Public Types | Public Member Functions | Private Member Functions | Private Attributes | List of all members
ossimSensorModelTuple Class Reference
#include <ossimSensorModelTuple.h>
Public Types
enum  DeriveMode {
  OBS_INIT =-99, EVALUATE =-98, P_WRT_X = -1, P_WRT_Y = -2,
  P_WRT_Z = -3
enum  IntersectStatus { OP_SUCCESS = 0, ERROR_PROP_FAIL = 1, OP_FAIL = 2 }
 ossimSensorModelTuple ()
 default constructor More...
 ~ossimSensorModelTuple ()
 virtual destructor More...
void addImage (ossimSensorModel *image)
 Method to add an image to the tuple. More...
std::ostream & print (std::ostream &out) const
 print method. More...
ossimSensorModelTuple::IntersectStatus intersect (const DptSet_t obs, ossimEcefPoint &pt, NEWMAT::Matrix &covMat) const
 Multi-image intersection method. More...
ossimSensorModelTuple::IntersectStatus intersect (const ossim_int32 &img, const ossimDpt &obs, ossimEcefPoint &pt, NEWMAT::Matrix &covMat)
 Single-image/DEM intersection method. More...
ossimSensorModelTuple::IntersectStatus intersect (const ossim_int32 &img, const ossimDpt &obs, const ossim_float64 &heightAboveEllipsoid, ossimEcefPoint &pt, NEWMAT::Matrix &covMat)
 Single-image/height intersection method. More...
bool setIntersectionSurfaceAccuracy (const ossim_float64 &surfCE90, const ossim_float64 &surfLE90)
 Set intersection surface accuracy method. More...
void getRpcPqeInputs (ossimRpcPqeInputs &obj) const
bool computeSingleInterCov (const ossim_int32 &img, const ossimDpt &obs, const ossimGpt &ptG, HeightRefType_t cRefType, NEWMAT::Matrix &covMat)
 Compute single image intersection covariance matrix. More...
bool getGroundObsEqComponents (const ossim_int32 img, const ossimDpt &obs, const ossimGpt &ptEst, ossimDpt &resid, NEWMAT::Matrix &B, NEWMAT::SymmetricMatrix &W) const
 Get observation equation components. More...
NEWMAT::Matrix invert (const NEWMAT::Matrix &m) const
Private Attributes
std::vector< ossimRefPtr< ossimSensorModel > > theImages
ossim_int32 theNumImages
ossim_float64 theSurfCE90
ossim_float64 theSurfLE90
bool theSurfAccSet
bool theSurfAccRepresentsNoDEM
ossimRpcPqeInputs theRpcPqeInputs
 Rpc model only, container to capture pqe inputs for report purposes only. More...
Detailed Description
Definition at line 42 of file ossimSensorModelTuple.h.
◆ DeriveMode
Enumerator
OBS_INIT
EVALUATE
P_WRT_X
P_WRT_Y
P_WRT_Z
Definition at line 46 of file ossimSensorModelTuple.h.
◆ IntersectStatus
Enumerator
OP_SUCCESS
ERROR_PROP_FAIL
OP_FAIL
Definition at line 55 of file ossimSensorModelTuple.h.
◆ ossimSensorModelTuple()
ossimSensorModelTuple::ossimSensorModelTuple ( )
default constructor
Definition at line 52 of file ossimSensorModelTuple.cpp.
53 :
54  theNumImages(0),
55  theSurfCE90(0.0),
56  theSurfLE90(0.0),
57  theSurfAccSet(false),
60 {
61  if (traceDebug())
62  {
64  << "\nossimSensorModelTuple::ossimSensorModelTuple DEBUG:"
65  << std::endl;
66 #ifdef OSSIM_ID_ENABLED
68  << "OSSIM_ID: " << OSSIM_ID << std::endl;
69 #endif
70  }
71
72 }
◆ ~ossimSensorModelTuple()
ossimSensorModelTuple::~ossimSensorModelTuple ( )
virtual destructor
Definition at line 79 of file ossimSensorModelTuple.cpp.
