Public Member Functions | Protected Attributes | List of all members
ossimTangentialRadialLensDistortion Class Reference
#include <ossimTangentialRadialLensDistortion.h>
Inheritance diagram for ossimTangentialRadialLensDistortion:
ossimLensDistortion ossim2dTo2dTransform ossimObject ossimReferenced
 ossimTangentialRadialLensDistortion ()
 ossimTangentialRadialLensDistortion (const ossimDpt &calibratedCenter, double k1=0.0, double k2=0.0, double k3=0.0, double p1=0.0, double p2=0.0)
 ossimTangentialRadialLensDistortion (const ossimDpt &calibratedCenter, std::vector< double > k, std::vector< double > p)
 Generic print method. More...
virtual void undistort (const ossimDpt &input, ossimDpt &output) const
- Public Member Functions inherited from ossimLensDistortion
 ossimLensDistortion (const ossimDpt &callibratedCenter=ossimDpt(0, 0))
void setCenter (const ossimDpt &center)
const ossimDptgetCenter () const
virtual void forward (const ossimDpt &input, ossimDpt &output) const
virtual void inverse (const ossimDpt &input, ossimDpt &output)
virtual void distort (const ossimDpt &input, ossimDpt &output) const
- Public Member Functions inherited from ossim2dTo2dTransform
virtual void forward (ossimDpt &modify_this) const
virtual void inverse (const ossimDpt &input, ossimDpt &output) const
virtual void inverse (ossimDpt &modify_this) const
virtual const ossim2dTo2dTransformoperator= (const ossim2dTo2dTransform &rhs)
virtual ossimDpt getOrigin () const
void setConvergenceThreshold (const double &new_threshold)
void setMaxIterations (int new_max_iters)
void setDxDy (const ossimDpt &dxdy)
 ossimObject ()
virtual ~ossimObject ()
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
std::vector< ossim_float64m_k
std::vector< ossim_float64m_p
- Protected Attributes inherited from ossimLensDistortion
ossimDpt theCenter
- Protected Attributes inherited from ossim2dTo2dTransform
double theConvergenceThreshold
int theMaxIterations
ossimDpt theDxDy
Additional Inherited Members
- Protected Member Functions inherited from ossim2dTo2dTransform
 ossim2dTo2dTransform ()
virtual ~ossim2dTo2dTransform ()
virtual ~ossimReferenced ()
Detailed Description
Definition at line 33 of file ossimTangentialRadialLensDistortion.h.
◆ ossimTangentialRadialLensDistortion() [1/3]
ossimTangentialRadialLensDistortion::ossimTangentialRadialLensDistortion ( )
Definition at line 7 of file ossimTangentialRadialLensDistortion.cpp.
References m_k, and m_p.
9 {
10  m_k.resize(3);
11  m_p.resize(2);
12  m_k[0] = m_k[1] = m_k[2] = 0.0;
13  m_p[0] = m_p[1];
14 }
ossimLensDistortion(const ossimDpt &callibratedCenter=ossimDpt(0, 0))
◆ ossimTangentialRadialLensDistortion() [2/3]
ossimTangentialRadialLensDistortion::ossimTangentialRadialLensDistortion ( const ossimDpt calibratedCenter,
double  k1 = 0.0,
double  k2 = 0.0,
double  k3 = 0.0,
double  p1 = 0.0,
double  p2 = 0.0
Definition at line 15 of file ossimTangentialRadialLensDistortion.cpp.
18  :ossimLensDistortion(calibratedCenter)
19  {
20
21  m_k.resize(3);
22  m_p.resize(2);
23
24  m_k[0] = k1;
25  m_k[1] = k2;
26  m_k[2] = k3;
27
28  m_p[0] = p1;
29  m_p[1] = p2;
30
31
32 }
◆ ossimTangentialRadialLensDistortion() [3/3]
Definition at line 33 of file ossimTangentialRadialLensDistortion.cpp.
