Public Types | Public Member Functions | Protected Attributes | List of all members
ossimRectangleCutFilter Class Reference
#include <ossimRectangleCutFilter.h>
Inheritance diagram for ossimRectangleCutFilter:
ossimImageSourceFilter ossimImageSource ossimConnectableObjectListener ossimSource ossimListener ossimConnectableObject ossimErrorStatusInterface ossimObject ossimListenerManager ossimPropertyInterface ossimReferenced ossimEastingNorthingCutter
Public Types
enum  ossimRectangleCutType { OSSIM_RECTANGLE_NULL_INSIDE = 0, OSSIM_RECTANGLE_NULL_OUTSIDE = 1 }
 ossimRectangleCutFilter (ossimObject *owner, ossimImageSource *inputSource=NULL)
 ossimRectangleCutFilter (ossimImageSource *inputSource=NULL)
void setRectangle (const ossimIrect &rect)
const ossimIrectgetRectangle () const
ossimRectangleCutType getCutType () const
void setCutType (ossimRectangleCutType cutType)
ossimIrect getBoundingRect (ossim_uint32 resLevel=0) const
ossimRefPtr< ossimImageDatagetTile (const ossimIrect &rect, ossim_uint32 resLevel=0)
virtual void initialize ()
virtual bool saveState (ossimKeywordlist &kwl, const char *prefix=NULL) const
virtual ~ossimImageSource ()
 Method to get a tile. More...
 For RTTI support. More...
virtual ~ossimSource ()
virtual void enableSource ()
virtual void disableSource ()
const ossimIdgetId () const
 ossimObject ()
virtual ~ossimObject ()
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
 ossimListenerManager ()
 ossimPropertyInterface ()
 ossimErrorStatusInterface ()
bool hasError () const
 ProcessEvent. More...
 ossimListener ()
virtual ~ossimListener ()
void enableListener ()
void disableListener ()
ossimIrect theRectangle
ossimRectangleCutType theCutType
vector< ossimDpttheDecimationList
bool theEnableFlag
bool theInitializedFlag
ossimId theId
ossimString theDescription
ossimObjecttheOwner
bool theInputListIsFixedFlag
bool theOutputListIsFixedFlag
bool theEnabledFlag
bool theFireEventFlag
ossimErrorCode theErrorStatus
bool theListenerEnableFlag
Additional Inherited Members
virtual ~ossimReferenced ()
Detailed Description
Definition at line 16 of file ossimRectangleCutFilter.h.
◆ ossimRectangleCutType
Enumerator
Definition at line 19 of file ossimRectangleCutFilter.h.
◆ ossimRectangleCutFilter() [1/2]
ossimRectangleCutFilter::ossimRectangleCutFilter ( ossimObject owner,
ossimImageSource inputSource = NULL
◆ ossimRectangleCutFilter() [2/2]
ossimRectangleCutFilter::ossimRectangleCutFilter ( ossimImageSource inputSource = NULL)
Member Function Documentation
◆ getBoundingRect()
ossimIrect ossimRectangleCutFilter::getBoundingRect ( ossim_uint32  resLevel = 0) const
virtual
This will return the bounding rect of the source.
We can have several sources which are in a chain to modify the bounding image rect. lets say you are next to an image handler then it will return the bounding rect for that image. If you are at the right side of a resampler then you will get a bounding rect along the image view plane. This is going to be a very import method for both image writers, mosaics or anything that needs to operate only within the bounds of an image.
Definition at line 171 of file ossimRectangleCutFilter.cpp.
Referenced by getValidImageVertices().
172 {
173  if(traceDebug())
174  {
175  ossimNotify(ossimNotifyLevel_DEBUG) << "ossimRectangleCutFilter::getBoundingRect DEBUG: entered..." << std::endl;
176  }
177  ossimIrect result;
178
179  result.makeNan();
180  if(!theInputConnection)
181  {
182  if(traceDebug())
183  {
184  ossimNotify(ossimNotifyLevel_DEBUG) << "ossimRectangleCutFilter::getBoundingRect DEBUG: Input connection was not valid so leaving" << std::endl;
185  }
186  return result;
187  }
188
189  result = theInputConnection->getBoundingRect(resLevel);
190  if(isSourceEnabled())
191  {
193  {
194  ossimDpt decimation;
195  getDecimationFactor(resLevel, decimation);
196  ossimIrect cutRect = theRectangle;
197  if(!decimation.hasNans())
198  {
199  cutRect = theRectangle*decimation;
200  }
201  result = cutRect;
202  }
203  }
204
205  if(traceDebug())
206  {
207  ossimNotify(ossimNotifyLevel_DEBUG) << "ossimRectangleCutFilter::getBoundingRect DEBUG: cut rect = " << result << std::endl;
208  }
209  return result;
210 }
bool hasNans() const
Definition: ossimDpt.h:67
void makeNan()
Definition: ossimIrect.h:329
virtual void getDecimationFactor(ossim_uint32 resLevel, ossimDpt &result) const
Will return the decimation factor for the given resolution level.
