Public Member Functions | Private Attributes | Friends | List of all members
ossimRpfBoundaryRectSectionSubheader Class Reference
#include <ossimRpfBoundaryRectSectionSubheader.h>
Inheritance diagram for ossimRpfBoundaryRectSectionSubheader:
ossimReferenced
 ossimRpfBoundaryRectSectionSubheader ()
 default constructor More...
 ossimRpfBoundaryRectSectionSubheader (const ossimRpfBoundaryRectSectionSubheader &obj)
 copy constructor More...
const ossimRpfBoundaryRectSectionSubheaderoperator= (const ossimRpfBoundaryRectSectionSubheader &rhs)
 assignment operator More...
virtual ~ossimRpfBoundaryRectSectionSubheader ()
ossimErrorCode parseStream (std::istream &in, ossimByteOrder)
void writeStream (std::ostream &out)
 Write method. More...
std::ostream & print (std::ostream &out) const
 print method More...
ossim_uint16 getNumberOfEntries () const
ossim_uint32 getTableOffset () const
ossim_uint16 getLengthOfEachEntry () const
void setNumberOfEntries (ossim_uint16 entries)
void setTableOffset (ossim_uint32 offset)
void setLengthOfEachEntry (ossim_uint16 length)
void clearFields ()
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
Private Attributes
ossim_uint32 m_rectangleTableOffset
ossim_uint16 m_numberOfEntries
ossim_uint16 m_lengthOfEachEntry
Friends
std::ostream & operator<< (std::ostream &out, const ossimRpfBoundaryRectSectionSubheader &data)
Additional Inherited Members
virtual ~ossimReferenced ()
Detailed Description
Definition at line 19 of file ossimRpfBoundaryRectSectionSubheader.h.
◆ ossimRpfBoundaryRectSectionSubheader() [1/2]
ossimRpfBoundaryRectSectionSubheader::ossimRpfBoundaryRectSectionSubheader ( )
◆ ossimRpfBoundaryRectSectionSubheader() [2/2]
ossimRpfBoundaryRectSectionSubheader::ossimRpfBoundaryRectSectionSubheader ( const ossimRpfBoundaryRectSectionSubheader obj)
◆ ~ossimRpfBoundaryRectSectionSubheader()
ossimRpfBoundaryRectSectionSubheader::~ossimRpfBoundaryRectSectionSubheader ( )
virtual
Definition at line 53 of file ossimRpfBoundaryRectSectionSubheader.cpp.
54 {
55 }
Member Function Documentation
◆ clearFields()
void ossimRpfBoundaryRectSectionSubheader::clearFields ( )
◆ getLengthOfEachEntry()
ossim_uint16 ossimRpfBoundaryRectSectionSubheader::getLengthOfEachEntry ( ) const
◆ getNumberOfEntries()
ossim_uint16 ossimRpfBoundaryRectSectionSubheader::getNumberOfEntries ( ) const
◆ getTableOffset()
ossim_uint32 ossimRpfBoundaryRectSectionSubheader::getTableOffset ( ) const
◆ operator=()
const ossimRpfBoundaryRectSectionSubheader & ossimRpfBoundaryRectSectionSubheader::operator= ( const ossimRpfBoundaryRectSectionSubheader rhs)
◆ parseStream()
ossimErrorCode ossimRpfBoundaryRectSectionSubheader::parseStream ( std::istream &  in,
ossimByteOrder  byteOrder
Definition at line 57 of file ossimRpfBoundaryRectSectionSubheader.cpp.
References ossim::byteOrder(), clearFields(), m_lengthOfEachEntry, m_numberOfEntries, m_rectangleTableOffset, ossimErrorCodes::OSSIM_ERROR, ossimErrorCodes::OSSIM_OK, and ossimEndian::swap().
Referenced by ossimRpfHeader::getNewBoundaryRectSectSubheader().