80 {
81  if (traceExec()) ossimNotify(ossimNotifyLevel_DEBUG)
82  << "DEBUG: ~ossimSensorModelTuple(): entering..." << std::endl;
83  if (traceExec()) ossimNotify(ossimNotifyLevel_DEBUG)
84  << "DEBUG: ~ossimSensorModelTuple(): returning..." << std::endl;
85 }
Member Function Documentation
◆ addImage()
void ossimSensorModelTuple::addImage ( ossimSensorModel image)
Definition at line 94 of file ossimSensorModelTuple.cpp.
References theImages, and theNumImages.
Referenced by main().
95 {
96  theImages.push_back(image);
97  theNumImages++;
98 }
◆ computeSingleInterCov()
bool ossimSensorModelTuple::computeSingleInterCov ( const ossim_int32 img,
const ossimDpt obs,
const ossimGpt ptG,
NEWMAT::Matrix &  covMat
private
Parameters
imgImage set index of current image.
obsImage point observations.
ptGCurrent ground estimate.
cRefTypeCurrent height reference type.
covMat3X3 ECF position covariance matrix.
Returns
Definition at line 403 of file ossimSensorModelTuple.cpp.
Referenced by intersect().
409 {
410  NEWMAT::SymmetricMatrix BtWB(3);
411  NEWMAT::Matrix B(2,3);
412  NEWMAT::SymmetricMatrix W(2);
413  NEWMAT::Matrix surfCovENU(3,3);
414  ossimDpt resid;
415
416  bool tCovOK;
417  bool covOK;
418
419  // Set the height reference
420  ossimHgtRef hgtRef(cRefType);
421
422
423  if (PTR_CAST(ossimRpcModel, theImages[img]))
424  {
426
427  // ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
428  // Special case for handling RPC LOS error components
429  // ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
430  ossimGpt ptObs(obs.samp,obs.line);
431  theImages[img]->getForwardDeriv(OBS_INIT, ptObs);
432  resid = theImages[img]->getForwardDeriv(EVALUATE, ptG);
433  ossimDpt pWRTx = theImages[img]->getForwardDeriv(P_WRT_X, ptG);
434  ossimDpt pWRTy = theImages[img]->getForwardDeriv(P_WRT_Y, ptG);
435  ossimDpt pWRTz = theImages[img]->getForwardDeriv(P_WRT_Z, ptG);
436
437  // Form required partials in local frame
438  ossimLsrSpace enu(ptG);
439  NEWMAT::Matrix jECF(3,2);
440  jECF(1,1) = pWRTx.u;
441  jECF(1,2) = pWRTx.v;
442  jECF(2,1) = pWRTy.u;
443  jECF(2,2) = pWRTy.v;
444  jECF(3,1) = pWRTz.u;
445  jECF(3,2) = pWRTz.v;
446  NEWMAT::Matrix jLSR(3,2);
447  jLSR = enu.ecefToLsrRotMatrix()*jECF;
448  ossim_float64 dU_dx = jLSR(1,1);
449  ossim_float64 dU_dy = jLSR(2,1);
450  ossim_float64 dU_dz = jLSR(3,1);
451  ossim_float64 dV_dx = jLSR(1,2);
452  ossim_float64 dV_dy = jLSR(2,2);
453  ossim_float64 dV_dz = jLSR(3,2);
454
455  // Compute azimuth & elevation angles
456  ossim_float64 den = dU_dy*dV_dx - dV_dy*dU_dx;
457  ossim_float64 dY = dU_dx*dV_dz - dV_dx*dU_dz;
458  ossim_float64 dX = dV_dy*dU_dz - dU_dy*dV_dz;
459  ossim_float64 dy_dH = dY / den;
460  ossim_float64 dx_dH = dX / den;
461  ossim_float64 tAz = atan2(dx_dH, dy_dH);
462  ossim_float64 tEl = atan2(1.0, sqrt(dy_dH*dy_dH+dx_dH*dx_dH));
463
464
465  // Get the terrain surface info required by ossimPositionQualityEvaluator
466  ossimColumnVector3d surfN = hgtRef.getLocalTerrainNormal(ptG);
467  // ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
468  // Currently, the CE/LE must be explicitly set by the
469  // setIntersectionSurfaceAccuracy. When DEM accuracy maintenance
470  // is fully supported, the following call should be used.
