile (bool flag)
virtual ossim_uint16 getOverviewCompressType () const
virtual ossim_int32 getOverviewJpegCompressQuality () const
virtual void setOverviewCompressType (ossim_uint16 type)
virtual void setOverviewJpegCompressQuality (ossim_int32 quality)
 Overrides base "addListener" this will capture the pointer and then call the base class "addListener". More...
 Overrides base "removeListener". More...
virtual void setPixelType (ossimPixelType type)
 If "point" the coordinate tie points are relative to the center of the pixel. More...
virtual void setPixelType (const ossimString &type)
virtual ossimPixelType getPixelType () const
virtual void getPixelTypeString (ossimString &type) const
- Public Member Functions inherited from ossimImageWriter
 ossimImageWriter (ossimObject *owner=NULL)
 ossimImageWriter (ossimObject *owner, ossim_uint32 numberOfInputs, ossim_uint32 numberOfOutputs, bool inputListIsFixed, bool outputListIsFixed)
virtual ~ossimImageWriter ()
virtual bool setViewingRect (const ossimIrect &aRect)
virtual ossimIrect getAreaOfInterest () const
- Public Member Functions inherited from ossimOutputSource
 ossimOutputSource (ossimObject *owner=NULL)
 ossimOutputSource (ossimObject *owner, ossim_uint32 inputListSize, ossim_uint32 outputListSize, bool inputListIsFixedFlag=true, bool outputListIsFixedFlag=true)
virtual ~ossimOutputSource ()
virtual bool open (const ossimString &outputName)
virtual const ossimStringgetOutputName ()
virtual ~ossimSource ()
virtual void enableSource ()
virtual void disableSource ()
const ossimIdgetId () const
 ossimObject ()
virtual ~ossimObject ()
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
 ossimListenerManager ()
 ossimPropertyInterface ()
 ossimErrorStatusInterface ()
bool hasError () const
- Public Member Functions inherited from ossimProcessInterface
 ossimProcessInterface ()
virtual void abort ()
bool needsAborting () const
bool isAborted () const
bool isExecuting () const
void enableEvents ()
void disableEvents ()
 ProcessEvent. More...
virtual void refreshEvent (ossimRefreshEvent &)
 ossimListener ()
virtual ~ossimListener ()
void enableListener ()
void disableListener ()
Protected Member Functions
virtual bool writeFile ()
virtual bool writeBlockBandSeparate ()
 write out block band separate More...
virtual bool writeBlockBandSequential ()
 Outputs in band sequential format. More...
void addTags ()
- Protected Member Functions inherited from ossimNitfWriterBase
void writeGeometry (ossimNitfImageHeaderV2_X *hdr, ossimImageSourceSequencer *seq)
 Populates tags with geometry info from projection. More...
void addBlockaTag (ossimMapProjectionInfo &mapInfo, ossimNitfImageHeaderV2_X *hdr)
 Adds the BLOCKA tag. More...
void addGeolobTag (const ossimMapProjection *mapProj, ossimNitfImageHeaderV2_X *hdr)
 Adds the GEOLOB tag. More...
void addRpcbTag (const ossimIrect &rect, ossimProjection *proj, ossimNitfImageHeaderV2_X *hdr)
 Adds the RPC00B tag. More...
void setComplexityLevel (std::streamoff, ossimNitfFileHeaderV2_X *hdr)
 Sets the complexity level of theFileHeader. More...
void setComplexityLevel (ossimNitfFileHeaderV2_X *hdr, ossim_uint64 width=0, ossim_uint64 height=0)
virtual void initializeDefaultsFromConfigFile (ossimNitfFileHeaderV2_X *fileHdr, ossimNitfImageHeaderV2_X *imgHdr)
 Sets file header and image header defaults from config file if found in preferences. More...
- Protected Member Functions inherited from ossimImageFileWriter
bool writeWorldFile (const ossimFilename &file)
 Common world file writer method. More...
virtual ~ossimReferenced ()
Protected Attributes
std::ofstream * theOutputStream
ossimRefPtr< ossimNitfFileHeaderV2_0theFileHeader
ossimRefPtr< ossimNitfImageHeaderV2_0theImageHeader
bool theEnableRpcbTagFlag
 If true user wants to set RPC00B tag. More...
bool theEnableBlockaTagFlag
 If true user wants to set BLOCKA tag. More...
bool theCopyFieldsFlag
 If true this will enable searching the input connnection for another NITF handler and bring the fields to this writers output fields and will maintin as many field values as possible. More...
- Protected Attributes inherited from ossimNitfWriterBase
bool theEnableGeolobTagFlag
 If true user wants to set GEOLOG tag. More...
- Protected Attributes inherited from ossimImageFileWriter
ossimRefPtr< ossimImageSourceSequencertheInputConnection
ossimRefPtr< ossimViewControllertheViewController
ossimListenertheProgressListener
ossimFilename theFilename
ossimString theOutputImageType
bool theWriteImageFlag
bool theWriteOverviewFlag
bool theWriteHistogramFlag
bool theScaleToEightBitFlag
ossim_uint16 theOverviewCompressType
ossim_int32 theOverviewJpegCompressQuality
bool theWriteEnviHeaderFlag
 External meta data writer flags. More...
bool theWriteErsHeaderFlag
bool theWriteExternalGeometryFlag
bool theWriteFgdcFlag
bool theWriteJpegWorldFileFlag
bool theWriteReadmeFlag
bool theWriteTiffWorldFileFlag
bool theWriteWorldFileFlag
bool theAutoCreateDirectoryFlag
ossimUnitType theLinearUnits
 If not a geographic projection this allows the user to set the linear units of the output tag to be: More...
ossimPixelType thePixelType
 OSSIM_PIXEL_IS_POINT = 0, OSSIM_PIXEL_IS_AREA = 1. More...
