Public Member Functions | Private Member Functions | Private Attributes | List of all members
ossimPolyconicProjection Class Reference
#include <ossimPolyconicProjection.h>
Inheritance diagram for ossimPolyconicProjection:
ossimMapProjection ossimProjection ossimObject ossimErrorStatusInterface ossimReferenced
 ossimPolyconicProjection (const ossimEllipsoid &ellipsoid=ossimEllipsoid(), const ossimGpt &origin=ossimGpt())
 ossimPolyconicProjection (const ossimEllipsoid &ellipsoid, const ossimGpt &origin, const double falseEasting, const double falseNorthing)
 ~ossimPolyconicProjection ()
virtual ossimGpt inverse (const ossimDpt &eastingNorthing) const
 Will take a point in meters and convert it to ground. More...
virtual ossimDpt forward (const ossimGpt &latLon) const
 All map projections will convert the world coordinate to an easting northing (Meters). More...
virtual void update ()
void setFalseEasting (double falseEasting)
void setFalseNorthing (double falseNorthing)
void setFalseEastingNorthing (double falseEasting, double falseNorthing)
void setDefaults ()
double getFalseEasting () const
double getFalseNorthing () const
- Public Member Functions inherited from ossimMapProjection
 ossimMapProjection (const ossimEllipsoid &ellipsoid=ossimEllipsoid(), const ossimGpt &origin=ossimGpt())
 ossimMapProjection (const ossimMapProjection &src)
virtual ossimDpt worldToLineSample (const ossimGpt &worldPoint) const
virtual void worldToLineSample (const ossimGpt &worldPoint, ossimDpt &lineSample) const
virtual ossimGpt lineSampleToWorld (const ossimDpt &projectedPoint) const
virtual void lineSampleToWorld (const ossimDpt &projectedPoint, ossimGpt &gpt) const
virtual void lineSampleHeightToWorld (const ossimDpt &lineSampPt, const double &heightAboveEllipsoid, ossimGpt &worldPt) const
 This is the pure virtual that projects the image point to the given elevation above ellipsoid, thereby bypassing reference to a DEM. More...
virtual void lineSampleToEastingNorthing (const ossimDpt &liineSample, ossimDpt &eastingNorthing) const
virtual void eastingNorthingToLineSample (const ossimDpt &eastingNorthing, ossimDpt &lineSample) const
virtual void eastingNorthingToWorld (const ossimDpt &eastingNorthing, ossimGpt &worldPt) const
virtual double getStandardParallel1 () const
 Derived classes should implement as needed. More...
virtual double getStandardParallel2 () const
virtual void setPcsCode (ossim_uint32 pcsCode)
virtual ossim_uint32 getPcsCode () const
 Returns the EPSG PCS code or 32767 if the projection is a custom (non-EPSG) projection. More...
virtual ossimString getProjectionName () const
 Returns the projection name. More...
virtual double getA () const
 ACCESS METHODS: More...
virtual double getB () const
virtual double getF () const
virtual const ossimDptgetDecimalDegreesPerPixel () const
 Returns decimal degrees per pixel as an ossimDpt with "x" representing longitude and "y" representing latitude. More...
virtual const ossimDptgetUlEastingNorthing () const
virtual const ossimGptgetUlGpt () const
virtual const ossimDatumgetDatum () const
const ossimEllipsoidgetEllipsoid () const
const ossimGptgetOrigin () const
virtual bool isGeographic () const
virtual void applyScale (const ossimDpt &scale, bool recenterTiePoint)
 Applies scale to theDeltaLonPerPixel, theDeltaLatPerPixel and theMetersPerPixel data members (eg: theDeltaLonPerPixel *= scale.x). More...
virtual void setEllipsoid (const ossimEllipsoid &ellipsoid)
 SET METHODS: More...
virtual void setAB (double a, double b)
virtual void setDatum (const ossimDatum *datum)
 Sets theDatum to datum. More...
virtual void setOrigin (const ossimGpt &origin)
 Sets theOrigin to origin. More...
virtual void setMetersPerPixel (const ossimDpt &gsd)
virtual void setDecimalDegreesPerPixel (const ossimDpt &gsd)
virtual void setUlTiePoints (const ossimGpt &gpt)
virtual void setUlTiePoints (const ossimDpt &eastingNorthing)
virtual void setUlEastingNorthing (const ossimDpt &ulEastingNorthing)
virtual void setUlGpt (const ossimGpt &ulGpt)
virtual void assign (const ossimProjection &aProjection)
 Prints data members to stream. More...