◆ getCutType()
ossimRectangleCutFilter::ossimRectangleCutType ossimRectangleCutFilter::getCutType ( ) const
Definition at line 298 of file ossimRectangleCutFilter.cpp.
References theCutType.
299 {
300  return theCutType;
301 }
◆ getRectangle()
const ossimIrect & ossimRectangleCutFilter::getRectangle ( ) const
Definition at line 293 of file ossimRectangleCutFilter.cpp.
References theRectangle.
294 {
295  return theRectangle;
296 }
◆ getTile()
ossimRefPtr< ossimImageData > ossimRectangleCutFilter::getTile ( const ossimIrect rect,
virtual
Returns
Definition at line 41 of file ossimRectangleCutFilter.cpp.
References ossimIrect::completely_within(), ossimDataObject::getDataObjectStatus(), ossimImageData::getHeight(), ossimImageData::getImageRectangle(), ossimImageSource::getTile(), ossimImageData::getWidth(), ossimIrect::hasNans(), ossimIrect::intersects(), ossimSource::isSourceEnabled(), min, OSSIM_EMPTY, OSSIM_NULL, OSSIM_RECTANGLE_NULL_INSIDE, OSSIM_RECTANGLE_NULL_OUTSIDE, ossimImageData::setNull(), theCutType, theDecimationList, ossimImageSourceFilter::theInputConnection, theRectangle, ossimIrect::ul(), ossimRefPtr< T >::valid(), ossimImageData::validate(), ossimIpt::x, x, ossimIpt::y, and y.
44 {
46
47  if ( theInputConnection && isSourceEnabled() && ( theRectangle.hasNans() == false ) )
48  {
49  ossim_int32 decimationIndex = min((ossim_int32)resLevel,
50  (ossim_int32)theDecimationList.size()-1);
51
52  // Compute cut rect for resLevel:
53  ossimIrect cutRect = theRectangle*theDecimationList[decimationIndex];
54
55  // Check intersection of our cut rect:
56  bool requestIntersects = rect.intersects( cutRect );
57  bool requestCompletelyWithin = rect.completely_within(cutRect);
58
59  if ( ( ( theCutType == OSSIM_RECTANGLE_NULL_OUTSIDE ) && requestIntersects ) ||
60  ( ( theCutType == OSSIM_RECTANGLE_NULL_INSIDE ) && !requestCompletelyWithin ) )
61  {
62  // Grab tile from the input.
63  tile = theInputConnection->getTile(rect, resLevel);
64
65  if ( tile.valid() )
66  {
67  if ( tile->getDataObjectStatus() != OSSIM_NULL &&
68  tile->getDataObjectStatus() != OSSIM_EMPTY )
69  {
70  ossimIrect inputRectangle = tile->getImageRectangle();
71
72  if( theCutType == OSSIM_RECTANGLE_NULL_OUTSIDE ) // Typical case...
73  {
74  if ( !requestCompletelyWithin )
75  {
76  // Clip the tile:
77  ossim_int32 ulx = inputRectangle.ul().x;
78  ossim_int32 uly = inputRectangle.ul().y;
79  ossim_int32 w = tile->getWidth();
80  ossim_int32 h = tile->getHeight();
81  ossim_int32 offset = 0;
82  ossimIpt tempPoint(ulx, uly);
83
84  for(ossim_int32 y = 0; y < h; ++tempPoint.y,++y)
85  {
86  tempPoint.x = ulx;
87  for(ossim_int32 x = 0; x < w; ++tempPoint.x,++x)
88  {
89  if(!cutRect.pointWithin(tempPoint))
90  {
91  tile->setNull(offset);
92  }
93  ++offset;
94  }
95  }
96  tile->validate();
97  }
98  }
99  else // Null inside...