- Protected Attributes inherited from ossimImageWriter
ossimIrect theAreaOfInterest
- Protected Attributes inherited from ossimOutputSource
ossimString theOutputName
bool theEnableFlag
bool theInitializedFlag
ossimId theId
ossimString theDescription
ossimObjecttheOwner
bool theInputListIsFixedFlag
bool theOutputListIsFixedFlag
bool theEnabledFlag
bool theFireEventFlag
ossimErrorCode theErrorStatus
- Protected Attributes inherited from ossimProcessInterface
double thePercentComplete
ossimString theMessage
bool theEventFlag
bool theListenerEnableFlag
Additional Inherited Members
- Public Types inherited from ossimProcessInterface
enum  ossimProcessStatus {
Detailed Description
Definition at line 26 of file ossimNitf20Writer.h.
◆ ossimNitf20Writer()
ossimNitf20Writer::ossimNitf20Writer ( const ossimFilename filename = ossimFilename(""),
ossimImageSource inputSource = (ossimImageSource*)NULL
Definition at line 51 of file ossimNitf20Writer.cpp.
References ossimRefPtr< T >::get(), ossimNitfWriterBase::initializeDefaultsFromConfigFile(), ossimNitfFileHeaderV2_X::setEncryption(), ossimNitfImageHeaderV2_X::setJustification(), ossimImageFileWriter::setWriteExternalGeometryFlag(), theFileHeader, theImageHeader, and ossimImageFileWriter::theOutputImageType.
53  : ossimNitfWriterBase(filename, inputSource),
54  theOutputStream(0),
55  theFileHeader(),
57  theEnableRpcbTagFlag(false),
59  theCopyFieldsFlag(false)
60 {
61  //---
62  // Since the internal nitf tags are not very accurate, write an external
63  // geometry out as default behavior. Users can disable this via the
64  // property interface or keyword list.
65  //---
67
70  theOutputImageType = "nitf20_block_band_separate";
71
72  // These are always set:
75
76  // Set any site defaults.
78  dynamic_cast<ossimNitfFileHeaderV2_X*>(theFileHeader.get()),
79  dynamic_cast<ossimNitfImageHeaderV2_X*>(theImageHeader.get()) );
80 }
ossimNitfWriterBase()
default constructor
If true this will enable searching the input connnection for another NITF handler and bring the field...
ossimRefPtr< ossimNitfFileHeaderV2_0 > theFileHeader
void setEncryption(const ossimString &encryption)
virtual void initializeDefaultsFromConfigFile(ossimNitfFileHeaderV2_X *fileHdr, ossimNitfImageHeaderV2_X *imgHdr)
virtual void setWriteExternalGeometryFlag(bool flag)
ossimRefPtr< ossimNitfImageHeaderV2_0 > theImageHeader
void setJustification(const ossimString &value)
◆ ~ossimNitf20Writer()
ossimNitf20Writer::~ossimNitf20Writer ( )
virtual
Definition at line 82 of file ossimNitf20Writer.cpp.
References close(), theFileHeader, and theImageHeader.
83 {
84  //---
85  // This looks like a leak but it's not as both of these are ossimRefPtr's.
86  //---
87  theFileHeader=0;
89
90  close();
91 }
Member Function Documentation
◆ addRegisteredTag()
void ossimNitf20Writer::addRegisteredTag ( ossimRefPtr< ossimNitfRegisteredTag registeredTag)
virtual
Reimplemented from ossimNitfWriterBase.
Definition at line 624 of file ossimNitf20Writer.cpp.
References ossimNitfImageHeader::addTag(), ossimRefPtr< T >::get(), ossimNitfTagInformation::setTagData(), and theImageHeader.
626 {
627  ossimNitfTagInformation tagInfo;
628  tagInfo.setTagData(registeredTag.get());
629  theImageHeader->addTag(tagInfo);
630 }
virtual void addTag(const ossimNitfTagInformation &tag, bool unique=true)
void setTagData(ossimRefPtr< ossimNitfRegisteredTag > tagData)
◆ addTags()
void ossimNitf20Writer::addTags ( )
protected
Definition at line 632 of file ossimNitf20Writer.cpp.
References ossimConnectableObject::accept(), ossimNitfFileHeader::addTag(), ossimString::begin(), ossimString::contains(), ossimRefPtr< T >::get(), ossimNitfTileSource::getCurrentImageHeader(), ossimNitfTileSource::getFileHeader(), ossimNitfFileHeader::getNumberOfTags(), ossimCollectionVisitor::getObjectAs(), ossimCollectionVisitor::getObjects(), ossimPropertyInterface::getPropertyValueAsString(), ossimNitfFileHeader::getTagInformation(), min, ossimNitfFileHeaderV2_X::setDate(), ossimPropertyInterface::setProperty(), ossimString::size(), theCopyFieldsFlag, theFileHeader, theImageHeader, ossimRefPtr< T >::valid(), ossimVisitor::VISIT_CHILDREN, and ossimVisitor::VISIT_INPUTS.
633 {
634  ossimDate currentDate;
635  theFileHeader->setDate(currentDate);
636
638  {
639  ossimTypeNameVisitor visitor(ossimString("ossimNitfTileSource"),
640  true,
642  accept(visitor);
643
644  // If there are multiple image handlers, e.g. a mosaic do not uses.