virtual bool operator== (const ossimProjection &projection) const
 Compares this to arg projection and returns TRUE if the same. More...
virtual void computeDegreesPerPixel ()
 Computes the approximate resolution in degrees/pixel. More...
virtual void computeMetersPerPixel ()
 This will go from the ground point and give you an approximate meters per pixel. More...
void setMatrix (double rotation, const ossimDpt &scale, const ossimDpt &translation)
void setMatrixScale (const ossimDpt &scale)
void setMatrixRotation (double rotation)
void setMatrixTranslation (const ossimDpt &translation)
void snapTiePointTo (ossim_float64 multiple, ossimUnitType unitType)
 Utility method to snap the tie point to some multiple. More...
void snapTiePointToOrigin ()
void setElevationLookupFlag (bool flag)
bool getElevationLookupFlag () const
ossimUnitType getModelTransformUnitType () const
void setModelTransformUnitType (ossimUnitType unit)
bool hasModelTransform () const
void setProjectionUnits (ossimUnitType units)
ossimUnitType getProjectionUnits () const
 OSSIM considers all map projection coordinates (including false eastings and northings) to be in meters. More...
 ossimProjection ()
virtual ~ossimProjection ()
 ossimObject ()
virtual ~ossimObject ()
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
 ossimErrorStatusInterface ()
bool hasError () const
long Set_Polyconic_Parameters (double a, double f, double Origin_Latitude, double Central_Meridian, double False_Easting, double False_Northing)
void Get_Polyconic_Parameters (double *a, double *f, double *Origin_Latitude, double *Central_Meridian, double *False_Easting, double *False_Northing) const
long Convert_Geodetic_To_Polyconic (double Latitude, double Longitude, double *Easting, double *Northing) const
long Convert_Polyconic_To_Geodetic (double Easting, double Northing, double *Latitude, double *Longitude) const
Private Attributes
double Poly_a
double Poly_f
double es2
double es4
double es6
double M0
double c0
double c1
double c2
double c3
double Poly_Origin_Lat
double Poly_Origin_Long
double Poly_False_Northing
double Poly_False_Easting
double Poly_Max_Easting
double Poly_Max_Northing
double Poly_Min_Easting
double Poly_Min_Northing
Additional Inherited Members
- Protected Member Functions inherited from ossimMapProjection
virtual ~ossimMapProjection ()
void updateFromTransform ()
virtual ~ossimReferenced ()
- Protected Attributes inherited from ossimMapProjection
ossimEllipsoid theEllipsoid
 This method verifies that the projection parameters match the current pcs code. More...
ossimGpt theOrigin
const ossimDatumtheDatum
 This is only set if we want to have built in datum shifting. More...
ossimDpt theMetersPerPixel
 Holds the number of meters per pixel. More...
ossimDpt theDegreesPerPixel
 Hold the decimal degrees per pixel. More...
ossimGpt theUlGpt
 Hold tie point in decimal degrees. More...
ossimDpt theUlEastingNorthing
 Hold tie point as easting northing. More...
ossimDpt theFalseEastingNorthing
 Hold the false easting northing. More...
ossim_uint32 thePcsCode
 Projection Coordinate System(PCS) code. More...
bool theElevationLookupFlag
ossimMatrix4x4 theModelTransform
ossimMatrix4x4 theInverseModelTransform
ossimUnitType theModelTransformUnitType
ossimUnitType theProjectionUnits
 Linear units of the projection as indicated in the projection's specification: More...
ossimErrorCode theErrorStatus
Detailed Description
Definition at line 18 of file ossimPolyconicProjection.h.
◆ ossimPolyconicProjection() [1/2]
ossimPolyconicProjection::ossimPolyconicProjection ( const ossimEllipsoid ellipsoid = ossimEllipsoid(),
const ossimGpt origin = ossimGpt()
Definition at line 46 of file ossimPolyconicProjection.cpp.
References setDefaults(), and update().
48  :ossimMapProjection(ellipsoid, origin)
49 {
50  setDefaults();
51  update();
52 }
virtual ossimGpt origin() const
ossimMapProjection(const ossimEllipsoid &ellipsoid=ossimEllipsoid(), const ossimGpt &origin=ossimGpt())
◆ ossimPolyconicProjection() [2/2]
ossimPolyconicProjection::ossimPolyconicProjection ( const ossimEllipsoid ellipsoid,
const ossimGpt origin,
Definition at line 54 of file ossimPolyconicProjection.cpp.
References Poly_False_Easting, Poly_False_Northing, Poly_Max_Easting, Poly_Max_Northing, Poly_Min_Easting, Poly_Min_Northing, and update().
