RPF replace/update section subheader record. More...
#include <ossimRpfReplaceUpdateRecord.h>
ossimRpfReplaceUpdateRecord () | |
default constructor More... | |
ossimRpfReplaceUpdateRecord (const ossimRpfReplaceUpdateRecord &obj) | |
copy constructor More... | |
const ossimRpfReplaceUpdateRecord & | operator= (const ossimRpfReplaceUpdateRecord &rhs) |
assignment operator More... | |
ossimErrorCode | parseStream (std::istream &in) |
Method to parse the record. More... | |
void | writeStream (std::ostream &out) |
Write method. More... | |
void | clearFields () |
Clears fields. More... | |
std::ostream & | print (std::ostream &out, const std::string &prefix=std::string(), ossim_uint32 recordNumber=0) const |
print method that outputs a key/value type format adding prefix to keys. More... | |
void | getNewFilename (std::string &file) const |
Gets new file field. More... | |
void | getOldFilename (std::string &file) const |
Gets old file field. More... | |
ossim_uint8 | getUpdateStatus () const |
void | setNewFilename (const std::string &file) |
Sets old file name 12 byte field. More... | |
void | setOldFilename (const std::string &file) |
Sets new file name 12 byte field. More... | |
void | setUpdateStatus (ossim_uint8 status) |
Private Attributes | |
char | m_newFile [13] |
This is a 12 byte asci field. More... | |
char | m_oldFile [13] |
ossim_uint8 | m_updateStatus |
This is a 1 byte unsigned integer. More... | |
Friends | |
std::ostream & | operator<< (std::ostream &out, const ossimRpfReplaceUpdateRecord &data) |
Convenience output operator. More... | |
See MIL-STD-2411 for detailed information.
Definition at line 26 of file ossimRpfReplaceUpdateRecord.h.
ossimRpfReplaceUpdateRecord::ossimRpfReplaceUpdateRecord | ( | ) |
default constructor
Definition at line 29 of file ossimRpfReplaceUpdateRecord.cpp.
References clearFields().
ossimRpfReplaceUpdateRecord::ossimRpfReplaceUpdateRecord | ( | const ossimRpfReplaceUpdateRecord & | obj | ) |
copy constructor
Definition at line 36 of file ossimRpfReplaceUpdateRecord.cpp.
References m_newFile, and m_oldFile.
void ossimRpfReplaceUpdateRecord::clearFields | ( | ) |
Clears fields.
Definition at line 127 of file ossimRpfReplaceUpdateRecord.cpp.
References m_newFile, m_oldFile, and m_updateStatus.
Referenced by ossimRpfReplaceUpdateRecord(), and parseStream().
void ossimRpfReplaceUpdateRecord::getNewFilename | ( | std::string & | file | ) | const |
file | Set by this. |
Definition at line 97 of file ossimRpfReplaceUpdateRecord.cpp.
References m_newFile.
void ossimRpfReplaceUpdateRecord::getOldFilename | ( | std::string & | file | ) | const |
Definition at line 102 of file ossimRpfReplaceUpdateRecord.cpp.
References m_oldFile.
ossim_uint8 ossimRpfReplaceUpdateRecord::getUpdateStatus | ( | ) | const |
Definition at line 107 of file ossimRpfReplaceUpdateRecord.cpp.
References m_updateStatus.
const ossimRpfReplaceUpdateRecord & ossimRpfReplaceUpdateRecord::operator= | ( | const ossimRpfReplaceUpdateRecord & | rhs | ) |
assignment operator
Definition at line 44 of file ossimRpfReplaceUpdateRecord.cpp.
ossimErrorCode ossimRpfReplaceUpdateRecord::parseStream | ( | std::istream & | in | ) |
Note no byte swapping required for this record.
in | Stream sitting at record. |
Definition at line 56 of file ossimRpfReplaceUpdateRecord.cpp.
References clearFields(), m_newFile, m_oldFile, m_updateStatus, ossimErrorCodes::OSSIM_ERROR, ossimErrorCodes::OSSIM_OK, and status.
Referenced by ossimRpfFrame::populateReplaceUpdateTable().
std::ostream & ossimRpfReplaceUpdateRecord::print | ( | std::ostream & | out, |
const std::string & | prefix = std::string() , |
ossim_uint32 | recordNumber = 0 |
) | const |
out | Stream to output to. |
prefix | This will be prepended to key. |
recordNumber | This is added to key. See below. e.g. Where prefix = "nitf.rpf.", recordNumber = 0 and key is "new_file" key becomes: "nitf.rpf.replace_update_record0.new_file:" |
Definition at line 82 of file ossimRpfReplaceUpdateRecord.cpp.
References m_newFile, m_oldFile, m_updateStatus, ossimString::string(), and ossimString::toString().
Referenced by operator<<().
void ossimRpfReplaceUpdateRecord::setNewFilename | ( | const std::string & | file | ) |
file |
Definition at line 112 of file ossimRpfReplaceUpdateRecord.cpp.
References m_newFile, and ossimNitfCommon::setField().
void ossimRpfReplaceUpdateRecord::setOldFilename | ( | const std::string & | file | ) |
file |
Definition at line 117 of file ossimRpfReplaceUpdateRecord.cpp.
References m_oldFile, and ossimNitfCommon::setField().
void ossimRpfReplaceUpdateRecord::setUpdateStatus | ( | ossim_uint8 | status | ) |
Definition at line 122 of file ossimRpfReplaceUpdateRecord.cpp.
References m_updateStatus, and status.
void ossimRpfReplaceUpdateRecord::writeStream | ( | std::ostream & | out | ) |
Write method.
out | Stream to write to. |
Definition at line 75 of file ossimRpfReplaceUpdateRecord.cpp.
friend |
Definition at line 24 of file ossimRpfReplaceUpdateRecord.cpp.
private |
Definition at line 108 of file ossimRpfReplaceUpdateRecord.h.
Referenced by clearFields(), getNewFilename(), operator=(), ossimRpfReplaceUpdateRecord(), parseStream(), print(), setNewFilename(), and writeStream().
private |
Definition at line 111 of file ossimRpfReplaceUpdateRecord.h.
Referenced by clearFields(), getOldFilename(), operator=(), ossimRpfReplaceUpdateRecord(), parseStream(), print(), setOldFilename(), and writeStream().
private |
Definition at line 114 of file ossimRpfReplaceUpdateRecord.h.
Referenced by clearFields(), getUpdateStatus(), operator=(), parseStream(), print(), setUpdateStatus(), and writeStream().