646  if ( visitor.getObjects().size() == 1 )
647  {
648  nitf = visitor.getObjectAs<ossimNitfTileSource>( 0 );
649  }
650
651  if( nitf.valid() )
652  {
653  ossimString value;
654  ossimPropertyInterface* fileHeaderProperties = dynamic_cast<ossimPropertyInterface*>(theFileHeader.get());
655  ossimPropertyInterface* imageHeaderProperties = dynamic_cast<ossimPropertyInterface*>(theImageHeader.get());
656  bool nitf21Flag = false;
657  const ossimNitfFileHeader* header = nitf->getFileHeader();
658  const ossimNitfImageHeader* imageHeader = nitf->getCurrentImageHeader();
659  if(header)
660  {
661  ossimString version = header->getPropertyValueAsString("fhdr");
662  nitf21Flag = version.contains("2.1");
663  value = header->getPropertyValueAsString("stype");
664  if(value.size())
665  {
666  fileHeaderProperties->setProperty("stype", value);
667  }
668  value = header->getPropertyValueAsString("ostaid");
669  if(value.size())
670  {
671  fileHeaderProperties->setProperty("ostaid", value);
672  }
673  value = header->getPropertyValueAsString("ftitle");
674  if(value.size())
675  {
676  fileHeaderProperties->setProperty("ftitle", value);
677  }
678  value = header->getPropertyValueAsString("fsclas");
679  if(value.size())
680  {
681  fileHeaderProperties->setProperty("fsclas", value);
682  }
683  value = header->getPropertyValueAsString("oname");
684  if(value.size())
685  {
686  fileHeaderProperties->setProperty("oname", value);
687  }
688  value = header->getPropertyValueAsString("ophone");
689  if(value.size())
690  {
691  fileHeaderProperties->setProperty("ophone", value);
692  }
693  int idx = 0;
694  for(idx = 0; idx < header->getNumberOfTags(); ++idx)
695  {
697  header->getTagInformation(info,
698  idx);
699  theFileHeader->addTag(info);
700  }
701  value = header->getPropertyValueAsString("");
702  if(value.size())
703  {
704  fileHeaderProperties->setProperty("", value);
705  }
706  value = header->getPropertyValueAsString("fdt");
707  if(value.size()==14)
708  {
709  if(nitf21Flag)
710  {
711  ossimString year(value.begin()+2, value.begin()+4);
712  ossimString mon(value.begin()+4, value.begin()+6);
713  ossimString day(value.begin()+6, value.begin()+8);
714  ossimString hour(value.begin()+8, value.begin()+10);
715  ossimString min(value.begin()+10, value.begin()+12);
716  ossimString sec(value.begin()+12, value.begin()+14);
717  if(mon.toUInt32() < 13)
718  {
719  mon = monthConversionTable[mon.toUInt32()];
720  }
721  fileHeaderProperties->setProperty("fdt", day+hour+min+sec+"Z"+mon+year);
722  }
723  else
724  {
725  fileHeaderProperties->setProperty("fdt", value);
726  }
727  }
728  }
729  if(imageHeader)
730  {
731  ossim_uint32 idx = 0;
732  for(idx = 0; idx < imageHeader->getNumberOfTags(); ++idx)
733  {
735  imageHeader->getTagInformation(info,
736  idx);
737  theImageHeader->addTag(info);
738  }
739  value = imageHeader->getPropertyValueAsString("tgtid");
740  if(value.size())
741  {
742  imageHeaderProperties->setProperty("tgtid", value);
743  }
744  value = imageHeader->getPropertyValueAsString("isclas");
745  if(value.size())
746  {
747  imageHeaderProperties->setProperty("isclas", value);
748  }
749  value = imageHeader->getPropertyValueAsString("igeolo");
750  if(value.size())
751  {
752  imageHeaderProperties->setProperty("igeolo", value);
753  }
754  value = imageHeader->getPropertyValueAsString("ititle");
755  if(nitf21Flag)
756  {
757  value = imageHeader->getPropertyValueAsString("iid2");
758  }
759  if(value.size())
760  {
761  imageHeaderProperties->setProperty("ititle", value);
762  }
763  if(!nitf21Flag)
764  {
765  value = imageHeader->getPropertyValueAsString("iscaut");
766  if(value.size())
767  {
768  imageHeaderProperties->setProperty("iscaut", value);
769  }
770  value = imageHeader->getPropertyValueAsString("iscode");
771  if(value.size())
772  {
773  imageHeaderProperties->setProperty("iscode", value);
774  }
775  value = imageHeader->getPropertyValueAsString("isctlh");
776  if(value.size())
777  {
778  imageHeaderProperties->setProperty("isctlh", value);
779  }
780  value = imageHeader->getPropertyValueAsString("isrel");
781  if(value.size())
782  {
783  imageHeaderProperties->setProperty("isrel", value);
784  }
785  value = imageHeader->getPropertyValueAsString("isctln");
786  if(value.size())
787  {
788  imageHeaderProperties->setProperty("isctln", value);
789  }
790  value = imageHeader->getPropertyValueAsString("isdwng");
791  if(value.size())
792  {
793  imageHeaderProperties->setProperty("isdevt", value);
794  }
795  value = imageHeader->getPropertyValueAsString("isorce");
796  if(value.size())
797  {
798  imageHeaderProperties->setProperty("isorce", value);
799  }
800  }
801  value = imageHeader->getPropertyValueAsString("idatim");
802  if(value.size()==14)
803  {
804  if(nitf21Flag)
805  {
806  ossimString year(value.begin()+2, value.begin()+4);
807  ossimString mon(value.begin()+4, value.begin()+6);
808  ossimString day(value.begin()+6, value.begin()+8);
809  ossimString hour(value.begin()+8, value.begin()+10);
810  ossimString min(value.begin()+10, value.begin()+12);
811  ossimString sec(value.begin()+12, value.begin()+14);
812  if(mon.toUInt32() < 13)
813  {
814  mon = monthConversionTable[mon.toUInt32()];
815  }
816  imageHeaderProperties->setProperty("idatim", day+hour+min+sec+"Z"+mon+year);
817  }
818  else
819  {
820  imageHeaderProperties->setProperty("idatim", value);
821  }
822  }
823  }
824
825  // we will port over only a selected few
826  }
827  }
828 }
void setDate(const ossimLocalTm &d)
Sets field FDT.
bool valid() const
Definition: ossimRefPtr.h:75
bool contains(char aChar) const
Definition: ossimString.h:58
virtual ossim_uint32 getNumberOfTags() const
virtual bool getTagInformation(ossimNitfTagInformation &tag, int idx) const
std::string::size_type size() const
Definition: ossimString.h:405
std::string::iterator begin()
Definition: ossimString.h:420
unsigned int ossim_uint32
const ossimNitfImageHeader * getCurrentImageHeader() const
const ossimNitfFileHeader * getFileHeader() const
virtual bool getTagInformation(ossimNitfTagInformation &tagInfo, ossim_uint32 idx) const
virtual void setProperty(const ossimString &name, const ossimString &value)
virtual void accept(ossimVisitor &visitor)
We will add a visitor interface for all connectable objects.
virtual int getNumberOfTags() const
virtual ossimString getPropertyValueAsString(const ossimString &name) const
#define min(a, b)
Definition: auxiliary.h:75
◆ close()
void ossimNitf20Writer::close ( )
virtual
Generic interface to allow one to close a consumer. For displays this might minimize the window and free up internal pointers for file writers it will make sure the file stream is closed and flushed.