58  :ossimMapProjection(ellipsoid, origin)
59 {
60  Poly_False_Easting = falseEasting;
61  Poly_False_Northing = falseNorthing;
62  Poly_Max_Easting = 20037509.0;
63  Poly_Max_Northing = 15348215.0;
64  Poly_Min_Easting = -20037509.0;
65  Poly_Min_Northing = -15348215.0;
66
67  update();
68 }
◆ ~ossimPolyconicProjection()
ossimPolyconicProjection::~ossimPolyconicProjection ( )
inline
Definition at line 27 of file ossimPolyconicProjection.h.
27 {}
Member Function Documentation
◆ Convert_Geodetic_To_Polyconic()
long ossimPolyconicProjection::Convert_Geodetic_To_Polyconic ( double  Latitude,
double  Longitude,
double *  Easting,
double *  Northing
) const
private
The function Convert_Geodetic_To_Polyconic converts geodetic (latitude and longitude) coordinates to Polyconic projection easting, and northing coordinates, according to the current ellipsoid and Polyconic projection parameters. If any errors occur, the error code(s) are returned by the function, otherwise POLY_NO_ERROR is returned.
Latitude : Latitude (phi) in radians (input) Longitude : Longitude (lambda) in radians (input) Easting : Easting (X) in meters (output) Northing : Northing (Y) in meters (output)
Definition at line 319 of file ossimPolyconicProjection.cpp.
References c0, c1, c2, c3, es2, M0, M_PI, Poly_a, POLY_COEFF_TIMES_SIN, Poly_False_Easting, Poly_False_Northing, POLY_LON_WARNING, POLY_M, POLY_NO_ERROR, and Poly_Origin_Long.
Referenced by forward(), and Set_Polyconic_Parameters().
323 { /* BEGIN Convert_Geodetic_To_Polyconic */
324 /*
325  * The function Convert_Geodetic_To_Polyconic converts geodetic (latitude and
326  * longitude) coordinates to Polyconic projection (easting and northing)
327  * coordinates, according to the current ellipsoid and Polyconic projection
328  * parameters. If any errors occur, the error code(s) are returned by the
329  * function, otherwise POLY_NO_ERROR is returned.
330  *
331  * Latitude : Latitude (phi) in radians (input)
332  * Longitude : Longitude (lambda) in radians (input)
333  * Easting : Easting (X) in meters (output)
334  * Northing : Northing (Y) in meters (output)
335  */
336
337  double slat = sin(Latitude);
338  double lat, sin2lat, sin4lat, sin6lat;
339  double dlam; /* Longitude - Central Meridan */
340  double NN;
341  double NN_OVER_tlat;
342  double MM;
343  double EE;
344  long Error_Code = POLY_NO_ERROR;
345
346 // if ((Latitude < -PI_OVER_2) || (Latitude > PI_OVER_2))
347 // { /* Latitude out of range */
348 // Error_Code |= POLY_LAT_ERROR;
349 // }
350 // if ((Longitude < -M_PI) || (Longitude > TWO_PI))
351 // { /* Longitude out of range */
352 // Error_Code |= POLY_LON_ERROR;
353 // }
354  if (!Error_Code)
355  { /* no errors */
356  dlam = Longitude - Poly_Origin_Long;
357  if (fabs(dlam) > (M_PI / 2.0))
358  { /* Distortion will result if Longitude is more than 90 degrees from the Central Meridian */
359  Error_Code |= POLY_LON_WARNING;
360  }
361 // if (dlam > M_PI)
362 // {
363 // dlam -= TWO_PI;
364 // }
365 // if (dlam < -M_PI)
366 // {
367 // dlam += TWO_PI;
368 // }
369  if (Latitude == 0.0)
370  {
371  *Easting = Poly_a * dlam + Poly_False_Easting;
372  *Northing = -M0 + Poly_False_Northing;
373  }
374  else
375  {
376  NN = Poly_a / sqrt(1.0 - es2 * (slat * slat));
377  NN_OVER_tlat = NN / tan(Latitude);
378  lat = c0 * Latitude;
379  sin2lat = POLY_COEFF_TIMES_SIN(c1, 2.0, Latitude);
380  sin4lat = POLY_COEFF_TIMES_SIN(c2, 4.0, Latitude);
381  sin6lat = POLY_COEFF_TIMES_SIN(c3, 6.0, Latitude);
382  MM = POLY_M(lat, sin2lat, sin4lat, sin6lat);
383  EE = dlam * slat;
384  *Easting = NN_OVER_tlat * sin(EE) + Poly_False_Easting;
385  *Northing = MM - M0 + NN_OVER_tlat * (1.0 - cos(EE)) +
387  }
388  }
389  return (Error_Code);
390 } /* END OF Convert_Geodetic_To_Polyconic */
#define POLY_NO_ERROR
#define M_PI
#define POLY_LON_WARNING
#define POLY_COEFF_TIMES_SIN(coeff, x, latit)
#define POLY_M(c0lat, c1s2lat, c2s4lat, c3s6lat)
◆ Convert_Polyconic_To_Geodetic()
long ossimPolyconicProjection::Convert_Polyconic_To_Geodetic ( double  Easting,
double  Northing,
double *  Latitude,
double *  Longitude
) const
private
The function Convert_Polyconic_To_Geodetic converts Polyconic projection easting and northing coordinates to geodetic (latitude and longitude) coordinates, according to the current ellipsoid and Polyconic projection coordinates. If any errors occur, the error code(s) are returned by the function, otherwise POLY_NO_ERROR is returned.
