Public Member Functions | List of all members
ossimViirsHandler Class Reference
Concrete class for reading VIIRS data from HDF5 file. More...
#include <ossimViirsHandler.h>
Inheritance diagram for ossimViirsHandler:
ossimHdf5ImageHandler ossimHdf5ImageHandler ossimImageHandler ossimImageHandler ossimImageSource ossimImageSource ossimSource ossimSource ossimConnectableObject ossimErrorStatusInterface ossimConnectableObject ossimErrorStatusInterface ossimObject ossimListenerManager ossimPropertyInterface ossimObject ossimListenerManager ossimPropertyInterface ossimReferenced ossimReferenced
 ossimViirsHandler ()
- Public Member Functions inherited from ossimHdf5ImageHandler
 ossimHdf5ImageHandler ()
 default constructor More...
virtual ~ossimHdf5ImageHandler ()
 virtual destructor More...
 Returns a pointer to a tile given an origin representing the upper left corner of the tile to grab from the image. More...
 Method to get a tile. More...
 Returns the number of bands in the image. More...
virtual ossim_uint32 getNumberOfLines (ossim_uint32 reduced_res_level=0) const
 Returns the number of lines in the image. More...
virtual ossim_uint32 getNumberOfSamples (ossim_uint32 reduced_res_level=0) const
 Returns the number of samples in the image. More...
virtual ossimIrect getImageRectangle (ossim_uint32 reduced_res_level=0) const
 Returns the zero based image rectangle for the reduced resolution data set (rrds) passed in. More...
 Returns the output pixel type of the tile source. More...
virtual bool isOpen () const
virtual void close ()
 Close method. More...
virtual void loadMetaData ()
ossimRefPtr< ossimHdf5ImageDatasetgetCurrentDataset ()
 Set propterty method. More...
 Get propterty method. More...
 Get propterty names. More...
virtual bool open ()
 The derived class needs to initialize the raster dataset names m_renderableNames in their constructor, for this method to work. More...
const std::vector< ossimString > & getRenderableSetNames ()
void addRenderable (const ossimString &datasetName)
 Adds the dataset name, either the full HDF5 path or the simple object name, to the list of renderable datasets. More...
 ossimImageHandler ()
virtual ~ossimImageHandler ()
virtual void initialize ()
virtual bool openOverview ()
virtual void closeOverview ()
 Opens the image file. More...
 Sets the filename. More...
 Returns the filename. More...
virtual bool isValidRLevel (ossim_uint32 resLevel) const
 Connection rule. More...
virtual bool hasLut () const
bool useEntryIndex () const
 Fetches the image ID. More...
template<class T >
template<class T >
virtual ~ossimImageSource ()
 For RTTI support. More...
 Initializes bandList. More...
virtual ~ossimSource ()
virtual void enableSource ()
virtual void disableSource ()
const ossimIdgetId () const
 ossimObject ()
virtual ~ossimObject ()
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
 ossimListenerManager ()
 ossimPropertyInterface ()
 ossimErrorStatusInterface ()
bool hasError () const
Additional Inherited Members
- Protected Member Functions inherited from ossimHdf5ImageHandler
void allocate ()
 Allocates the tile. More...
virtual void completeOpen ()
virtual ~ossimReferenced ()
- Protected Attributes inherited from ossimHdf5ImageHandler
std::vector< ossimStringm_renderableNames
ossimRefPtr< ossimHdf5m_hdf5
std::vector< ossimRefPtr< ossimHdf5ImageDataset > > m_entries
ossim_uint32 m_currentEntry
std::mutex m_mutex
ossimFilename theImageFile
ossimFilename theOverviewFile
ossimString theImageID
bool theOpenOverviewFlag
ossimPixelType thePixelType
bool theEnableFlag
bool theInitializedFlag
ossimId theId
ossimString theDescription
ossimObjecttheOwner
bool theInputListIsFixedFlag
bool theOutputListIsFixedFlag
bool theEnabledFlag
bool theFireEventFlag
ossimErrorCode theErrorStatus
Detailed Description
Definition at line 21 of file include/ossim/hdf5/ossimViirsHandler.h.
◆ ossimViirsHandler() [1/2]
ossimViirsHandler::ossimViirsHandler ( )
Definition at line 15 of file src/hdf5/ossimViirsHandler.cpp.
References ossimHdf5ImageHandler::m_renderableNames.
16 {
17  m_renderableNames.push_back(VIIRS_DATASET);
18 }
std::vector< ossimString > m_renderableNames
◆ ossimViirsHandler() [2/2]
Member Function Documentation
◆ getImageGeometry() [1/2]
ossimRefPtr< ossimImageGeometry > ossimViirsHandler::getImageGeometry ( )
virtual
The geometry contains full-to-local image transform as well as projection (image-to-world).
Definition at line 20 of file src/hdf5/ossimViirsHandler.cpp.
References ossimRefPtr< T >::get(), ossimImageHandler::getExternalImageGeometry(), ossimHdf5GridModel::initialize(), ossimHdf5ImageHandler::isOpen(), ossimHdf5ImageHandler::m_hdf5, ossimImageHandler::theGeometry, and ossimRefPtr< T >::valid().
21 {
22  if (theGeometry.valid())
23  return theGeometry;
24
26  if (!theGeometry.valid() && isOpen())
27  {
29
30  // Attempt to create an OSSIM coarse grid model from HDF5 lat lon grids:
32  if ( hdf5GridModel->initialize(m_hdf5.get(), VIIRS_GEOMETRY) )
33  {
34  theGeometry->setProjection(hdf5GridModel.get());
36  }
37  else
38  theGeometry = 0;
39  }
40
41  return theGeometry;
42 }
ossimRefPtr< ossimImageGeometry > theGeometry
void setProjection(ossimProjection *projection)
Sets the projection to be used for local-to-world coordinate transformation.
bool valid() const
Definition: ossimRefPtr.h:75
ossimRefPtr< ossimHdf5 > m_hdf5
bool initialize(ossimHdf5 *hdf5, const ossimString &projDataPath="")
Initializes from an open HDF5 file.
void initImageParameters(ossimImageGeometry *geom) const
Convenience method to set things needed in the image geometry from the image handler.
virtual bool isOpen() const
virtual ossimRefPtr< ossimImageGeometry > getExternalImageGeometry() const
Returns the image geometry object associated with this tile source or NULL if non defined...
◆ getImageGeometry() [2/2]
virtual ossimRefPtr<ossimImageGeometry> ossimViirsHandler::getImageGeometry ( )
virtual
◆ getNullPixelValue() [1/2]
virtual double ossimViirsHandler::getNullPixelValue ( ossim_uint32  band = 0) const
virtual
Returns
Null pixel value.
Reimplemented from ossimHdf5ImageHandler.
◆ getNullPixelValue() [2/2]
virtual
Returns
Null pixel value.
Definition at line 45 of file src/hdf5/ossimViirsHandler.cpp.
46 {
47  // NPP VIIRS data has null of "-999.3".
48  return -999.3;
49 }
