Public Member Functions | Public Attributes | Friends | List of all members
ossimplugins::GeolocationGrid Class Reference
This class is able to read the ASAR GeolocationGrid record. More...
#include <GeolocationGrid.h>
Inheritance diagram for ossimplugins::GeolocationGrid:
ossimplugins::EnvisatAsarRecord
 GeolocationGrid ()
 Constructor. More...
virtual ~GeolocationGrid ()
 Destructor. More...
 GeolocationGrid (const GeolocationGrid &rhs)
 Copy constructor. More...
GeolocationGridoperator= (const GeolocationGrid &rhs)
 Copy operator. More...
EnvisatAsarRecordInstanciate ()
 This function is able to create a new instance of the class. More...
EnvisatAsarRecordClone ()
 This function is able to create a new instance of the class initialised with the data of the calling instance. More...
void Read (std::istream &is)
 Reads the class data from a stream. More...
void Write (std::ostream &os)
 Writes the class to a stream. More...
int get_first_zero_doppler_time_day ()
 first_zero_doppler_time day More...
unsigned int get_first_zero_doppler_time_sec ()
 first_zero_doppler_time second More...
unsigned int get_first_zero_doppler_time_microsec ()
 first_zero_doppler_time micro sec More...
bool get_attach_flag ()
 attach_flag More...
unsigned int get_line_num ()
 line_num More...
unsigned int get_num_lines ()
 num_lines More...
float get_sub_sat_track ()
 sub_sat_track More...
unsigned int * get_samp_numbers ()
 samp_numbvers More...
float * get_slant_range_times ()
 slant_range_times More...
float * get_angles ()
 angles More...
int * get_lats ()
 lats More...
int * get_longs ()
 longs More...
std::string get_last_zero_doppler_time ()
 last_zero_doppler_time More...
std::string get_last_line_tie_points ()
 last_line_tie_points More...
- Public Member Functions inherited from ossimplugins::EnvisatAsarRecord
 EnvisatAsarRecord (std::string mnemonic)
virtual ~EnvisatAsarRecord ()
 Destructor. More...
 EnvisatAsarRecord (const EnvisatAsarRecord &rhs)
std::string get_mnemonic ()
 Returns the mnemonic of the record. More...
Public Attributes
int _first_zero_doppler_time_day
unsigned int _first_zero_doppler_time_sec
 first_zero_doppler_time sec More...
unsigned int _first_zero_doppler_time_microsec
 first_zero_doppler_time microsec More...
bool _attach_flag
 attach_flag More...
unsigned int _line_num
 line_num More...
unsigned int _num_lines
 num_lines More...
float _sub_sat_track
unsigned int _samp_numbers [11]
 samp_numbers More...
float _slant_range_times [11]
 slant_range_times[11] More...
float _angles [11]
 angles[11] More...
int _lats [11]
 lats[11] More...
int _longs [11]
 longs[11] More...
std::string _last_zero_doppler_time
std::string _last_line_tie_points
Friends
std::ostream & operator<< (std::ostream &os, const GeolocationGrid &data)
 This function writes the GeolocationGrid in a stream. More...
std::istream & operator>> (std::istream &is, GeolocationGrid &data)
 This function reads a GeolocationGrid from a stream. More...
Additional Inherited Members
- Protected Member Functions inherited from ossimplugins::EnvisatAsarRecord
template<typename T >
void SwitchEndian (T &value)
 This function switches the LSB value and the MSB value of the parameter. More...
- Protected Attributes inherited from ossimplugins::EnvisatAsarRecord
std::string _mnemonic
Detailed Description
Definition at line 24 of file GeolocationGrid.h.
◆ GeolocationGrid() [1/2]
ossimplugins::GeolocationGrid::GeolocationGrid ( )
Constructor.
Definition at line 16 of file GeolocationGrid.cpp.
Referenced by Clone(), and Instanciate().
16  : EnvisatAsarRecord("GeolocationGrid_rec")
17  {
18  }
EnvisatAsarRecord(std::string mnemonic)
Constructor.