Implements ossimOutputSource.
Definition at line 110 of file ossimNitf20Writer.cpp.
References theOutputStream.
Referenced by open(), and ~ossimNitf20Writer().
111 {
112  if(theOutputStream)
113  {
114  theOutputStream->close();
115  delete theOutputStream;
117  }
118 }
std::basic_ofstream< char > ofstream
Class for char output file streams.
Definition: ossimIosFwd.h:47
◆ getImageTypeList()
void ossimNitf20Writer::getImageTypeList ( std::vector< ossimString > &  imageTypeList) const
virtual
Appends this writer image types to list "imageTypeList".
This writer has the following types: nitf_block_band_separate nitf_block_band_sequential
Parameters
imageTypeListstl::vector<ossimString> list to append to.
Implements ossimImageFileWriter.
Definition at line 165 of file ossimNitf20Writer.cpp.
166 {
167  imageTypeList.push_back(ossimString("nitf20_block_band_separate"));
168  imageTypeList.push_back(ossimString("nitf20_block_band_sequential"));
169 }
◆ getProperty()
ossimRefPtr< ossimProperty > ossimNitf20Writer::getProperty ( const ossimString name) const
virtual
Gets a property.
Parameters
Thename of the property to get.
Returns
The property if found.
Definition at line 220 of file ossimNitf20Writer.cpp.
References ossimContainerProperty::addChildren(), ossimImageFileWriter::getProperty(), ossimPropertyInterface::getPropertyList(), theCopyFieldsFlag, theEnableBlockaTagFlag, theEnableRpcbTagFlag, theFileHeader, and theImageHeader.
221 {
222  ossimRefPtr<ossimProperty> result = 0;
223
224  if(name == "file_header")
225  {
226  ossimContainerProperty* container = new ossimContainerProperty(name);
227  std::vector<ossimRefPtr<ossimProperty> > propertyList;
228
229  theFileHeader->getPropertyList(propertyList);
230  container->addChildren(propertyList);
231
232  result = container;
233  }
234  else if(name == "image_header")
235  {
236  ossimContainerProperty* container = new ossimContainerProperty(name);
237  std::vector<ossimRefPtr<ossimProperty> > propertyList;
238
239  theImageHeader->getPropertyList(propertyList);
240  container->addChildren(propertyList);
241
242  result = container;
243  }
244  else if(name == "enable_rpcb_tag")
245  {
246  ossimBooleanProperty* boolProperty =
248
249  result = boolProperty;
250  }
251  else if(name == "enable_blocka_tag")
252  {
253  ossimBooleanProperty* boolProperty =
255
256  result = boolProperty;
257  }
258  else if(name == "copy_fields_flag")
259  {
260  ossimBooleanProperty* boolProperty =
262
263  result = boolProperty;
264  }
265  else
266  {
268  }
269
270  return result;
271 }
void getPropertyList(std::vector< ossimRefPtr< ossimProperty > > &propertyList) const
virtual void addChildren(std::vector< ossimRefPtr< ossimProperty > > &propertyList)
◆ getPropertyNames()
void ossimNitf20Writer::getPropertyNames ( std::vector< ossimString > &  propertyNames) const
virtual
Parameters
propertyNamesArray to populate with property names.
Note
The following names are handled: file_header image_header
Definition at line 273 of file ossimNitf20Writer.cpp.
References ossimImageFileWriter::getPropertyNames().
274 {
276
277  propertyNames.push_back("file_header");
278  propertyNames.push_back("image_header");
279  propertyNames.push_back("enable_rpcb_tag");
280  propertyNames.push_back("enable_blocka_tag");
281  propertyNames.push_back("copy_fields_flag");
282 }
◆ isOpen()
bool ossimNitf20Writer::isOpen ( ) const
virtual
Definition at line 93 of file ossimNitf20Writer.cpp.
Referenced by open(), and writeFile().
94 {
95  return (theOutputStream != 0);
96 }
◆ loadState()
bool ossimNitf20Writer::loadState ( const ossimKeywordlist kwl,
const char *  prefix = 0
virtual
Parameters
kwlKeyword list to initialize from.
prefixUsually something like: "object2."
Returns
true on success, false on failure.
Definition at line 836 of file ossimNitf20Writer.cpp.
References ossimNitfWriterBase::loadState().
838 {
839  return ossimNitfWriterBase::loadState(kwl, prefix);
840 }
Initializes the state of the writer from kwl with prefix then calls base class ossimImageFileWriter::...
◆ open()
bool ossimNitf20Writer::open ( )
virtual
Allows a generic interface to open a consumer for writing. If you are a display writer then you would probably show the window or init the device context for writing.
Definition at line 98 of file ossimNitf20Writer.cpp.
References ossimString::c_str(), close(), isOpen(), ossimImageFileWriter::theFilename, and theOutputStream.
Referenced by writeFile().
99 {
100  if(isOpen())
101  {
102  close();
103  }
105  theOutputStream->open(theFilename.c_str(), ios::out|ios::binary);
106
107  return theOutputStream->good();
108 }
virtual bool isOpen() const
const char * c_str() const
Definition: ossimString.h:396
◆ saveState()
bool ossimNitf20Writer::saveState ( ossimKeywordlist kwl,
) const
virtual
Parameters
kwlKeyword list to save to.
Returns
Definition at line 830 of file ossimNitf20Writer.cpp.
References ossimNitfWriterBase::saveState().
832 {
833  return ossimNitfWriterBase::saveState(kwl, prefix);
834 }
Saves the state of the writer to kwl with prefix then calls base class ossimImageFileWriter::saveStat...
◆ setProperty()
void ossimNitf20Writer::setProperty ( ossimRefPtr< ossimProperty property)
virtual
Set the properties.
Parameters
propertyThe property to set.
Definition at line 171 of file ossimNitf20Writer.cpp.