Easting : Easting (X) in meters (input) Northing : Northing (Y) in meters (input) Latitude : Latitude (phi) in radians (output) Longitude : Longitude (lambda) in radians (output)
Definition at line 393 of file ossimPolyconicProjection.cpp.
References c0, c1, c2, c3, es2, FLOAT_EQ, M0, PI_OVER_2, Poly_a, POLY_COEFF_TIMES_SIN, Poly_False_Easting, Poly_False_Northing, POLY_M, POLY_NO_ERROR, and Poly_Origin_Long.
Referenced by inverse().
397 { /* BEGIN Convert_Polyconic_To_Geodetic */
398 /*
399  * The function Convert_Polyconic_To_Geodetic converts Polyconic projection
400  * (easting and northing) coordinates to geodetic (latitude and longitude)
401  * coordinates, according to the current ellipsoid and Polyconic projection
402  * coordinates. If any errors occur, the error code(s) are returned by the
403  * function, otherwise POLY_NO_ERROR is returned.
404  *
405  * Easting : Easting (X) in meters (input)
406  * Northing : Northing (Y) in meters (input)
407  * Latitude : Latitude (phi) in radians (output)
408  * Longitude : Longitude (lambda) in radians (output)
409  */
410
411  double dx; /* Delta easting - Difference in easting (easting-FE) */
412  double dy; /* Delta northing - Difference in northing (northing-FN) */
413  double dx_OVER_Poly_a;
414  double AA;
415  double BB;
416  double CC = 0.0;
417  double PHIn, Delta_PHI = 1.0;
418  double sin_PHIn;
419  double PHI, sin2PHI,sin4PHI, sin6PHI;
420  double Mn, Mn_prime, Ma;
421  double AA_Ma;
422  double Ma2_PLUS_BB;
423  double AA_MINUS_Ma;
424  double tolerance = 1.0e-12; /* approximately 1/1000th of
425  an arc second or 1/10th meter */
426  long Error_Code = POLY_NO_ERROR;
427
428 // if ((Easting < (Poly_False_Easting + Poly_Min_Easting))
429 // || (Easting > (Poly_False_Easting + Poly_Max_Easting)))
430 // { /* Easting out of range */
431 // Error_Code |= POLY_EASTING_ERROR;
432 // }
433 // if ((Northing < (Poly_False_Northing + Poly_Min_Northing))
434 // || (Northing > (Poly_False_Northing + Poly_Max_Northing)))
435 // { /* Northing out of range */
436 // Error_Code |= POLY_NORTHING_ERROR;
437 // }
438  if (!Error_Code)
439  { /* no errors */
440  dy = Northing - Poly_False_Northing;
441  dx = Easting - Poly_False_Easting;
442  dx_OVER_Poly_a = dx / Poly_a;
443  if (FLOAT_EQ(dy,-M0,1))
444  {
445  *Latitude = 0.0;
446  *Longitude = dx_OVER_Poly_a + Poly_Origin_Long;
447  }
448  else
449  {
450  AA = (M0 + dy) / Poly_a;
451  BB = dx_OVER_Poly_a * dx_OVER_Poly_a + (AA * AA);
452  PHIn = AA;
453
454  while (fabs(Delta_PHI) > tolerance)
455  {
456  sin_PHIn = sin(PHIn);
457  CC = sqrt(1.0 - es2 * sin_PHIn * sin_PHIn) * tan(PHIn);
458  PHI = c0 * PHIn;
459  sin2PHI = POLY_COEFF_TIMES_SIN(c1, 2.0, PHIn);
460  sin4PHI = POLY_COEFF_TIMES_SIN(c2, 4.0, PHIn);
461  sin6PHI = POLY_COEFF_TIMES_SIN(c3, 6.0, PHIn);
462  Mn = POLY_M(PHI, sin2PHI, sin4PHI, sin6PHI);
463  Mn_prime = c0 - 2.0 * c1 * cos(2.0 * PHIn) + 4.0 * c2 * cos(4.0 * PHIn) -
464  6.0 * c3 * cos(6.0 * PHIn);
465  Ma = Mn / Poly_a;
466  AA_Ma = AA * Ma;
467  Ma2_PLUS_BB = Ma * Ma + BB;
468  AA_MINUS_Ma = AA - Ma;
469  Delta_PHI = (AA_Ma * CC + AA_MINUS_Ma - 0.5 * (Ma2_PLUS_BB) * CC) /
470  (es2 * sin2PHI * (Ma2_PLUS_BB - 2.0 * AA_Ma) /
471  4.0 * CC + (AA_MINUS_Ma) * (CC * Mn_prime - 2.0 / sin2PHI) - Mn_prime);