471  // bool tCovOK = hgtRef.getHeightCovMatrix(ptG, covECF);
472  // ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
473  ossim_float64 surfCE;
474  ossim_float64 surfLE;
475
477  {
478  //***************************************************************
479  // RPC_No_DEM_State Demo case
480  // In this case, surfCE90/surfLE90 are interpreted differently:
481  // [1] surfCE90 contains the scale divisor for RPC hgtScale
482  // [2] surfLE90 contains the probability level divisor for
483  // RPC hgtScale to yield a 1-sigma value
484  //***************************************************************
485
486  // Reset the surface normal to vertical
487  surfN = surfN.zAligned();
488
489  // Set approximate surface CE/LE based on RPC parameters
490  // [1] Assume range (scale) only to be 90% vertical error for now
491  // [2] Assume bias could be used for height
493  model->getRpcParameters(rpcPar);
494  ossim_float64 hgtRng = rpcPar.hgtScale;
495  surfCE = 0.0;
496  ossim_float64 scaledHgtRng = abs(hgtRng/theSurfCE90);
497  ossim_float64 scaled1SigmaHgtRng = abs(scaledHgtRng/theSurfLE90);
498  surfLE = scaled1SigmaHgtRng*1.6449;
499
500  if(traceDebug())
501  {
503  << "\n computeSingleInterCov() RPC NoDEM state selected..."
504  << "\n RPC Height Scale = " << rpcPar.hgtScale <<" m"
505  << "\n Scale Divisor = " <<abs(theSurfCE90)
506  << "\n 1-Sigma Divisor = "<<abs(theSurfLE90)
507  << std::endl;
508  }
509  }
510  else
511  {
512  surfCE = theSurfCE90;
513  surfLE = theSurfLE90;
514  }
515
516  tCovOK = hgtRef.getSurfaceCovMatrix(surfCE, surfLE, surfCovENU);
517
518  // Evaluate & retrieve the ENU covariance matrix
519  if (tCovOK)
520  {
521  // Store for later retrieval...
528
529  if(traceDebug())
530  {
532  << "\n RPC error prop parameters..."
533  << "\n Elevation Angle = " << tEl*DEG_PER_RAD<< " deg"
534  << "\n Azimuth Angle = " << tAz*DEG_PER_RAD<<" deg"
535  << "\n RPC Bias Error = " <<model->getBiasError() <<" m"
536  << "\n RPC Random Error = " <<model->getRandError()<<" m"
537  << "\n surfN = " <<surfN
538  << "\n surfCovENU = \n" <<surfCovENU
539  << std::endl;
540  }
541
542  ossimEcefPoint pt(ptG);
543
545  (pt,model->getBiasError(),model->getRandError(),
546  tEl,tAz,surfN,surfCovENU);
547  NEWMAT::Matrix covENU(3,3);
548  covOK = qev.getCovMatrix(covENU);
549
550  // Transform to ECF for output
551  if (covOK)
552  {
553  covMat = enu.lsrToEcefRotMatrix()*covENU*enu.ecefToLsrRotMatrix();
554  }
555  }
556  else
557  {
558  covOK = false;
559  }
560  }
561
562  else
563  {
564  // ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
565  // Standard covariance matrix formation
566  // ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
567  // Image contribution
568  covOK = getGroundObsEqComponents(img, obs, ptG, resid, B, W);
569  BtWB << B.t() * W * B;
570
571  // Height contribution
572  NEWMAT::Matrix St(3,3);
573  // ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
574  // Currently, the CE/LE must be explicitly set by the
575  // setIntersectionSurfaceAccuracy. When DEM accuracy maintenance
576  // is fully supported, the following call should be used.