References ossimRefPtr< T >::get(), ossimContainerProperty::getPropertyList(), PTR_CAST, ossimPropertyInterface::setProperties(), ossimNitfImageHeaderV2_0::setProperty(), ossimNitfFileHeaderV2_0::setProperty(), ossimImageFileWriter::setProperty(), theCopyFieldsFlag, theEnableBlockaTagFlag, theEnableRpcbTagFlag, theFileHeader, and theImageHeader.
172 {
173  if(!property) return;
174
175  ossimString name = property->getName();
176
177  if(name == "file_header")
178  {
180  property.get());
181  if(containerProperty)
182  {
183  std::vector<ossimRefPtr<ossimProperty> > propertyList;
184  containerProperty->getPropertyList(propertyList);
185  theFileHeader->setProperties(propertyList);
186  }
187  }
188  else if(name == "image_header")
189  {
191  property.get());
192  if(containerProperty)
193  {
194  std::vector<ossimRefPtr<ossimProperty> > propertyList;
195  containerProperty->getPropertyList(propertyList);
196  theImageHeader->setProperties(propertyList);
197  }
198  }
199  else if (name == "enable_rpcb_tag")
200  {
201  theEnableRpcbTagFlag = property->valueToString().toBool();
202  }
203  else if (name == "enable_blocka_tag")
204  {
205  theEnableBlockaTagFlag = property->valueToString().toBool();
206  }
207  else if(name == "copy_fields_flag")
208  {
209  theCopyFieldsFlag = property->valueToString().toBool();
210  }
211  else
212  {
213  // just in case it was an nitf specific tag we can pass it safely like this
214  theFileHeader->setProperty(property);
215  theImageHeader->setProperty(property);
217  }
218 }
void setProperties(std::vector< ossimRefPtr< ossimProperty > > &propertyList)
virtual void getPropertyList(std::vector< ossimRefPtr< ossimProperty > > &children) const
#define PTR_CAST(T, p)
Definition: ossimRtti.h:321
◆ writeBlockBandSeparate()
bool ossimNitf20Writer::writeBlockBandSeparate ( )
protectedvirtual
Returns
true on success and false on error
Definition at line 284 of file ossimNitf20Writer.cpp.
References ossimNitfFileHeaderV2_0::addImageInfoRecord(), ossimRefPtr< T >::get(), ossim::getActualBitsPerPixel(), ossim::getBitsPerPixel(), ossimImageSourceSequencer::getBoundingRect(), ossimImageData::getBuf(), ossimImageData::getHeight(), ossimImageSourceSequencer::getNextTile(), ossimNitfCommon::getNitfPixelType(), ossimImageData::getNumberOfBands(), ossimImageSource::getNumberOfOutputBands(), ossimImageSourceSequencer::getNumberOfTiles(), ossimImageSourceSequencer::getOutputScalarType(), ossimRectilinearDataObject::getScalarType(), ossimImageData::getSizeInBytes(), ossimEndian::getSystemEndianType(), ossimImageData::getWidth(), ossimIrect::height(), ossimProcessInterface::needsAborting(), OSSIM_DOUBLE, OSSIM_FLOAT, OSSIM_LITTLE_ENDIAN, OSSIM_NORMALIZED_DOUBLE, OSSIM_NORMALIZED_FLOAT, OSSIM_SSHORT16, OSSIM_UCHAR, OSSIM_USHORT11, OSSIM_USHORT12, OSSIM_USHORT13, OSSIM_USHORT14, OSSIM_USHORT15, OSSIM_USHORT16, ossimNitfFileHeaderV2_0::replaceImageInfoRecord(), ossim::scalarSizeInBytes(), ossimNitfImageHeaderV2_X::setActualBitsPerPixel(), ossimNitfImageHeaderV2_0::setBandInfo(), ossimNitfImageBandV2_0::setBandRepresentation(), ossimNitfImageHeaderV2_X::setBitsPerPixel(), ossimNitfImageHeaderV2_X::setBlocksPerCol(), ossimNitfImageHeaderV2_X::setBlocksPerRow(), ossimNitfImageHeaderV2_X::setCategory(), ossimNitfWriterBase::setComplexityLevel(), ossimNitfFileHeaderV2_0::setFileLength(), ossimNitfFileHeaderV2_0::setHeaderLength(), ossimNitfImageInfoRecordV2_0::setImageLength(), ossimNitfImageHeaderV2_X::setImageMode(), ossimNitfImageHeaderV2_0::setNumberOfBands(), ossimNitfImageHeaderV2_0::setNumberOfCols(), ossimNitfImageHeaderV2_X::setNumberOfPixelsPerBlockCol(), ossimNitfImageHeaderV2_X::setNumberOfPixelsPerBlockRow(), ossimNitfImageHeaderV2_0::setNumberOfRows(), ossimImageFileWriter::setPercentComplete(), ossimNitfImageHeaderV2_X::setPixelType(), ossimNitfImageHeaderV2_X::setRepresentation(), ossimNitfImageInfoRecordV2_0::setSubheaderLength(), ossimImageSourceSequencer::setTileSize(), ossimImageSourceSequencer::setToStartOfSequence(), ossimEndian::swap(), theFileHeader, theImageHeader, ossimImageFileWriter::theInputConnection, theOutputStream, tileNumber, ossimRefPtr< T >::valid(), ossimIrect::width(), ossimNitfImageHeaderV2_0::writeStream(), ossimNitfFileHeaderV2_0::writeStream(), ossimIpt::x, and ossimIpt::y.