472  PHIn -= Delta_PHI;
473  }
474  *Latitude = PHIn;
475
476 // if (*Latitude > PI_OVER_2) /* force distorted values to 90, -90 degrees */
477 // *Latitude = PI_OVER_2;
478 // else if (*Latitude < -PI_OVER_2)
479 // *Latitude = -PI_OVER_2;
480
481  if (FLOAT_EQ(fabs(*Latitude),PI_OVER_2,.00001) || (*Latitude == 0))
482  *Longitude = Poly_Origin_Long;
483
484  else
485  {
486  *Longitude = (asin(dx_OVER_Poly_a * CC)) / sin(*Latitude) +
488  }
489  }
490 // if (*Longitude > M_PI)
491 // *Longitude -= TWO_PI;
492 // if (*Longitude < -M_PI)
493 // *Longitude += TWO_PI;
494
495 // if (*Longitude > M_PI) /* force distorted values to 180, -180 degrees */
496 // *Longitude = M_PI;
497 // else if (*Longitude < -M_PI)
498 // *Longitude = -M_PI;
499
500  }
501  return (Error_Code);
502 } /* END OF Convert_Polyconic_To_Geodetic */
#define PI_OVER_2
#define FLOAT_EQ(x, v, epsilon)
◆ dup()
virtual ossimObject* ossimPolyconicProjection::dup ( ) const
inlinevirtual
Implements ossimProjection.
Definition at line 28 of file ossimPolyconicProjection.h.
29  {
30  return new ossimPolyconicProjection(*this);
31  }
ossimPolyconicProjection(const ossimEllipsoid &ellipsoid=ossimEllipsoid(), const ossimGpt &origin=ossimGpt())
◆ forward()
ossimDpt ossimPolyconicProjection::forward ( const ossimGpt worldPoint) const
virtual
Definition at line 131 of file ossimPolyconicProjection.cpp.
References ossimGpt::changeDatum(), ossimDatum::code(), Convert_Geodetic_To_Polyconic(), ossimGpt::datum(), ossimGpt::latr(), ossimGpt::lonr(), and ossimMapProjection::theDatum.
132 {
133  double easting = 0.0;
134  double northing = 0.0;
135  ossimGpt gpt = latLon;
136
137  if (theDatum)
138  {
139  if (theDatum->code() != latLon.datum()->code())
140  {
141  gpt.changeDatum(theDatum); // Shift to our datum.
142  }
143  }
144
146  gpt.lonr(),
147  &easting,
148  &northing);
149
150  return ossimDpt(easting, northing);
151 }
virtual const ossimString & code() const
Definition: ossimDatum.h:57
void changeDatum(const ossimDatum *datum)
This will actually perform a shift.
Definition: ossimGpt.cpp:316
double lonr() const
Returns the longitude in radian measure.
Definition: ossimGpt.h:76
double latr() const
latr().
Definition: ossimGpt.h:66
long Convert_Geodetic_To_Polyconic(double Latitude, double Longitude, double *Easting, double *Northing) const
const ossimDatum * theDatum
◆ Get_Polyconic_Parameters()
void ossimPolyconicProjection::Get_Polyconic_Parameters ( double *  a,
double *  f,
double *  Origin_Latitude,
double *  Central_Meridian,
double *  False_Easting,
double *  False_Northing
) const
private
The function Get_Polyconic_Parameters returns the current ellipsoid parameters, and Polyconic projection parameters.
a : Semi-major axis of ellipsoid, in meters (output) f : Flattening of ellipsoid (output) Origin_Latitude : Latitude in radians at which the (output) point scale factor is 1.0 Central_Meridian : Longitude in radians at the center of (output) the projection False_Easting : A coordinate value in meters assigned to the central meridian of the projection. (output) False_Northing : A coordinate value in meters assigned to the origin latitude of the projection (output)
Definition at line 284 of file ossimPolyconicProjection.cpp.