100  {
101  // Note if complete within requested rect this block was bypassed entirely.
102  ossim_int32 ulx = inputRectangle.ul().x;
103  ossim_int32 uly = inputRectangle.ul().y;
104  ossim_int32 w = tile->getWidth();
105  ossim_int32 h = tile->getHeight();
106  ossim_int32 offset = 0;
107  ossimIpt tempPoint(ulx, uly);
108
109  for(ossim_int32 y = 0; y < h; ++tempPoint.y,++y)
110  {
111  tempPoint.x = ulx;
112  for(ossim_int32 x = 0; x < w; ++tempPoint.x,++x)
113  {
114  if(cutRect.pointWithin(tempPoint))
115  {
116  tile->setNull(offset);
117  }
118  ++offset;
119  }
120  }
121  tile->validate();
122  }
123
124  } // Matches: if ( tile->getDataObjectStatus() ...
125
126  } // Matches: if ( tile.valid() )
127
128  } // Matches: if ( ( ( theCutType == OSSI ...
129
130  } // Matches: if ( theInputConnection && enabled && ...
131
132  return tile;
133 } // End: ossimRectangleCutFilter::getTile( ... )
vector< ossimDpt > theDecimationList
ossim_uint32 x
ossim_uint32 y
bool valid() const
Definition: ossimRefPtr.h:75
const ossimIpt & ul() const
Definition: ossimIrect.h:274
bool intersects(const ossimIrect &rect) const
Definition: ossimIrect.cpp:183
bool completely_within(const ossimIrect &rect) const
Definition: ossimIrect.cpp:425
virtual ossimIrect getImageRectangle() const
void setNull(ossim_uint32 offset)
ossim_int32 y
Definition: ossimIpt.h:142
Definition: ossimIrect.h:337
ossim_int32 x
Definition: ossimIpt.h:141
#define min(a, b)
Definition: auxiliary.h:75
int ossim_int32
◆ getValidImageVertices()
void ossimRectangleCutFilter::getValidImageVertices ( vector< ossimIpt > &  validVertices,
ossimVertexOrdering  ordering = OSSIM_CLOCKWISE_ORDER,
) const
virtual
Definition at line 148 of file ossimRectangleCutFilter.cpp.
References getBoundingRect(), ossimIrect::ll(), ossimIrect::lr(), OSSIM_CLOCKWISE_ORDER, ossimIrect::ul(), and ossimIrect::ur().
152 {
153  ossimIrect rect = getBoundingRect();
154
155  if(ordering == OSSIM_CLOCKWISE_ORDER)
156  {
157  validVertices.push_back(rect.ul());
158  validVertices.push_back(rect.ur());
159  validVertices.push_back(rect.lr());
160  validVertices.push_back(rect.ll());
161  }
162  else
163  {
164  validVertices.push_back(rect.ul());
165  validVertices.push_back(rect.ll());
166  validVertices.push_back(rect.lr());
167  validVertices.push_back(rect.ur());
168  }
169 }
ossimIrect getBoundingRect(ossim_uint32 resLevel=0) const
const ossimIpt & ll() const
Definition: ossimIrect.h:277
const ossimIpt & lr() const
Definition: ossimIrect.h:276
const ossimIpt & ur() const
Definition: ossimIrect.h:275
◆ initialize()
void ossimRectangleCutFilter::initialize ( )
virtual
Reimplemented in ossimEastingNorthingCutter.
Definition at line 212 of file ossimRectangleCutFilter.cpp.
References ossimImageSource::getDecimationFactors(), ossimIrect::hasNans(), setRectangle(), theDecimationList, ossimImageSourceFilter::theInputConnection, and theRectangle.
Referenced by ossimEastingNorthingCutter::initialize().
213 {
214  theDecimationList.clear();
216  {
218  }
219  if(theDecimationList.empty())
220  {
221  theDecimationList.push_back(ossimDpt(1,1));
222  }
223  if(theRectangle.hasNans())
224  {
226  }
227 }
void setRectangle(const ossimIrect &rect)
virtual void getDecimationFactors(std::vector< ossimDpt > &decimations) const
Will return an array of all decimations for each resolution level.
