#include <ossimNitfCsproaTag.h>
Public Types | |
enum | { RESERVE1_SIZE = 12, RESERVE2_SIZE = 12, RESERVE3_SIZE = 12, RESERVE4_SIZE = 12, RESERVE5_SIZE = 12, RESERVE6_SIZE = 12, RESERVE7_SIZE = 12, RESERVE8_SIZE = 12, RESERVE9_SIZE = 12, BWC_SIZE = 12 } |
ossimNitfCsproaTag () | |
virtual void | parseStream (std::istream &in) |
virtual void | writeStream (std::ostream &out) |
virtual std::ostream & | print (std::ostream &out, const std::string &prefix=std::string()) const |
Pure virtual print method that outputs a key/value type format adding prefix to keys. More... | |
virtual void | clearFields () |
ossimNitfRegisteredTag () | |
default constructor More... | |
ossimNitfRegisteredTag (const std::string &tagName, ossim_uint32 tagLength) | |
Constructor that takes name and size. More... | |
virtual | ~ossimNitfRegisteredTag () |
destructor More... | |
virtual std::string | getRegisterTagName () const |
This will return the name of the registered tag for this user defined header. More... | |
virtual const std::string & | getTagName () const |
virtual void | setTagName (const std::string &tagName) |
virtual ossim_uint32 | getSizeInBytes () const |
Returns the length in bytes of the tag from the CEL or REL field. More... | |
virtual ossim_uint32 | getTagLength () const |
virtual void | setTagLength (ossim_uint32 length) |
Set the tag length. More... | |
virtual void | parseStream (ossim::istream &in)=0 |
This will allow the user defined data to parse the stream. More... | |
virtual void | writeStream (ossim::ostream &out)=0 |
virtual void | setProperty (ossimRefPtr< ossimProperty > property) |
virtual ossimRefPtr< ossimProperty > | getProperty (const ossimString &name) const |
virtual void | getPropertyNames (std::vector< ossimString > &propertyNames) const |
virtual void | getMetadata (ossimKeywordlist &kwl, const char *prefix=0) const |
Default interface to populate keyword list with metadata. More... | |
virtual bool | saveState (ossimKeywordlist &kwl, const ossimString &prefix) const |
ossimObject () | |
virtual | ~ossimObject () |
virtual ossimObject * | dup () const |
virtual ossimString | getShortName () const |
virtual ossimString | getLongName () const |
virtual ossimString | getDescription () const |
virtual ossimString | getClassName () const |
virtual RTTItypeid | getType () const |
virtual bool | canCastTo (ossimObject *obj) const |
virtual bool | canCastTo (const RTTItypeid &id) const |
virtual bool | canCastTo (const ossimString &parentClassName) const |
virtual bool | saveState (ossimKeywordlist &kwl, const char *prefix=0) const |
virtual bool | loadState (const ossimKeywordlist &kwl, const char *prefix=0) |
virtual std::ostream & | print (std::ostream &out) const |
Generic print method. More... | |
virtual bool | isEqualTo (const ossimObject &obj, ossimCompareType compareType=OSSIM_COMPARE_FULL) const |
virtual void | accept (ossimVisitor &visitor) |
ossimReferenced () | |
ossimReferenced (const ossimReferenced &) | |
ossimReferenced & | operator= (const ossimReferenced &) |
void | ref () const |
increment the reference count by one, indicating that this object has another pointer which is referencing it. More... | |
void | unref () const |
decrement the reference count by one, indicating that a pointer to this object is referencing it. More... | |
void | unref_nodelete () const |
int | referenceCount () const |
ossimPropertyInterface () | |
virtual | ~ossimPropertyInterface () |
virtual void | setProperty (const ossimString &name, const ossimString &value) |
virtual ossimString | getPropertyValueAsString (const ossimString &name) const |
void | getPropertyList (std::vector< ossimRefPtr< ossimProperty > > &propertyList) const |
void | setProperties (std::vector< ossimRefPtr< ossimProperty > > &propertyList) |
Protected Attributes | |
char | m_reserved1 [RESERVE1_SIZE+1] |
char | m_reserved2 [RESERVE1_SIZE+1] |
char | m_reserved3 [RESERVE1_SIZE+1] |
char | m_reserved4 [RESERVE1_SIZE+1] |
char | m_reserved5 [RESERVE1_SIZE+1] |
char | m_reserved6 [RESERVE1_SIZE+1] |
char | m_reserved7 [RESERVE1_SIZE+1] |
char | m_reserved8 [RESERVE1_SIZE+1] |
char | m_reserved9 [RESERVE1_SIZE+1] |
char | m_bwc [BWC_SIZE+1] |
std::string | m_tagName |
ossim_uint32 | m_tagLength |
virtual | ~ossimReferenced () |
Definition at line 13 of file ossimNitfCsproaTag.h.
anonymous enum |
Enumerator | |
RESERVE1_SIZE | |
RESERVE2_SIZE | |
RESERVE3_SIZE | |
RESERVE4_SIZE | |
RESERVE5_SIZE | |
RESERVE6_SIZE | |
RESERVE7_SIZE | |
RESERVE8_SIZE | |
RESERVE9_SIZE | |
BWC_SIZE |
Definition at line 16 of file ossimNitfCsproaTag.h.
ossimNitfCsproaTag::ossimNitfCsproaTag | ( | ) |
Definition at line 5 of file ossimNitfCsproaTag.cpp.
References clearFields().
Definition at line 62 of file ossimNitfCsproaTag.cpp.
References BWC_SIZE, m_bwc, m_reserved1, m_reserved2, m_reserved3, m_reserved4, m_reserved5, m_reserved6, m_reserved7, m_reserved8, m_reserved9, RESERVE1_SIZE, RESERVE2_SIZE, RESERVE3_SIZE, RESERVE4_SIZE, RESERVE5_SIZE, RESERVE6_SIZE, RESERVE7_SIZE, RESERVE8_SIZE, and RESERVE9_SIZE.
Referenced by ossimNitfCsproaTag().
Definition at line 11 of file ossimNitfCsproaTag.cpp.
Reimplemented from ossimNitfRegisteredTag.
Definition at line 39 of file ossimNitfCsproaTag.cpp.
References ossimNitfRegisteredTag::getTagLength(), ossimNitfRegisteredTag::getTagName(), m_bwc, m_reserved1, m_reserved2, m_reserved3, m_reserved4, m_reserved5, m_reserved6, m_reserved7, m_reserved8, and m_reserved9.
Definition at line 25 of file ossimNitfCsproaTag.cpp.
protected |
Definition at line 48 of file ossimNitfCsproaTag.h.
Referenced by clearFields(), parseStream(), print(), and writeStream().
protected |
Definition at line 39 of file ossimNitfCsproaTag.h.
protected |
Definition at line 40 of file ossimNitfCsproaTag.h.
protected |
Definition at line 41 of file ossimNitfCsproaTag.h.
protected |
Definition at line 42 of file ossimNitfCsproaTag.h.
protected |
Definition at line 43 of file ossimNitfCsproaTag.h.
protected |
Definition at line 44 of file ossimNitfCsproaTag.h.
protected |
Definition at line 45 of file ossimNitfCsproaTag.h.
protected |
Definition at line 46 of file ossimNitfCsproaTag.h.
protected |
Definition at line 47 of file ossimNitfCsproaTag.h.