◆ ~GeolocationGrid()
ossimplugins::GeolocationGrid::~GeolocationGrid ( )
virtual
Destructor.
Definition at line 20 of file GeolocationGrid.cpp.
21  {
22  }
◆ GeolocationGrid() [2/2]
ossimplugins::GeolocationGrid::GeolocationGrid ( const GeolocationGrid rhs)
Copy constructor.
Definition at line 170 of file GeolocationGrid.cpp.
References _angles, _lats, _longs, _samp_numbers, and _slant_range_times.
170  :
171  EnvisatAsarRecord(rhs),
172  _first_zero_doppler_time_day(rhs._first_zero_doppler_time_day),
173  _first_zero_doppler_time_sec(rhs._first_zero_doppler_time_sec),
174  _first_zero_doppler_time_microsec(rhs._first_zero_doppler_time_microsec),
175  _attach_flag(rhs._attach_flag),
176  _line_num(rhs._line_num),
177  _num_lines(rhs._num_lines),
178  _sub_sat_track(rhs._sub_sat_track),
179  _last_zero_doppler_time(rhs._last_zero_doppler_time),
180  _last_line_tie_points(rhs._last_line_tie_points)
181  {
182
183  for (int i = 0; i<11; i++) {
184  _samp_numbers[i] = rhs._samp_numbers[i];
185  _slant_range_times[i] = rhs._slant_range_times[i];
186  _angles[i] = rhs._angles[i];
187  _lats[i] = rhs._lats[i];
188  _longs[i] = rhs._longs[i];
189  }
190
191
192  }
float _slant_range_times[11]
unsigned int _samp_numbers[11]
samp_numbers
float _angles[11]
angles[11]
sub_sat_track
line_num
Constructor.
num_lines
Member Function Documentation
◆ Clone()
EnvisatAsarRecord* ossimplugins::GeolocationGrid::Clone ( )
inlinevirtual
Implements ossimplugins::EnvisatAsarRecord.
Definition at line 68 of file GeolocationGrid.h.
References GeolocationGrid().
69  {
70  return new GeolocationGrid(*this);
71  };
◆ get_angles()
float* ossimplugins::GeolocationGrid::get_angles ( )
inline
angles
Definition at line 155 of file GeolocationGrid.h.
References _angles.
156  {
157  return _angles;
158  };
float _angles[11]
angles[11]
◆ get_attach_flag()
bool ossimplugins::GeolocationGrid::get_attach_flag ( )
inline
attach_flag
Definition at line 113 of file GeolocationGrid.h.
References _attach_flag.
114  {
115  return _attach_flag;
116  };
◆ get_first_zero_doppler_time_day()
int ossimplugins::GeolocationGrid::get_first_zero_doppler_time_day ( )
inline
Definition at line 92 of file GeolocationGrid.h.
References _first_zero_doppler_time_day.
Referenced by ossimplugins::ossimEnvisatAsarModel::saveState().
93  {
95  };
◆ get_first_zero_doppler_time_microsec()
unsigned int ossimplugins::GeolocationGrid::get_first_zero_doppler_time_microsec ( )
inline
Definition at line 106 of file GeolocationGrid.h.
References _first_zero_doppler_time_microsec.
107  {
109  };
◆ get_first_zero_doppler_time_sec()
unsigned int ossimplugins::GeolocationGrid::get_first_zero_doppler_time_sec ( )
inline
Definition at line 99 of file GeolocationGrid.h.
References _first_zero_doppler_time_sec.
100  {
102  };
◆ get_last_line_tie_points()
std::string ossimplugins::GeolocationGrid::get_last_line_tie_points ( )
inline
Definition at line 183 of file GeolocationGrid.h.
References _last_line_tie_points.
184  {
185  return _last_line_tie_points;
186  };
◆ get_last_zero_doppler_time()
std::string ossimplugins::GeolocationGrid::get_last_zero_doppler_time ( )
inline
Definition at line 176 of file GeolocationGrid.h.