285 {
287  ossim_uint64 byteSize = ossim::scalarSizeInBytes(scalarType);
290  ossim_uint64 idx = 0;
291  ossim_uint64 headerStart = (ossim_uint64)theOutputStream->tellp();
292
293  ossimIpt blockSize(64, 64);
294  ossim_uint64 blocksHorizontal = (ossim_uint32)ceil(((double)rect.width()/(double)blockSize.x));
295  ossim_uint64 blocksVertical = (ossim_uint32)ceil(((double)rect.height()/(double)blockSize.y));
296
297  ossimNitfImageInfoRecordV2_0 imageInfoRecord;
298  //imageInfoRecord.setSubheaderLength(439); // ok if no tags
299  imageInfoRecord.setImageLength(bands*byteSize*blocksVertical*blockSize.y*blocksHorizontal*blockSize.x);
300
301  theFileHeader->addImageInfoRecord(imageInfoRecord);
302
303  //---
304  // This makes space for the file header; it is written again at the end of
305  // this method with updated values
306  // need a better way to get the length. This should be queried on the
307  // header before writing
308  //---
310  ossim_uint64 headerLength = ((ossim_uint64)theOutputStream->tellp() - headerStart) /* + 1 */;
311
312  ossimString representation;
314  ossim::getActualBitsPerPixel(scalarType));
318  theImageHeader->setImageMode('B');// blocked
319
320  if((bands == 3)&&
321  (scalarType == OSSIM_UCHAR))
322  {
324  theImageHeader->setCategory("VIS");
325  }
326  else if(bands == 1)
327  {
330  }
331  else
332  {
335  }
336
337  theImageHeader->setBlocksPerRow(blocksHorizontal);
338  theImageHeader->setBlocksPerCol(blocksVertical);
343
344  ossimNitfImageBandV2_0 bandInfo;
345  for(idx = 0; idx < bands; ++idx)
346  {
347  std::ostringstream out;
348
349  out << std::setfill('0')
350  << std::setw(2)
351  << idx;
352
353  bandInfo.setBandRepresentation(out.str().c_str());
355  bandInfo);
356  }
357
358  ossim_uint64 imageHeaderStart = theOutputStream->tellp();
360  ossim_uint64 imageHeaderEnd = theOutputStream->tellp();
361  ossim_uint64 imageHeaderSize = imageHeaderEnd - imageHeaderStart;
362
363  theInputConnection->setTileSize(blockSize);
368  ossimEndian endian;
369
370
371  while( data.valid() && !needsAborting())
372  {
374  {
375  switch(data->getScalarType())
376  {
377  case OSSIM_USHORT16:
378  case OSSIM_USHORT11:
379  case OSSIM_USHORT12:
380  case OSSIM_USHORT13:
381  case OSSIM_USHORT14:
382  case OSSIM_USHORT15:
383  {
384  endian.swap((ossim_uint16*)data->getBuf(),
385  data->getWidth()*data->getHeight()*data->getNumberOfBands());
386  break;
387  }
388  case OSSIM_SSHORT16:
389  {
390  endian.swap((ossim_sint16*)data->getBuf(),
391  data->getWidth()*data->getHeight()*data->getNumberOfBands());
392  break;
393  }
394  case OSSIM_FLOAT:
396  {
397  endian.swap((ossim_float32*)data->getBuf(),
398  data->getWidth()*data->getHeight()*data->getNumberOfBands());
399  break;
400  }
401  case OSSIM_DOUBLE:
403  {
404  endian.swap((ossim_float64*)data->getBuf(),
405  data->getWidth()*data->getHeight()*data->getNumberOfBands());
406  break;
407  }
408  default:
409  break;
410  }
411  }
412
413  theOutputStream->write((char*)(data->getBuf()),
414  data->getSizeInBytes());
415
416  setPercentComplete(((double)tileNumber / (double)numberOfTiles) * 100);
417
418  if(!needsAborting())
419  {
421  }
422  ++tileNumber;
423  }
424
425  std::streamoff pos = theOutputStream->tellp();
426
428
429  /*
430  * Need to change the way I compute file length and header length later
431  * We need to figure out a better way to compute.
432  */
433  theFileHeader->setFileLength(static_cast<ossim_uint64>(pos));
434  theFileHeader->setHeaderLength(headerLength);
435  theOutputStream->seekp(0, ios::beg);
436  imageInfoRecord.setSubheaderLength(imageHeaderSize);
437  theFileHeader->replaceImageInfoRecord(0, imageInfoRecord);
439
440  return true;
441 }
virtual void setNumberOfCols(ossim_uint32 cols)
void setPixelType(const ossimString &pixelType=ossimString("INT"))
std::basic_ostringstream< char > ostringstream
Class for char output memory streams.
Definition: ossimIosFwd.h:35
virtual void writeStream(ossim::ostream &out)
void setNumberOfPixelsPerBlockRow(ossim_uint32 pixels)
void setActualBitsPerPixel(ossim_uint32 bitsPerPixel)
ossim_uint32 tileNumber
bool valid() const
virtual void replaceImageInfoRecord(ossim_uint32 i, const ossimNitfImageInfoRecordV2_0 &recordInfo)
float ossim_float32
ossim_uint32 height() const
Definition: ossimIrect.h:487
virtual ossimRefPtr< ossimImageData > getNextTile(ossim_uint32 resLevel=0)
static ossimString getNitfPixelType(ossimScalarType scalarType)
Get the nitf pixel type string from scalar type.
void setSubheaderLength(ossim_uint32 length)
OSSIM_DLL ossim_uint32 getActualBitsPerPixel(ossimScalarType scalarType)
Get actual bits per pixel for a given scalar type.
unsigned short ossim_uint16
virtual void setHeaderLength(ossim_uint64 headerLength)
Sets header length (HL) field.
virtual void addImageInfoRecord(const ossimNitfImageInfoRecordV2_0 &recordInfo)
void setBitsPerPixel(ossim_uint32 bitsPerPixel)
double ossim_float64
void setBlocksPerRow(ossim_uint32 blocks)
virtual void setNumberOfBands(ossim_uint32 nbands)
virtual ossim_uint32 getSizeInBytes() const
Returns the total number of bytes for all bands.
virtual void setBandInfo(ossim_uint32 idx, const ossimNitfImageBandV2_0 &info)
signed short ossim_sint16
void setCategory(const ossimString &category)
ossimRefPtr< ossimImageSourceSequencer > theInputConnection
This will return the bounding rect of the source.
unsigned long long ossim_uint64
virtual void setFileLength(ossim_uint64 fileLength)
Sets file length (FL) field.