577  // hgtRef.getHeightCovMatrix(ptG, St);
578  // ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
579
580  // Check for special case of "no DEM" error propagation, only used for RPC
582  {
583  if(traceDebug())
584  {
586  << "\n computeSingleInterCov() RPC NoDEM state selected..."
587  << " Not valid for this sensor model" << std::endl;
588  }
589  }
590
591  if (hgtRef.getSurfaceCovMatrix(theSurfCE90, theSurfLE90, surfCovENU))
592  {
593  tCovOK = hgtRef.getSurfaceNormalCovMatrix(ptG, surfCovENU, St);
594  }
595  else
596  {
597  tCovOK = false;
598  }
599
600  if (tCovOK)
601  {
602  NEWMAT::Matrix Sti = invert(St);
603  // Full ECF covariance matrix
604  covMat = invert(BtWB + Sti);
605  }
606  else
607  {
608  // Don't include height
609  covMat = invert(BtWB);
610  }
611  }
612
613  return covOK;
614 }
NEWMAT::Matrix theSurfaceCovMatrix
#define DEG_PER_RAD
ossim_float64 theRpcAzimuthAngle
double u
Definition: ossimDpt.h:164
double samp
ossim_float64 theRpcRandError
ossim_float64 theRpcBiasError
#define abs(a)
Definition: auxiliary.h:74
void getRpcParameters(ossimRpcModel::rpcModelStruct &model) const
Returns RPC parameter set in structure.
ossim_float64 theRpcElevationAngle
double ossim_float64
double line
Definition: ossimDpt.h:165
#define PTR_CAST(T, p)
Definition: ossimRtti.h:321
RPC model structure used for access function.
Definition: ossimRpcModel.h:44
NEWMAT::Matrix invert(const NEWMAT::Matrix &m) const
double getRandError() const
Returns Error - Random.
double getBiasError() const
Returns Error - Bias.
bool getGroundObsEqComponents(const ossim_int32 img, const ossimDpt &obs, const ossimGpt &ptEst, ossimDpt &resid, NEWMAT::Matrix &B, NEWMAT::SymmetricMatrix &W) const
ossimColumnVector3d theSurfaceNormalVector
const ossimColumnVector3d & zAligned()
double v
◆ getGroundObsEqComponents()
bool ossimSensorModelTuple::getGroundObsEqComponents ( const ossim_int32  img,
const ossimDpt obs,
const ossimGpt ptEst,
ossimDpt resid,
NEWMAT::Matrix &  B,
NEWMAT::SymmetricMatrix &  W
) const
private
Parameters
iterCurrent iteration.
obsObservations.
ptEstCurrent ground estimate.
residObservation residuals.
BMatrix of partials of observations WRT X,Y,Z.
WWeight matrix of observations.
Definition at line 351 of file ossimSensorModelTuple.cpp.
358 {
359  // Temporary image geometry
360  ossimImageGeometry* iGeom = new ossimImageGeometry(NULL, (ossimProjection*) theImages[img].get());
361
362  // Evaluate residuals
363  ossimDpt computedImg;
364  iGeom->worldToLocal(ptEst, computedImg);
365  resid = obs - computedImg;
366
367  // Evaluate partials B(2X3)
368  NEWMAT::Matrix Bt(3,2);
369  iGeom->computeGroundToImagePartials(Bt, ptEst);
370  B = Bt.t();
371
372  // Get covariance matrix & form weight matrix
373  NEWMAT::SymmetricMatrix Cov(2);
375  covStatus = theImages[img]->getObsCovMat(obs,Cov);
376
377  if (covStatus == ossimSensorModel::COV_INVALID)
378  {
379  W = 0.0;
380  W(1,1) = 1.0;
381  W(2,2) = 1.0;
382  }
383  else
384  {
385  NEWMAT::Matrix Wfull = invert(Cov);
386  W << Wfull;
387  }
388
389  bool covOK = false;
390  if (covStatus == ossimSensorModel::COV_FULL)
391  covOK = true;
392
393  return covOK;
394 }
bool computeGroundToImagePartials(NEWMAT::Matrix &result, const ossimGpt &gpt, const ossimDpt3d &deltaLlh)
bool worldToLocal(const ossimGpt &world_pt, ossimDpt &local_pt) const
Exposes the 3D world-to-local image coordinate reverse projection.