References _last_zero_doppler_time.
177  {
179  };
◆ get_lats()
int* ossimplugins::GeolocationGrid::get_lats ( )
inline
lats
Definition at line 162 of file GeolocationGrid.h.
References _lats.
163  {
164  return _lats;
165  };
◆ get_line_num()
unsigned int ossimplugins::GeolocationGrid::get_line_num ( )
inline
line_num
Definition at line 120 of file GeolocationGrid.h.
References _line_num.
121  {
122  return _line_num;
123  };
line_num
◆ get_longs()
int* ossimplugins::GeolocationGrid::get_longs ( )
inline
longs
Definition at line 169 of file GeolocationGrid.h.
References _longs.
170  {
171  return _longs;
172  };
◆ get_num_lines()
unsigned int ossimplugins::GeolocationGrid::get_num_lines ( )
inline
num_lines
Definition at line 127 of file GeolocationGrid.h.
References _num_lines.
128  {
129  return _num_lines;
130  };
num_lines
◆ get_samp_numbers()
unsigned int* ossimplugins::GeolocationGrid::get_samp_numbers ( )
inline
samp_numbvers
Definition at line 141 of file GeolocationGrid.h.
References _samp_numbers.
142  {
143  return _samp_numbers;
144  };
samp_numbers
◆ get_slant_range_times()
float* ossimplugins::GeolocationGrid::get_slant_range_times ( )
inline
slant_range_times
Definition at line 148 of file GeolocationGrid.h.
References _slant_range_times.
149  {
150  return _slant_range_times;
151  };
◆ get_sub_sat_track()
float ossimplugins::GeolocationGrid::get_sub_sat_track ( )
inline
sub_sat_track
Definition at line 134 of file GeolocationGrid.h.
References _sub_sat_track.
135  {
136  return _sub_sat_track;
137  };
sub_sat_track
◆ Instanciate()
EnvisatAsarRecord* ossimplugins::GeolocationGrid::Instanciate ( )
inlinevirtual
Definition at line 60 of file GeolocationGrid.h.
61  {
62  return new GeolocationGrid();
63  };
◆ operator=()
GeolocationGrid & ossimplugins::GeolocationGrid::operator= ( const GeolocationGrid rhs)
Copy operator.
Definition at line 195 of file GeolocationGrid.cpp.
References _angles, _attach_flag, _first_zero_doppler_time_day, _first_zero_doppler_time_microsec, _first_zero_doppler_time_sec, _last_line_tie_points, _last_zero_doppler_time, _lats, _line_num, _longs, _num_lines, _samp_numbers, _slant_range_times, and _sub_sat_track.
196  {
197  _first_zero_doppler_time_day = rhs._first_zero_doppler_time_day;
198  _first_zero_doppler_time_sec = rhs._first_zero_doppler_time_sec;
199  _first_zero_doppler_time_microsec = rhs._first_zero_doppler_time_microsec;
200  _attach_flag = rhs._attach_flag;
201  _line_num = rhs._line_num;
202  _num_lines = rhs._num_lines;
203  _sub_sat_track = rhs._sub_sat_track;
204  _last_zero_doppler_time = rhs._last_zero_doppler_time;
205  _last_line_tie_points = rhs._last_line_tie_points;
206
207  for (int i = 0; i<11; i++) {
208  _samp_numbers[i] = rhs._samp_numbers[i];
209  _slant_range_times[i] = rhs._slant_range_times[i];
210  _angles[i] = rhs._angles[i];
211  _lats[i] = rhs._lats[i];
212  _longs[i] = rhs._longs[i];
213  }
214
215  return *this;
216  }
samp_numbers
float _angles[11]
angles[11]
sub_sat_track
line_num
num_lines
◆ Read()
void ossimplugins::GeolocationGrid::Read ( std::istream &  is)
inlinevirtual
Definition at line 76 of file GeolocationGrid.h.