References Poly_a, Poly_f, Poly_False_Easting, Poly_False_Northing, Poly_Origin_Lat, and Poly_Origin_Long.
291 { /* BEGIN Get_Polyconic_Parameters */
292 /*
293  * The function Get_Polyconic_Parameters returns the current ellipsoid
294  * parameters, and Polyconic projection parameters.
295  *
296  * a : Semi-major axis of ellipsoid, in meters (output)
297  * f : Flattening of ellipsoid (output)
298  * Origin_Latitude : Latitude in radians at which the (output)
299  * point scale factor is 1.0
300  * Central_Meridian : Longitude in radians at the center of (output)
301  * the projection
302  * False_Easting : A coordinate value in meters assigned to the
303  * central meridian of the projection. (output)
304  * False_Northing : A coordinate value in meters assigned to the
305  * origin latitude of the projection (output)
306  */
307
308  *a = Poly_a;
309  *f = Poly_f;
310  *Origin_Latitude = Poly_Origin_Lat;
311  *Central_Meridian = Poly_Origin_Long;
312  *False_Easting = Poly_False_Easting;
313  *False_Northing = Poly_False_Northing;
314
315  return;
316 } /* END OF Get_Polyconic_Parameters */
◆ getFalseEasting()
double ossimPolyconicProjection::getFalseEasting ( ) const
inlinevirtual
Returns
The false easting.
Definition at line 58 of file ossimPolyconicProjection.h.
◆ getFalseNorthing()
double ossimPolyconicProjection::getFalseNorthing ( ) const
inlinevirtual
Returns
The false northing.
Definition at line 59 of file ossimPolyconicProjection.h.
◆ inverse()
ossimGpt ossimPolyconicProjection::inverse ( const ossimDpt projectedPoint) const
virtual
Definition at line 118 of file ossimPolyconicProjection.cpp.
References Convert_Polyconic_To_Geodetic(), DEG_PER_RAD, ossimMapProjection::theDatum, ossimDpt::x, and ossimDpt::y.
119 {
120  double lat = 0.0;
121  double lon = 0.0;
122
123  Convert_Polyconic_To_Geodetic(eastingNorthing.x,
124  eastingNorthing.y,
125  &lat,
126  &lon);
127
128  return ossimGpt(lat*DEG_PER_RAD, lon*DEG_PER_RAD, 0.0, theDatum);
129 }
#define DEG_PER_RAD
long Convert_Polyconic_To_Geodetic(double Easting, double Northing, double *Latitude, double *Longitude) const
◆ loadState()
bool ossimPolyconicProjection::loadState ( const ossimKeywordlist kwl,
const char *  prefix = 0
virtual
Definition at line 158 of file ossimPolyconicProjection.cpp.
References ossimKeywordlist::find(), ossimMapProjection::loadState(), Poly_False_Easting, Poly_False_Northing, setDefaults(), STATIC_TYPE_NAME, ossimMapProjection::theFalseEastingNorthing, ossimKeywordNames::TYPE_KW, update(), ossimDpt::x, and ossimDpt::y.
160 {
161  bool flag = ossimMapProjection::loadState(kwl, prefix);
162  const char* type = kwl.find(prefix, ossimKeywordNames::TYPE_KW);
163
164  setDefaults();
165
167  {
170  }
171
172  update();
173
174  return flag;
175 }
double y
Definition: ossimDpt.h:165
static const char * TYPE_KW
#define STATIC_TYPE_NAME(T)
Definition: ossimRtti.h:325
double x
Definition: ossimDpt.h:164
◆ saveState()
bool ossimPolyconicProjection::saveState ( ossimKeywordlist kwl,
) const
virtual
Definition at line 153 of file ossimPolyconicProjection.cpp.
References ossimMapProjection::saveState().