59 {
60  if(in)
61  {
62  clearFields();
63
64  in.read((char*)&m_rectangleTableOffset, 4);
65  in.read((char*)&m_numberOfEntries, 2);
66  in.read((char*)&m_lengthOfEachEntry, 2);
67
68  if( ossim::byteOrder() != byteOrder )
69  {
70  ossimEndian anEndian;
71  anEndian.swap(m_rectangleTableOffset);
72  anEndian.swap(m_numberOfEntries);
73  anEndian.swap(m_lengthOfEachEntry);
74  }
75  }
76  else
77  {
79  }
80
82 }
static const ossimErrorCode OSSIM_OK
OSSIM_DLL ossimByteOrder byteOrder()
Definition: ossimCommon.cpp:54
static const ossimErrorCode OSSIM_ERROR
void swap(ossim_sint8 &)
Definition: ossimEndian.h:26
◆ print()
std::ostream & ossimRpfBoundaryRectSectionSubheader::print ( std::ostream &  out) const
print method
Parameters
outString to output to.
Returns
output stream.
Definition at line 109 of file ossimRpfBoundaryRectSectionSubheader.cpp.
References m_lengthOfEachEntry, m_numberOfEntries, and m_rectangleTableOffset.
Referenced by operator<<().
110 {
111  out << "RectangleTableOffset: " << m_rectangleTableOffset
112  << "\nNumberOfEntries: " << m_numberOfEntries
113  << "\nLengthOfEachEntry: " << m_lengthOfEachEntry << std::endl;
114  return out;
115 }
◆ setLengthOfEachEntry()
void ossimRpfBoundaryRectSectionSubheader::setLengthOfEachEntry ( ossim_uint16  length)
◆ setNumberOfEntries()
void ossimRpfBoundaryRectSectionSubheader::setNumberOfEntries ( ossim_uint16  entries)
Definition at line 132 of file ossimRpfBoundaryRectSectionSubheader.cpp.
References m_numberOfEntries.
◆ setTableOffset()
void ossimRpfBoundaryRectSectionSubheader::setTableOffset ( ossim_uint32  offset)
◆ writeStream()
void ossimRpfBoundaryRectSectionSubheader::writeStream ( std::ostream &  out)
Write method.
Parameters
outStream to write to.
Definition at line 84 of file ossimRpfBoundaryRectSectionSubheader.cpp.
References ossimEndian::getSystemEndianType(), m_lengthOfEachEntry, m_numberOfEntries, m_rectangleTableOffset, OSSIM_BIG_ENDIAN, and ossimEndian::swap().
85 {
86  ossimEndian anEndian;
87
88  if( anEndian.getSystemEndianType() != OSSIM_BIG_ENDIAN )
89  {
90  // Always write out big endian.
91  anEndian.swap(m_rectangleTableOffset);
92  anEndian.swap(m_numberOfEntries);
93  anEndian.swap(m_lengthOfEachEntry);
94  }
95
96  out.write((char*)&m_rectangleTableOffset, 4);
97  out.write((char*)&m_numberOfEntries, 2);
98  out.write((char*)&m_lengthOfEachEntry, 2);
99
100  if( anEndian.getSystemEndianType() != OSSIM_BIG_ENDIAN )
101  {
102  // Swap back to native.
103  anEndian.swap(m_rectangleTableOffset);
104  anEndian.swap(m_numberOfEntries);
105  anEndian.swap(m_lengthOfEachEntry);
106  }
107 }
ossimByteOrder getSystemEndianType() const
Definition: ossimEndian.h:78
◆ operator<<
std::ostream& operator<< ( std::ostream &  out,
const ossimRpfBoundaryRectSectionSubheader data
friend
Definition at line 19 of file ossimRpfBoundaryRectSectionSubheader.cpp.
21 {
22  return data.print(out);
23 }
std::ostream & print(std::ostream &out) const
print method
Member Data Documentation
◆ m_lengthOfEachEntry
ossim_uint16 ossimRpfBoundaryRectSectionSubheader::m_lengthOfEachEntry
private
◆ m_numberOfEntries
ossim_uint16 ossimRpfBoundaryRectSectionSubheader::m_numberOfEntries
private
◆ m_rectangleTableOffset
ossim_uint32 ossimRpfBoundaryRectSectionSubheader::m_rectangleTableOffset
private