77  {
78  is>>*this;
79  };
◆ Write()
void ossimplugins::GeolocationGrid::Write ( std::ostream &  os)
inlinevirtual
Definition at line 84 of file GeolocationGrid.h.
85  {
86  os<<*this;
87  };
◆ operator<<
std::ostream& operator<< ( std::ostream &  os,
const GeolocationGrid data
friend
Definition at line 25 of file GeolocationGrid.cpp.
26  {
27  os<<"first_zero_doppler_time_day:"<<data._first_zero_doppler_time_day<<std::endl;
28
29  os<<"first_zero_doppler_time_sec:"<<data._first_zero_doppler_time_sec<<std::endl;
30
31  os<<"first_zero_doppler_time_microsec:"<<data._first_zero_doppler_time_microsec<<std::endl;
32
33  os<<"attach_flag:"<<data._attach_flag<<std::endl;
34
35  os<<"line_num:"<<data._line_num<<std::endl;
36
37  os<<"num_lines:"<<data._num_lines<<std::endl;
38
39  os<<"sub_sat_track:"<<data._sub_sat_track<<std::endl;
40
41  for (int i = 0; i<11; i++) {
42  os<<"samp_numbers["<<i<<"]:"<<data._samp_numbers[i]<<std::endl;
43  }
44
45  for (int i = 0; i<11; i++) {
46  os<<"slant_range_times["<<i<<"]:"<<data._slant_range_times[i]<<std::endl;
47  }
48
49  for (int i = 0; i<11; i++) {
50  os<<"angles["<<i<<"]:"<<data._angles[i]<<std::endl;
51  }
52
53  for (int i = 0; i<11; i++) {
54  os<<"lats["<<i<<"]:"<<data._lats[i]<<std::endl;
55  }
56
57  for (int i = 0; i<11; i++) {
58  os<<"longs["<<i<<"]:"<<data._longs[i]<<std::endl;
59  }
60
61  os<<"last_zero_doppler_time:"<<data._last_zero_doppler_time.c_str()<<std::endl;
62
63  os<<"last_line_tie_points:"<<data._last_line_tie_points.c_str()<<std::endl;
64
65  return os;
66
67  }
◆ operator>>
std::istream& operator>> ( std::istream &  is,
friend
Definition at line 69 of file GeolocationGrid.cpp.
70  {
71  char buf220[221];
72  buf220[220] = '\0';
73  char buf32[33];
74  buf32[32] = '\0';
75  // char buf27[28];
76  // buf27[27] = '\0';
77  // char buf20[21];
78  // buf20[20] = '\0';
79  // char buf16[17];
80  // buf16[16]='\0';
81  // char buf15[16];
82  // buf15[15] = '\0';
83  // char buf14[15];
84  // buf14[14] = '\0';
85  // char buf13[14];
86  // buf13[13] = '\0';
87  char buf12[13];
88  buf12[12] = '\0';
89  // char buf11[12];
90  // buf11[11] = '\0';
91  // char buf10[11];
92  // buf10[10] = '\0';
93  // char buf9[10];
94  // buf9[9] = '\0';
95  // char buf8[9];
96  // buf8[8] = '\0';
97  // char buf7[8];
98  // buf7[7] = '\0';
99  // char buf6[7];
100  // buf6[6] = '\0';
101  // char buf5[6];
102  // buf5[5] = '\0';
103  // char buf4[5];
104  // buf4[4] = '\0';
105  // char buf3[4];
106  // buf3[3] = '\0';
107  // char buf2[3];
108  // buf2[2] = '\0';
109 // char buf1[1]; // not used avoid warning
110
111  is.read((char*)&(data._first_zero_doppler_time_day),4);
112  data.SwitchEndian(data._first_zero_doppler_time_day);
113
114  is.read((char*)&(data._first_zero_doppler_time_sec),4);
115  data.SwitchEndian(data._first_zero_doppler_time_sec);
116
117  is.read((char*)&(data._first_zero_doppler_time_microsec),4);
118  data.SwitchEndian(data._first_zero_doppler_time_microsec);
119
120  is.read((char*)&(data._attach_flag),1);
121
122  is.read((char*)&(data._line_num),4);
123  data.SwitchEndian(data._line_num);
124
125  is.read((char*)&(data._num_lines),4);
126  data.SwitchEndian(data._num_lines);
127
128  is.read((char*)&(data._sub_sat_track),4);
129  data.SwitchEndian(data._sub_sat_track);
130