154 {
155  return ossimMapProjection::saveState(kwl, prefix);
156 }
◆ Set_Polyconic_Parameters()
long ossimPolyconicProjection::Set_Polyconic_Parameters ( double  a,
double  f,
private
The function Set_Polyconic_Parameters receives the ellipsoid parameters and Polyconic projcetion parameters as inputs, and sets the corresponding state variables.If any errors occur, the error code(s) are returned by the function, otherwise POLY_NO_ERROR is returned.
a : Semi-major axis of ellipsoid, in meters (input) f : Flattening of ellipsoid (input) Origin_Latitude : Latitude in radians at which the (input) point scale factor is 1.0 Central_Meridian : Longitude in radians at the center of (input) the projection False_Easting : A coordinate value in meters assigned to the central meridian of the projection. (input) False_Northing : A coordinate value in meters assigned to the origin latitude of the projection (input)
Definition at line 183 of file ossimPolyconicProjection.cpp.
References c0, c1, c2, c3, Convert_Geodetic_To_Polyconic(), es2, es4, es6, FOURTY_ONE, M0, M_PI, Poly_a, POLY_COEFF_TIMES_SIN, Poly_f, Poly_False_Easting, Poly_False_Northing, POLY_M, Poly_Max_Easting, Poly_Max_Northing, Poly_Min_Easting, Poly_Min_Northing, POLY_NO_ERROR, Poly_Origin_Lat, and Poly_Origin_Long.
Referenced by update().
190 { /* BEGIN Set_Polyconic_Parameters */
191 /*
192  * The function Set_Polyconic_Parameters receives the ellipsoid parameters and
193  * Polyconic projection parameters as inputs, and sets the corresponding state
194  * variables. If any errors occur, the error code(s) are returned by the function,
195  * otherwise POLY_NO_ERROR is returned.
196  *
197  * a : Semi-major axis of ellipsoid, in meters (input)
198  * f : Flattening of ellipsoid (input)
199  * Origin_Latitude : Latitude in radians at which the (input)
200  * point scale factor is 1.0
201  * Central_Meridian : Longitude in radians at the center of (input)
202  * the projection
203  * False_Easting : A coordinate value in meters assigned to the
204  * central meridian of the projection. (input)
205  * False_Northing : A coordinate value in meters assigned to the
206  * origin latitude of the projection (input)
207  */
208
209  double j, three_es4;
210  double lat, sin2lat, sin4lat, sin6lat;
211  double temp;
212 // double inv_f = 1 / f;
213  long Error_Code = POLY_NO_ERROR;
214
215 // if (a <= 0.0)
216 // { /* Semi-major axis must be greater than zero */
217 // Error_Code |= POLY_A_ERROR;
218 // }
219 // if ((inv_f < 250) || (inv_f > 350))
220 // { /* Inverse flattening must be between 250 and 350 */
221 // Error_Code |= POLY_INV_F_ERROR;
222 // }
223 // if ((Origin_Latitude < -PI_OVER_2) || (Origin_Latitude > PI_OVER_2))
224 // { /* origin latitude out of range */
225 // Error_Code |= POLY_ORIGIN_LAT_ERROR;
226 // }
227 // if ((Central_Meridian < -M_PI) || (Central_Meridian > TWO_PI))
228 // { /* origin longitude out of range */
229 // Error_Code |= POLY_CENT_MER_ERROR;
230 // }
231  if (!Error_Code)
232  { /* no errors */
233  Poly_a = a;
234  Poly_f = f;
235  Poly_Origin_Lat = Origin_Latitude;
236 // if (Central_Meridian > M_PI)
237 // Central_Meridian -= TWO_PI;
238  Poly_Origin_Long = Central_Meridian;
239  Poly_False_Northing = False_Northing;
240  Poly_False_Easting = False_Easting;
241  es2 = 2 * Poly_f - Poly_f * Poly_f;
242  es4 = es2 * es2;
243  es6 = es4 * es2;
244
245  j = 45.0 * es6 / 1024.0;
246  three_es4 = 3.0 * es4;
247  c0 = 1.0 - es2 / 4.0 - three_es4 / 64.0 - 5.0 * es6 / 256.0;
248  c1 = 3.0 * es2 / 8.0 + three_es4 / 32.0 + j;
249  c2 = 15.0 * es4 / 256.0 + j;
250  c3 = 35.0 * es6 / 3072.0;
251
252  lat = c0 * Poly_Origin_Lat;
253  sin2lat = POLY_COEFF_TIMES_SIN(c1, 2.0, Poly_Origin_Lat);
254  sin4lat = POLY_COEFF_TIMES_SIN(c2, 4.0, Poly_Origin_Lat);
255  sin6lat = POLY_COEFF_TIMES_SIN(c3, 6.0, Poly_Origin_Lat);
256  M0 = POLY_M(lat, sin2lat, sin4lat, sin6lat);
257
258  if (Poly_Origin_Long > 0)
259  {
262  Poly_Max_Easting = 19926189.0;
263  Poly_Min_Easting = -20037509.0;
264  }
265  else if (Poly_Origin_Long < 0)
266  {
269  Poly_Max_Easting = 20037509.0;
270  Poly_Min_Easting = -19926189.0;
271  }
272  else
273  {
276  Poly_Max_Easting = 20037509.0;
277  Poly_Min_Easting = -20037509.0;
278  }
279
280  } /* END OF if(!Error_Code) */
281  return (Error_Code);
282 } /* END OF Set_Polyconic_Parameters */
#define M_PI
#define FOURTY_ONE
◆ setDefaults()
void ossimPolyconicProjection::setDefaults ( )
◆ setFalseEasting()
void ossimPolyconicProjection::setFalseEasting ( double  falseEasting)
Definition at line 85 of file ossimPolyconicProjection.cpp.