36  :ossimLensDistortion(calibratedCenter),
37  m_k(k),
38  m_p(p)
39 {
40 }
Member Function Documentation
◆ loadState()
bool ossimTangentialRadialLensDistortion::loadState ( const ossimKeywordlist kwl,
const char *  prefix = 0
virtual
Reimplemented from ossimLensDistortion.
Definition at line 90 of file ossimTangentialRadialLensDistortion.cpp.
References ossimKeywordlist::find(), ossimLensDistortion::loadState(), m_k, m_p, and ossim::toSimpleVector().
92 {
93  bool result = ossimLensDistortion::loadState(kwl, prefix);
94  ossimString k = kwl.find(prefix, "k");
95  ossimString p = kwl.find(prefix, "p");
96
97  m_k.clear();
98  m_p.clear();
101
102  return result;
103 }
bool toSimpleVector(std::vector< T > &result, const ossimString &stringOfPoints)
Definition: ossimCommon.h:537
◆ print()
virtual std::ostream& ossimTangentialRadialLensDistortion::print ( std::ostream &  out) const
inlinevirtual
Derived classes should re-implement as they see fit.
Returns
std::ostream&
Reimplemented from ossim2dTo2dTransform.
Definition at line 46 of file ossimTangentialRadialLensDistortion.h.
47  {return out;}
◆ saveState()
bool ossimTangentialRadialLensDistortion::saveState ( ossimKeywordlist kwl,
) const
virtual
Method to save the state of the object to a keyword list. Return true if ok or false on error.
Definition at line 75 of file ossimTangentialRadialLensDistortion.cpp.
References ossimKeywordlist::add(), m_k, m_p, ossimLensDistortion::saveState(), and ossim::toSimpleStringList().
Referenced by ossimSpectraboticsRedEdgeModel::saveState().
77 {
78  bool result = ossimLensDistortion::saveState(kwl, prefix);
79  ossimString kValues;
80  ossimString pValues;
83
84  kwl.add(prefix, "k", kValues);
85  kwl.add(prefix, "p", pValues);
86
87  return result;
88 }
void toSimpleStringList(ossimString &result, const std::vector< T > &valuesList)
This will output a vector of values inst a string.
Definition: ossimCommon.h:484
◆ undistort()
void ossimTangentialRadialLensDistortion::undistort ( const ossimDpt input,
ossimDpt output
) const
virtual
Implements ossimLensDistortion.
Definition at line 42 of file ossimTangentialRadialLensDistortion.cpp.
References m_k, m_p, ossimDpt::x, and ossimDpt::y.
44 {
45  // make relative to calibrated center
46  //ossimDpt deltaPosition(input.x - theCenter.x,
47  // input.y - theCenter.y);
48
49  double r = sqrt(input.x*input.x +
50  input.y*input.y);
51  double r2 = r*r;
52  double rMultiplier = r2;
53  ossim_uint32 idx = 0;
54  // comnpute the radial portion of the equation of the form
55  // 1 + k0*r^2 + k1*r^4 + .......
56  double tempRadial = 1.0;
57  for(idx = 0; idx < m_k.size();++idx)
58  {
59  tempRadial += m_k[idx]*rMultiplier;
60  rMultiplier*=r2;
61  }
62  // now apply the radial to the input point and then
63  // shift and apply the tangential coefficients along x and y.
64  output.x = (input.x*tempRadial) +
65  (2.0*m_p[0]*input.x*input.y) +
66  (m_p[1]*(r2 + 2*input.x*input.x));
67
68  output.y = (input.y*tempRadial) +
69  (2.0*m_p[1]*input.x*input.y) +
70  (m_p[0]*(r2 + 2*input.y*input.y));
71
72 // output.x += theCenter.x;
73 // output.y += theCenter.y;
74 }
double y
Definition: ossimDpt.h:165
unsigned int ossim_uint32
double x
Definition: ossimDpt.h:164
Member Data Documentation
◆ m_k
std::vector<ossim_float64> ossimTangentialRadialLensDistortion::m_k
protected
◆ m_p
std::vector<ossim_float64> ossimTangentialRadialLensDistortion::m_p
protected