131  for (int i = 0; i<11; i++) {
132  is.read((char*)&(data._samp_numbers[i]),4);
133  data.SwitchEndian(data._samp_numbers[i]);
134  }
135
136  for (int i = 0; i<11; i++) {
137  is.read((char*)&(data._slant_range_times[i]),4);
138  data.SwitchEndian(data._slant_range_times[i]);
139  }
140
141  for (int i = 0; i<11; i++) {
142  is.read((char*)&(data._angles[i]),4);
143  data.SwitchEndian(data._angles[i]);
144  }
145
146  for (int i = 0; i<11; i++) {
147  is.read((char*)&(data._lats[i]),4);
148  data.SwitchEndian(data._lats[i]);
149  }
150
151  for (int i = 0; i<11; i++) {
152  is.read((char*)&(data._longs[i]),4);
153  data.SwitchEndian(data._longs[i]);
154  }
155
156  is.read(buf32,22);
157
158  is.read(buf12,12);
159  data._last_zero_doppler_time = buf12;
160
161  is.read(buf220,220);
162  data._last_line_tie_points = buf220;
163
164  is.read(buf32,22);
165
166  return is;
167
168  }
Member Data Documentation
◆ _angles
float ossimplugins::GeolocationGrid::_angles[11]
◆ _attach_flag
bool ossimplugins::GeolocationGrid::_attach_flag
attach_flag
Definition at line 204 of file GeolocationGrid.h.
Referenced by get_attach_flag(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
◆ _first_zero_doppler_time_day
int ossimplugins::GeolocationGrid::_first_zero_doppler_time_day
Definition at line 186 of file GeolocationGrid.h.
Referenced by get_first_zero_doppler_time_day(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
◆ _first_zero_doppler_time_microsec
unsigned int ossimplugins::GeolocationGrid::_first_zero_doppler_time_microsec
Definition at line 200 of file GeolocationGrid.h.
Referenced by get_first_zero_doppler_time_microsec(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
◆ _first_zero_doppler_time_sec
unsigned int ossimplugins::GeolocationGrid::_first_zero_doppler_time_sec
Definition at line 196 of file GeolocationGrid.h.
Referenced by get_first_zero_doppler_time_sec(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
◆ _last_line_tie_points
std::string ossimplugins::GeolocationGrid::_last_line_tie_points
Definition at line 244 of file GeolocationGrid.h.
Referenced by get_last_line_tie_points(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
◆ _last_zero_doppler_time
std::string ossimplugins::GeolocationGrid::_last_zero_doppler_time
Definition at line 240 of file GeolocationGrid.h.
Referenced by get_last_zero_doppler_time(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
◆ _lats
int ossimplugins::GeolocationGrid::_lats[11]
◆ _line_num
unsigned int ossimplugins::GeolocationGrid::_line_num
line_num
Definition at line 208 of file GeolocationGrid.h.
Referenced by get_line_num(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
◆ _longs
int ossimplugins::GeolocationGrid::_longs[11]
◆ _num_lines
unsigned int ossimplugins::GeolocationGrid::_num_lines
num_lines
Definition at line 212 of file GeolocationGrid.h.
Referenced by get_num_lines(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
◆ _samp_numbers
unsigned int ossimplugins::GeolocationGrid::_samp_numbers[11]
◆ _slant_range_times
float ossimplugins::GeolocationGrid::_slant_range_times[11]
◆ _sub_sat_track
float ossimplugins::GeolocationGrid::_sub_sat_track
sub_sat_track
Definition at line 216 of file GeolocationGrid.h.
Referenced by get_sub_sat_track(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