◆ loadState()
bool ossimRectangleCutFilter::loadState ( const ossimKeywordlist kwl,
const char *  prefix = NULL
virtual
Definition at line 255 of file ossimRectangleCutFilter.cpp.
References ossimString::c_str(), ossimString::empty(), ossimKeywordlist::find(), ossimImageSourceFilter::loadState(), ossimIrect::loadState(), OSSIM_RECTANGLE_NULL_INSIDE, OSSIM_RECTANGLE_NULL_OUTSIDE, theCutType, theRectangle, ossimString::toLong(), and ossimIrect::toRect().
257 {
258  ossimString newPrefix = prefix;
259
260  ossimString rect = kwl.find(prefix, "rect");
261  if(!rect.empty())
262  {
263  theRectangle.toRect(rect);
264  }
265  else
266  {
267  newPrefix+="clip_rect.";
268
269  theRectangle.loadState(kwl, newPrefix.c_str());
270  }
271
272  const char* cutType = kwl.find(prefix, "cut_type");
273  if(cutType)
274  {
275  ossimString c = cutType;
276  if(c == "null_inside")
277  {
279  }
280  else if(c == "null_outside")
281  {
283  }
284  else
285  {
286  theCutType = static_cast<ossimRectangleCutType>(ossimString(cutType).toLong());
287  }
288  }
289
290  return ossimImageSourceFilter::loadState(kwl, prefix);
291 }
bool loadState(const ossimKeywordlist &kwl, const char *prefix=0)
Definition: ossimIrect.cpp:641
long toLong() const
toLong&#39;s deprecated, please use the toInts...
const char * c_str() const
Definition: ossimString.h:396
bool empty() const
Definition: ossimString.h:411
bool toRect(const ossimString &rectString)
expected Format: form 1: ( 30, -90, 512, 512, [LH|RH] ) -x- -y- -w- -h- -Right or left handed- ...
Definition: ossimIrect.cpp:359
◆ saveState()
bool ossimRectangleCutFilter::saveState ( ossimKeywordlist kwl,
) const
virtual
Definition at line 229 of file ossimRectangleCutFilter.cpp.
References ossimKeywordlist::add(), OSSIM_RECTANGLE_NULL_INSIDE, OSSIM_RECTANGLE_NULL_OUTSIDE, ossimImageSourceFilter::saveState(), ossimIrect::saveState(), theCutType, and theRectangle.
Referenced by ossimEastingNorthingCutter::saveState().
231 {
232  ossimString newPrefix = prefix;
233  newPrefix+="clip_rect.";
234
235  theRectangle.saveState(kwl, newPrefix);
236
238  {
239  kwl.add(prefix,
240  "cut_type",
241  "null_inside",
242  true);
243  }
245  {
246  kwl.add(prefix,
247  "cut_type",
248  "null_outside",
249  true);
250  }
251
252  return ossimImageSourceFilter::saveState(kwl, prefix);
253 }
bool saveState(ossimKeywordlist &kwl, const char *prefix=0) const
Definition: ossimIrect.cpp:589
◆ setCutType()
void ossimRectangleCutFilter::setCutType ( ossimRectangleCutType  cutType)
Definition at line 303 of file ossimRectangleCutFilter.cpp.
Referenced by ossimChipProcTool::getChip().
304 {
305  theCutType = cutType;
306 }
◆ setRectangle()
void ossimRectangleCutFilter::setRectangle ( const ossimIrect rect)
Definition at line 135 of file ossimRectangleCutFilter.cpp.
References ossimImageSource::getBoundingRect(), ossimIrect::hasNans(), ossimImageSourceFilter::theInputConnection, and theRectangle.
Referenced by ossimChipProcTool::getChip(), initialize(), ossimIgen::outputProduct(), and ossimGpkgWriter::reInitializeCutters().
136 {
137  theRectangle = rect;
138
139  if(theRectangle.hasNans())
140  {
142  {
144  }
145  }
146 }
Member Data Documentation
◆ theCutType
ossimRectangleCutType ossimRectangleCutFilter::theCutType
protected
◆ theDecimationList
vector<ossimDpt> ossimRectangleCutFilter::theDecimationList
protected
Definition at line 53 of file ossimRectangleCutFilter.h.
Referenced by getTile(), and initialize().
◆ theRectangle
ossimIrect ossimRectangleCutFilter::theRectangle
protected