◆ getRpcPqeInputs()
void ossimSensorModelTuple::getRpcPqeInputs ( ossimRpcPqeInputs obj) const
Parameters
objObject to initialize with rpc pqe inputs.
Definition at line 145 of file ossimSensorModelTuple.cpp.
References theRpcPqeInputs.
146 {
147  obj = theRpcPqeInputs;
148 }
◆ intersect() [1/3]
ossimSensorModelTuple::IntersectStatus ossimSensorModelTuple::intersect ( const DptSet_t  obs,
ossimEcefPoint pt,
) const
Parameters
obsVector of image point observations.
ptIntersected ECF position of point.
covMat3X3 ECF position covariance matrix [m].
Returns
Definition at line 173 of file ossimSensorModelTuple.cpp.
References OP_FAIL.
176 {
177  IntersectStatus opOK = OP_FAIL;
178  bool covOK = true;
179  bool epOK;
180  ossim_int32 nImages = (ossim_int32)obs.size();
181
182  if (nImages > 1)
183  {
184
185  // Matrices
186  NEWMAT::SymmetricMatrix N(3);
187  NEWMAT::SymmetricMatrix BtWB(3);
188  NEWMAT::Matrix Ni(3,3);
189  NEWMAT::ColumnVector C(3);
190  NEWMAT::ColumnVector BtWF(3);
191  NEWMAT::ColumnVector F(2);
192  NEWMAT::ColumnVector dR(3);
193  NEWMAT::Matrix B(2,3);
194  NEWMAT::SymmetricMatrix W(2);
195
196  // Get a priori ground estimate using first point
197  ossimGpt estG;
198  theImages[0]->lineSampleToWorld(obs[0], estG);
199
200  for (int iter=0; iter<5; iter++)
201  {
202  // cout<<"\n iter: "<<iter;
203
204  N = 0.0;
205  C = 0.0;
206
207  // Loop over observations
208  for (int i=0; i<nImages; i++)
209  {
210  ossimDpt resid;
211  if (!getGroundObsEqComponents(i, obs[i], estG, resid, B, W))
212  {
213  covOK = false;
214  }
215
216  F[0] = resid.x;
217  F[1] = resid.y;
218  // cout<<"\n F{"<<i+1<<"}: "<<F[0]<<", "<<F[1];
219
220  // Form coefficient matrix & discrepancy vector
221  BtWF << B.t() * W * F;
222  BtWB << B.t() * W * B;
223  C += BtWF;
224  N += BtWB;
225  }
226
227  // Solve system
228  Ni = invert(N);
229  dR = Ni * C;
230
231  // cout<<"\n dR: ("<<dR[0]<<", "<<dR[1]<<", "<<dR[2]<<")"<<endl;
232
233  // Update estimate
234  double latUpd = estG.latd() - dR[0];
235  double lonUpd = estG.lond() - dR[1];
236  double hgtUpd = estG.height() - dR[2];
237
238  estG.latd(latUpd);
239  estG.lond(lonUpd);
240  estG.height(hgtUpd);
241
242  if (traceDebug())
243  {
245  << "DEBUG: intersect:\n"
246  << " iteration:\n" << iter
247  // << " C:\n" << C
248  // << " Ni:\n" << Ni
249  << " dR:\n" << dR <<std::endl;
250  }
251
252  } // iterative loop
253
254  // Return intersected point
255  ossimEcefPoint finalEst(estG);
256  pt = finalEst;
257
258  // Return propagated covariance matrix
259  if (covOK)
260  {
261  covMat = Ni;
262  epOK = true;
263  }
264  else
265  epOK = false;
266
267  // Set operation status
268  if (epOK)
269  opOK = OP_SUCCESS;
270  else
271  opOK = ERROR_PROP_FAIL;
272  }
273
274  return opOK;
275 }
double lond() const
Will convert the radian measure to degrees.