OSSIM_DLL ossim_uint32 scalarSizeInBytes(ossimScalarType scalarType)
void setNumberOfPixelsPerBlockCol(ossim_uint32 pixels)
ossim_uint32 width() const
Definition: ossimIrect.h:500
ossimByteOrder getSystemEndianType() const
Definition: ossimEndian.h:78
ossimScalarType
OSSIM_DLL ossim_uint32 getBitsPerPixel(ossimScalarType scalarType)
Get bits per pixel for a given scalar type.
void setBlocksPerCol(ossim_uint32 blocks)
void setRepresentation(const ossimString &rep)
virtual void setNumberOfRows(ossim_uint32 rows)
void setImageLength(ossim_uint64 length)
void setComplexityLevel(std::streamoff, ossimNitfFileHeaderV2_X *hdr)
virtual void setBandRepresentation(const ossimString &rep)
Sets the band representation.
virtual void setPercentComplete(double percentComplete)
virtual void setTileSize(const ossimIpt &tileSize)
32 bit floating point
void swap(ossim_sint8 &)
Definition: ossimEndian.h:26
16 bit unsigned iteger
64 bit floating point
16 bit signed integer
8 bit unsigned iteger
◆ writeBlockBandSequential()
bool ossimNitf20Writer::writeBlockBandSequential ( )
protectedvirtual
Band 1 is followed by band 2, ... etc.
Definition at line 443 of file ossimNitf20Writer.cpp.
References ossimNitfFileHeaderV2_0::addImageInfoRecord(), ossimRefPtr< T >::get(), ossim::getActualBitsPerPixel(), ossim::getBitsPerPixel(), ossimImageSourceSequencer::getBoundingRect(), ossimImageData::getBuf(), ossimImageData::getHeight(), ossimImageSourceSequencer::getNextTile(), ossimNitfCommon::getNitfPixelType(), ossimImageData::getNumberOfBands(), ossimImageSource::getNumberOfOutputBands(), ossimImageSourceSequencer::getNumberOfTiles(), ossimImageSourceSequencer::getNumberOfTilesHorizontal(), ossimImageSourceSequencer::getNumberOfTilesVertical(), ossimImageSourceSequencer::getOutputScalarType(), ossimRectilinearDataObject::getScalarType(), ossimEndian::getSystemEndianType(), ossimImageData::getWidth(), ossimIrect::height(), ossimProcessInterface::needsAborting(), OSSIM_DOUBLE, OSSIM_FLOAT, OSSIM_LITTLE_ENDIAN, OSSIM_NORMALIZED_DOUBLE, OSSIM_NORMALIZED_FLOAT, OSSIM_SSHORT16, OSSIM_UCHAR, OSSIM_USHORT11, OSSIM_USHORT12, OSSIM_USHORT13, OSSIM_USHORT14, OSSIM_USHORT15, OSSIM_USHORT16, ossimNitfFileHeaderV2_0::replaceImageInfoRecord(), ossim::scalarSizeInBytes(), ossimNitfImageHeaderV2_X::setActualBitsPerPixel(), ossimNitfImageHeaderV2_0::setBandInfo(), ossimNitfImageBandV2_0::setBandRepresentation(), ossimNitfImageHeaderV2_X::setBitsPerPixel(), ossimNitfImageHeaderV2_X::setBlocksPerCol(), ossimNitfImageHeaderV2_X::setBlocksPerRow(), ossimNitfImageHeaderV2_X::setCategory(), ossimNitfWriterBase::setComplexityLevel(), ossimNitfFileHeaderV2_X::setDate(), ossimNitfFileHeaderV2_0::setFileLength(), ossimNitfFileHeaderV2_0::setHeaderLength(), ossimNitfImageInfoRecordV2_0::setImageLength(), ossimNitfImageHeaderV2_X::setImageMode(), ossimNitfImageHeaderV2_0::setNumberOfBands(), ossimNitfImageHeaderV2_0::setNumberOfCols(), ossimNitfImageHeaderV2_X::setNumberOfPixelsPerBlockCol(), ossimNitfImageHeaderV2_X::setNumberOfPixelsPerBlockRow(), ossimNitfImageHeaderV2_0::setNumberOfRows(), ossimImageFileWriter::setPercentComplete(), ossimNitfImageHeaderV2_X::setPixelType(), ossimNitfImageHeaderV2_X::setRepresentation(), ossimNitfImageInfoRecordV2_0::setSubheaderLength(), ossimImageSourceSequencer::setTileSize(), ossimImageSourceSequencer::setToStartOfSequence(), ossimEndian::swap(), theFileHeader, theImageHeader, ossimImageFileWriter::theInputConnection, theOutputStream, tileNumber, ossimRefPtr< T >::valid(), ossimIrect::width(), ossimNitfImageHeaderV2_0::writeStream(), ossimNitfFileHeaderV2_0::writeStream(), ossimIpt::x, and ossimIpt::y.