References Poly_False_Easting, and update().
86 {
87  Poly_False_Easting = falseEasting;
88
89  update();
90 }
◆ setFalseEastingNorthing()
void ossimPolyconicProjection::setFalseEastingNorthing ( double  falseEasting,
Definition at line 109 of file ossimPolyconicProjection.cpp.
References Poly_False_Easting, Poly_False_Northing, and update().
111 {
112  Poly_False_Easting = falseEasting;
113  Poly_False_Northing = falseNorthing;
114
115  update();
116 }
◆ setFalseNorthing()
void ossimPolyconicProjection::setFalseNorthing ( double  falseNorthing)
Definition at line 92 of file ossimPolyconicProjection.cpp.
References Poly_False_Northing, and update().
93 {
94  Poly_False_Northing = falseNorthing;
95
96  update();
97 }
◆ update()
void ossimPolyconicProjection::update ( )
virtual
Definition at line 70 of file ossimPolyconicProjection.cpp.
References ossimEllipsoid::getA(), ossimEllipsoid::getFlattening(), ossimGpt::latr(), ossimGpt::lonr(), Poly_False_Easting, Poly_False_Northing, Set_Polyconic_Parameters(), ossimMapProjection::theEllipsoid, ossimMapProjection::theFalseEastingNorthing, ossimMapProjection::theOrigin, ossimMapProjection::update(), ossimDpt::x, and ossimDpt::y.
Referenced by loadState(), ossimPolyconicProjection(), setFalseEasting(), setFalseEastingNorthing(), and setFalseNorthing().
71 {
74  theOrigin.latr(),
75  theOrigin.lonr(),
78
81
83 }
long Set_Polyconic_Parameters(double a, double f, double Origin_Latitude, double Central_Meridian, double False_Easting, double False_Northing)
double y
const double & getA() const
double lonr() const
double x
double latr() const
latr().
const double & getFlattening() const
Member Data Documentation
◆ c0
double ossimPolyconicProjection::c0
mutableprivate
◆ c1
double ossimPolyconicProjection::c1
mutableprivate
◆ c2
double ossimPolyconicProjection::c2
mutableprivate
◆ c3
double ossimPolyconicProjection::c3
mutableprivate
◆ es2
double ossimPolyconicProjection::es2
mutableprivate
◆ es4
double ossimPolyconicProjection::es4
mutableprivate
Definition at line 79 of file ossimPolyconicProjection.h.
Referenced by Set_Polyconic_Parameters().
◆ es6
double ossimPolyconicProjection::es6
mutableprivate
Definition at line 80 of file ossimPolyconicProjection.h.
◆ M0
double ossimPolyconicProjection::M0
mutableprivate
◆ Poly_a
double ossimPolyconicProjection::Poly_a
mutableprivate
◆ Poly_f
double ossimPolyconicProjection::Poly_f
mutableprivate
◆ Poly_False_Easting
double ossimPolyconicProjection::Poly_False_Easting
mutableprivate
◆ Poly_False_Northing
double ossimPolyconicProjection::Poly_False_Northing
mutableprivate
◆ Poly_Max_Easting
double ossimPolyconicProjection::Poly_Max_Easting
mutableprivate
◆ Poly_Max_Northing
double ossimPolyconicProjection::Poly_Max_Northing
mutableprivate
◆ Poly_Min_Easting
double ossimPolyconicProjection::Poly_Min_Easting
mutableprivate
◆ Poly_Min_Northing
double ossimPolyconicProjection::Poly_Min_Northing
mutableprivate
◆ Poly_Origin_Lat
double ossimPolyconicProjection::Poly_Origin_Lat
mutableprivate
◆ Poly_Origin_Long
double ossimPolyconicProjection::Poly_Origin_Long
mutableprivate