Definition: ossimGpt.h:97
double y
double latd() const
Definition: ossimGpt.h:87
double height() const
Definition: ossimGpt.h:107
double x
int ossim_int32
◆ intersect() [2/3]
ossimSensorModelTuple::IntersectStatus ossimSensorModelTuple::intersect ( const ossim_int32 img,
const ossimDpt obs,
ossimEcefPoint pt,
Parameters
Returns
Definition at line 319 of file ossimSensorModelTuple.cpp.
References AT_DEM, computeSingleInterCov(), ERROR_PROP_FAIL, OP_FAIL, OP_SUCCESS, and theImages.
323 {
324  IntersectStatus opOK = OP_FAIL;
325  ossimGpt ptG;
326
327  // Intersection
328  theImages[img]->lineSampleToWorld(obs, ptG);
329  ossimEcefPoint ptECF(ptG);
330  pt = ptECF;
331
332  // Error propagation
333  bool epOK = computeSingleInterCov(img, obs, ptG, AT_DEM, covMat);
334
335  // Set operation status
336  if (epOK)
337  opOK = OP_SUCCESS;
338  else
339  opOK = ERROR_PROP_FAIL;
340
341  return opOK;
342 }
bool computeSingleInterCov(const ossim_int32 &img, const ossimDpt &obs, const ossimGpt &ptG, HeightRefType_t cRefType, NEWMAT::Matrix &covMat)
◆ intersect() [3/3]
const ossimDpt obs,
const ossim_float64 heightAboveEllipsoid,
ossimEcefPoint pt,
Parameters
heightAboveEllipsoidDesired intersection height [m].
Returns
: This method's "const" qualifier was removed as it stores rpc inputs to the pqe constructor for report purposes.
Definition at line 285 of file ossimSensorModelTuple.cpp.
References AT_HGT, computeSingleInterCov(), ERROR_PROP_FAIL, OP_FAIL, OP_SUCCESS, and theImages.
290 {
291  IntersectStatus opOK = OP_FAIL;
292  ossimGpt ptG;
293
294  // Intersection
295  theImages[img]->lineSampleHeightToWorld(obs, atHeightAboveEllipsoid, ptG);
296  ossimEcefPoint ptECF(ptG);
297  pt = ptECF;
298
299  // Error propagation
300  bool epOK = computeSingleInterCov(img, obs, ptG, AT_HGT, covMat);
301
302  // Set operation status
303  if (epOK)
304  opOK = OP_SUCCESS;
305  else
306  opOK = ERROR_PROP_FAIL;
307
308  return opOK;
309 }
◆ invert()
NEWMAT::Matrix ossimSensorModelTuple::invert ( const NEWMAT::Matrix &  m) const
private
Definition at line 623 of file ossimSensorModelTuple.cpp.
References SVD().
624 {
625  ossim_uint32 idx = 0;
626  NEWMAT::DiagonalMatrix d;
627  NEWMAT::Matrix u;
628  NEWMAT::Matrix v;
629
630  // decompose m.t*m into the singular values and vectors.
631  NEWMAT::SVD(m, d, u, v, true, true);
632
633  // invert the diagonal
634  for(idx=0; idx < (ossim_uint32)d.Ncols(); ++idx)
635  {
636  if(d[idx] > 1e-14) //TBC : use DBL_EPSILON ?
