Public Member Functions | Static Public Member Functions | Protected Member Functions | Protected Attributes | Static Protected Attributes | List of all members
ossim::CurlStreamFactory Class Reference
#include <ossimCurlStreamFactory.h>
Inheritance diagram for ossim::CurlStreamFactory:
ossim::StreamFactoryBase
virtual ~CurlStreamFactory ()
virtual std::shared_ptr< ossim::istreamcreateIstream (const std::string &connectionString, const ossimKeywordlist &options, std::ios_base::openmode openMode) const
virtual std::shared_ptr< ossim::ostreamcreateOstream (const std::string &connectionString, const ossimKeywordlist &options, std::ios_base::openmode openMode) const
virtual std::shared_ptr< ossim::iostreamcreateIOstream (const std::string &connectionString, const ossimKeywordlist &options, std::ios_base::openmode openMode) const
virtual bool exists (const std::string &connectionString, bool &continueFlag) const
 Methods to test if connection exists. More...
- Public Member Functions inherited from ossim::StreamFactoryBase
virtual ~StreamFactoryBase ()
static CurlStreamFactoryinstance ()
 CurlStreamFactory (const CurlStreamFactory &)
ossimCurlHttpRequest m_curlHttpRequest
static CurlStreamFactorym_instance = 0
Detailed Description
Definition at line 20 of file ossimCurlStreamFactory.h.
◆ ~CurlStreamFactory()
ossim::CurlStreamFactory::~CurlStreamFactory ( )
virtual
Definition at line 20 of file ossimCurlStreamFactory.cpp.
21 {
22 }
◆ CurlStreamFactory() [1/2]
ossim::CurlStreamFactory::CurlStreamFactory ( )
protected
Definition at line 113 of file ossimCurlStreamFactory.cpp.
115 {
116 }
◆ CurlStreamFactory() [2/2]
ossim::CurlStreamFactory::CurlStreamFactory ( const CurlStreamFactory )
protected
Definition at line 119 of file ossimCurlStreamFactory.cpp.
121 {
122 }
Member Function Documentation
◆ createIOstream()
std::shared_ptr< ossim::iostream > ossim::CurlStreamFactory::createIOstream ( const std::string &  connectionString,
const ossimKeywordlist options,
) const
virtual
Implements ossim::StreamFactoryBase.
Definition at line 77 of file ossimCurlStreamFactory.cpp.
81 {
82  return std::shared_ptr<ossim::iostream>(0);
83 }
◆ createIstream()
std::shared_ptr< ossim::istream > ossim::CurlStreamFactory::createIstream ( const std::string &  connectionString,
) const
virtual
Definition at line 34 of file ossimCurlStreamFactory.cpp.
38 {
39  //std::cout << "ossim::CurlStreamFactory::createIstream............Entered\n";
40  std::shared_ptr<ossim::CurlIStream> result = std::make_shared<ossim::CurlIStream>();
41  if(traceDebug())
42  {
43  ossimNotify(ossimNotifyLevel_WARN) << "ossim::AwsStreamFactory::createIstream: Entered...............\n";
44  }
45  //---
46  // Hack for upstream code calling ossimFilename::convertToNative()
47  // wrecking s3 url.
48  //---
49 #if defined(_WIN32)
50  ossimFilename f = connectionString;
51  f.convertBackToForwardSlashes();
52  result->open( f.string(), openMode) ;
53 #else
54  result->open( connectionString, openMode );
55 #endif
56
57  if(!result->good())
58  {
59  result.reset();
60  }
61  if(traceDebug())
62  {
63  ossimNotify(ossimNotifyLevel_WARN) << "ossim::CurlStreamFactory::createIstream: Leaving...............\n";
64  }
65
66  return result;
67 }
const std::string & string() const
Definition: ossimString.h:414
◆ createOstream()
std::shared_ptr< ossim::ostream > ossim::CurlStreamFactory::createOstream ( const std::string &  connectionString,
) const
virtual
Definition at line 69 of file ossimCurlStreamFactory.cpp.
73 {
74  return std::shared_ptr<ossim::ostream>(0);
75 }
◆ exists()
bool ossim::CurlStreamFactory::exists ( const std::string &  connectionString,
bool &  continueFlag
) const
virtual
Parameters
connectionString
continueFlagInitializes by this, if set to false, indicates factory handles file/url and no more factory checks are necessary. If true, connection is not handled by this factory.
Returns
true on success, false, if not.
Definition at line 85 of file ossimCurlStreamFactory.cpp.
References ossimUrl::getProtocol(), and ossimHttpRequest::set().
87 {
88  bool result = false;
89  if ( connectionString.size() )
90  {
91  ossimUrl url(connectionString);
92
93  if( (url.getProtocol() == "http") || (url.getProtocol() == "https") )
94  {
95  continueFlag = false; // Set to false to stop registry search.
96
97  ossimKeywordlist header;
98  ossim_int64 filesize;
99  ossimCurlHttpRequest curlHttpRequest;
100  curlHttpRequest.set(url, header);
101  filesize = m_curlHttpRequest.getContentLength();
102  if ( filesize )
103  {
104  result = true;
105  }
106  }
107
108  }
109  return result;
110 }
ossim_int64 getContentLength() const
bool set(const ossimUrl &url, const ossimKeywordlist &headerOptions, HttpMethodType methodType=HTTP_METHOD_GET)
long long ossim_int64
◆ instance()
ossim::CurlStreamFactory * ossim::CurlStreamFactory::instance ( )
static
Definition at line 24 of file ossimCurlStreamFactory.cpp.
Referenced by ossimSharedLibraryInitialize().
25 {
26  if(!m_instance)
27  {
29  }
30
31  return m_instance;
32 }
static CurlStreamFactory * m_instance
Member Data Documentation
◆ m_curlHttpRequest
ossimCurlHttpRequest ossim::CurlStreamFactory::m_curlHttpRequest
protected
Definition at line 60 of file ossimCurlStreamFactory.h.
◆ m_instance
ossim::CurlStreamFactory * ossim::CurlStreamFactory::m_instance = 0
staticprotected
Definition at line 62 of file ossimCurlStreamFactory.h.