444 {
446  ossim_uint64 byteSize = ossim::scalarSizeInBytes(scalarType);
449  ossim_uint64 idx = 0;
450  ossim_uint64 headerStart = (ossim_uint64)theOutputStream->tellp();
451
452  ossimIpt blockSize(64, 64);
453
456  theInputConnection->setTileSize(blockSize);
459
460  ossimNitfImageInfoRecordV2_0 imageInfoRecord;
461  // imageInfoRecord.setSubheaderLength(439);
462  imageInfoRecord.setImageLength(bands*byteSize*blocksHorizontal*blocksVertical*blockSize.x*blockSize.y);
463
464  ossimDate currentDate;
465
466  theFileHeader->setDate(currentDate);
467  theFileHeader->addImageInfoRecord(imageInfoRecord);
468
469  //---
470  // This makes space for the file header; it is written again at the end of
471  // this method with updated values
472  // need a better way to get the length. This should be queried on the
473  // header before writing
474  //---
476  ossim_uint64 headerLength = ((ossim_uint64)theOutputStream->tellp() - headerStart) /* + 1 */;
477
478  ossimString representation;
480  ossim::getActualBitsPerPixel(scalarType));
484  theImageHeader->setImageMode('S');// blocked
485
486  if((bands == 3)&&
487  (scalarType == OSSIM_UCHAR))
488  {
490  theImageHeader->setCategory("VIS");
491  }
492  else if(bands == 1)
493  {
496  }
497  else
498  {
501  }
502  theImageHeader->setBlocksPerRow(blocksHorizontal);
503  theImageHeader->setBlocksPerCol(blocksVertical);
508
509  ossimNitfImageBandV2_0 bandInfo;
510  for(idx = 0; idx < bands; ++idx)
511  {
512  std::ostringstream out;
513
514  out << std::setfill('0')
515  << std::setw(2)
516  << idx;
517
518  bandInfo.setBandRepresentation(out.str().c_str());
520  bandInfo);
521  }
522
523  int imageHeaderStart = theOutputStream->tellp();
525  int imageHeaderEnd = theOutputStream->tellp();
526  int imageHeaderSize = imageHeaderEnd - imageHeaderStart;
527
528  // ossimIpt ul = rect.ul();
531  ossimEndian endian;
532
533  // get the start to the first band of data block
534  //
535  ossim_uint64 streamOffset = theOutputStream->tellp();
536
537  // holds the total pixels to the next band
538
539  ossim_uint64 blockSizeInBytes = blockSize.x*blockSize.y*ossim::scalarSizeInBytes(data->getScalarType());
540  ossim_uint64 bandOffsetInBytes = (blockSizeInBytes*blocksHorizontal*blocksVertical);
541
542  bool needSwapping = endian.getSystemEndianType() == OSSIM_LITTLE_ENDIAN;
543  while(data.valid() && !needsAborting())
544  {
545  if(needSwapping)
546  {
547  switch(data->getScalarType())
548  {
549  case OSSIM_USHORT16:
550  case OSSIM_USHORT11:
551  case OSSIM_USHORT12:
552  case OSSIM_USHORT13:
553  case OSSIM_USHORT14:
554  case OSSIM_USHORT15:
555  {
556  endian.swap((ossim_uint16*)data->getBuf(),
557  data->getWidth()*data->getHeight()*data->getNumberOfBands());
558  break;
559  }
560  case OSSIM_SSHORT16:
561  {
562  endian.swap((ossim_sint16*)data->getBuf(),
563  data->getWidth()*data->getHeight()*data->getNumberOfBands());
564  break;
565  }
566  case OSSIM_FLOAT:
568  {
569  endian.swap((ossim_float32*)data->getBuf(),
570  data->getWidth()*data->getHeight()*data->getNumberOfBands());
571  break;
572  }
573  case OSSIM_DOUBLE:
575  {
576  endian.swap((ossim_float64*)data->getBuf(),
577  data->getWidth()*data->getHeight()*data->getNumberOfBands());
578  break;
579  }
580  default:
581  break;
582  }
583  }
584
585  for(idx = 0; idx < bands; ++idx)
586  {
587  theOutputStream->seekp(streamOffset+ // start of image stream
588  tileNumber*blockSizeInBytes + // start of block for band separate output
589  bandOffsetInBytes*idx, // which band offset is it
590  ios::beg);
591
592  theOutputStream->write((char*)(data->getBuf(idx)),
593  blockSizeInBytes);
594  }
595  ++tileNumber;
596
597  setPercentComplete(((double)tileNumber / (double)numberOfTiles) * 100);
598
599  if(!needsAborting())
600  {
602  }
603  }
604
605  std::streamoff pos = theOutputStream->tellp();
606
608
609  /*
610  * Need to change the way I compute file length and header length later
611  * We need to figure out a better way to compute.
612  */
613  theFileHeader->setFileLength(static_cast<ossim_uint64>(pos));
614  theFileHeader->setHeaderLength(headerLength);
615  theOutputStream->seekp(0, ios::beg);
616  imageInfoRecord.setSubheaderLength(imageHeaderSize);
617  theFileHeader->replaceImageInfoRecord(0, imageInfoRecord);
619
620  return true;
621 }
Sets field FDT.
bool valid() const
float ossim_float32
ossimScalarType
ossim_int64 getNumberOfTilesHorizontal() const
ossim_int64 getNumberOfTilesVertical() const
◆ writeFile()
bool ossimNitf20Writer::writeFile ( )
protectedvirtual
Returns
true on success false on error.
Definition at line 120 of file ossimNitf20Writer.cpp.
References ossimImageSourceSequencer::isMaster(), isOpen(), open(), ossimImageSourceSequencer::slaveProcessTiles(), and ossimImageFileWriter::theInputConnection.
121 {
123  {
125
126  return true;
127  }
128
129  open();
130
131  if (!isOpen())
132  {
133  if (traceDebug())
134  {
136  << "ossimNitf20Writer::writeFile ERROR:"
137  << " Could not open! Returning..."
138  << std::endl;
139  }
140
141  return false;
142  }
143
144  // Write out the geometry info.
146
147  addTags();
148
149  bool result = false;
150  if((theOutputImageType == "nitf20_block_band_separate")||
151  (theOutputImageType == "image/nitf20"))
152  {
153  result = writeBlockBandSeparate();
154  }
155  else if(theOutputImageType == "nitf20_block_band_sequential")
156  {
157  result = writeBlockBandSequential();
158  }
159
160  close();
161
162  return result;
163 }
void writeGeometry(ossimNitfImageHeaderV2_X *hdr, ossimImageSourceSequencer *seq)
virtual bool writeBlockBandSequential()
virtual bool writeBlockBandSeparate()
Member Data Documentation
◆ theCopyFieldsFlag
bool ossimNitf20Writer::theCopyFieldsFlag
protected
Definition at line 130 of file ossimNitf20Writer.h.
Referenced by addTags(), getProperty(), and setProperty().
◆ theEnableBlockaTagFlag
bool ossimNitf20Writer::theEnableBlockaTagFlag
protected
(DEFAULT = true) Currently only valid for map projected images.
Definition at line 122 of file ossimNitf20Writer.h.
Referenced by getProperty(), and setProperty().
◆ theEnableRpcbTagFlag
bool ossimNitf20Writer::theEnableRpcbTagFlag
protected
(DEFAULT = false)
Definition at line 116 of file ossimNitf20Writer.h.
◆ theFileHeader
ossimRefPtr<ossimNitfFileHeaderV2_0> ossimNitf20Writer::theFileHeader
protected
◆ theImageHeader
ossimRefPtr<ossimNitfImageHeaderV2_0> ossimNitf20Writer::theImageHeader
protected
◆ theOutputStream
std::ofstream* ossimNitf20Writer::theOutputStream
protected