637  {
638  d[idx] = 1.0/d[idx];
639  }
640  else
641  {
642  d[idx] = 0.0;
643  if (traceDebug())
644  {
646  << "DEBUG: ossimSensorModelTuple::invert(): "
647  << "\nsingular matrix in SVD..."
648  << std::endl;
649  }
650  }
651  }
652
653  //compute inverse of decomposed m;
654  return v*d*u.t();
655 }
unsigned int ossim_uint32
void SVD(const Matrix &, DiagonalMatrix &, Matrix &, Matrix &, bool=true, bool=true)
Definition: svd.cpp:26
◆ print()
std::ostream & ossimSensorModelTuple::print ( std::ostream &  out) const
print method.
Definition at line 156 of file ossimSensorModelTuple.cpp.
157 {
158  out << "\n ossimSensorModelTuple::print:" << std::endl;
159  for (int i=0; i<theNumImages; ++i)
160  theImages[i]->print(out);
161
162  return out;
163 }
std::ostream & print(std::ostream &out) const
print method.
◆ setIntersectionSurfaceAccuracy()
bool ossimSensorModelTuple::setIntersectionSurfaceAccuracy ( const ossim_float64 surfCE90,
const ossim_float64 surfLE90
Parameters
surfCE9090% CE [m].
surfLE9090% LE [m].
Returns
true on success, false on exception. Entry of negative value(s) indicates "no DEM" error prop for RPC
Definition at line 110 of file ossimSensorModelTuple.cpp.
References theSurfAccRepresentsNoDEM, theSurfAccSet, theSurfCE90, and theSurfLE90.
112 {
113  bool setOK = false;
114
115  if (surfCE90>=0.0 && surfLE90>=0.0)
116  {
117  theSurfCE90 = surfCE90;
118  theSurfLE90 = surfLE90;
119  theSurfAccSet = true;
121  setOK = true;
122  }
123  else
124  {
125  //***************************************************************
126  // RPC_No_DEM_State Demo case
127  // In this case, surfCE90/surfLE90 are interpreted differently:
128  // [1] surfCE90 contains the scale divisor for RPC hgtScale
129  // [2] surfLE90 contains the probability level divisor for
130  // RPC hgtScale to yield a 1-sigma value
131  // These coputations are performed in computeSingleInterCov.
132  //***************************************************************
133  theSurfCE90 = surfCE90;
134  theSurfLE90 = surfLE90;
135  theSurfAccSet = false;
137  setOK = true;
138  }
139
140  return setOK;
141 }
Member Data Documentation
◆ theImages
std::vector<ossimRefPtr<ossimSensorModel> > ossimSensorModelTuple::theImages
mutableprivate
Definition at line 146 of file ossimSensorModelTuple.h.
Referenced by addImage(), intersect(), and print().
◆ theNumImages
ossim_int32 ossimSensorModelTuple::theNumImages
private
Definition at line 148 of file ossimSensorModelTuple.h.
Referenced by addImage(), and print().
◆ theRpcPqeInputs
ossimRpcPqeInputs ossimSensorModelTuple::theRpcPqeInputs
private
Definition at line 158 of file ossimSensorModelTuple.h.
Referenced by getRpcPqeInputs().
◆ theSurfAccRepresentsNoDEM
bool ossimSensorModelTuple::theSurfAccRepresentsNoDEM
private
Definition at line 153 of file ossimSensorModelTuple.h.
Referenced by setIntersectionSurfaceAccuracy().
◆ theSurfAccSet
bool ossimSensorModelTuple::theSurfAccSet
private
Definition at line 152 of file ossimSensorModelTuple.h.
◆ theSurfCE90
ossim_float64 ossimSensorModelTuple::theSurfCE90
private
Definition at line 150 of file ossimSensorModelTuple.h.
◆ theSurfLE90
ossim_float64 ossimSensorModelTuple::theSurfLE90
private
Definition at line 151 of file ossimSensorModelTuple.h.
