#include <ossim/projection/ossimBngProjection.h>
#include <ossim/projection/ossimTranmerc.h>
#include <ossim/base/ossimDatumFactory.h>
#include <ossim/base/ossimEllipsoidFactory.h>
#include <ossim/base/ossimKeywordNames.h>
#include <ossim/elevation/ossimElevManager.h>
#include <string.h>
#include <stdio.h>
Go to the source code of this file.
Macros | |
#define | BNG_NO_ERROR 0x0000 |
#define | BNG_LAT_ERROR 0x0001 |
#define | BNG_LON_ERROR 0x0002 |
#define | BNG_EASTING_ERROR 0x0004 |
#define | BNG_NORTHING_ERROR 0x0008 |
#define | BNG_INVALID_AREA_ERROR 0x0010 |
#define | BNG_STRING_ERROR 0x0020 |
#define | BNG_ELLIPSOID_ERROR 0x0040 |
#define | PI_OVER_2 (M_PI / 2.0e0) /* PI over 2 */ |
#define | MAX_LAT (61.5 * M_PI / 180.0) /* 61.5 degrees */ |
#define | MIN_LAT (49.5 * M_PI / 180.0) /* 49.5 degrees */ |
#define | MAX_LON (3.5 * M_PI / 180.0) /* 3.5 degrees */ |
#define | MIN_LON (-10.0 * M_PI / 180.0) /* -10 degrees */ |
#define | BNG500GRID "STNOHJ" /* 500,000 unit square identifications */ |
#define | BNG100GRID "VWXYZQRSTULMNOPFGHJKABCDE" /* 100,000 unit square identifications */ |
Functions | |
RTTI_DEF1 (ossimBngProjection, "ossimBngProjection", ossimMapProjection) | |
#define BNG100GRID "VWXYZQRSTULMNOPFGHJKABCDE" /* 100,000 unit square identifications */ |
Definition at line 35 of file ossimBngProjection.cpp.
#define BNG500GRID "STNOHJ" /* 500,000 unit square identifications */ |
Definition at line 34 of file ossimBngProjection.cpp.
#define BNG_EASTING_ERROR 0x0004 |
Definition at line 23 of file ossimBngProjection.cpp.
#define BNG_ELLIPSOID_ERROR 0x0040 |
Definition at line 27 of file ossimBngProjection.cpp.
#define BNG_INVALID_AREA_ERROR 0x0010 |
Definition at line 25 of file ossimBngProjection.cpp.
Referenced by ossimBngProjection::Check_Out_Of_Area().
#define BNG_LAT_ERROR 0x0001 |
Definition at line 21 of file ossimBngProjection.cpp.
Referenced by ossimBngProjection::Convert_Geodetic_To_BNG().
#define BNG_LON_ERROR 0x0002 |
Definition at line 22 of file ossimBngProjection.cpp.
#define BNG_NO_ERROR 0x0000 |
Definition at line 20 of file ossimBngProjection.cpp.
Referenced by ossimBngProjection::Break_BNG_String(), ossimBngProjection::Check_Out_Of_Area(), ossimBngProjection::Convert_BNG_To_Geodetic(), ossimBngProjection::Convert_BNG_To_Transverse_Mercator(), ossimBngProjection::Convert_Geodetic_To_BNG(), ossimBngProjection::Convert_Transverse_Mercator_To_BNG(), ossimBngProjection::Find_Index(), ossimBngProjection::Make_BNG_String(), and ossimBngProjection::Set_BNG_Parameters().
#define BNG_NORTHING_ERROR 0x0008 |
Definition at line 24 of file ossimBngProjection.cpp.
#define BNG_STRING_ERROR 0x0020 |
Definition at line 26 of file ossimBngProjection.cpp.
Referenced by ossimBngProjection::Break_BNG_String(), and ossimBngProjection::Find_Index().
#define MAX_LAT (61.5 * M_PI / 180.0) /* 61.5 degrees */ |
Definition at line 30 of file ossimBngProjection.cpp.
#define MAX_LON (3.5 * M_PI / 180.0) /* 3.5 degrees */ |
Definition at line 32 of file ossimBngProjection.cpp.
#define MIN_LAT (49.5 * M_PI / 180.0) /* 49.5 degrees */ |
Definition at line 31 of file ossimBngProjection.cpp.
#define MIN_LON (-10.0 * M_PI / 180.0) /* -10 degrees */ |
Definition at line 33 of file ossimBngProjection.cpp.
#define PI_OVER_2 (M_PI / 2.0e0) /* PI over 2 */ |
Definition at line 29 of file ossimBngProjection.cpp.
RTTI_DEF1 | ( | ossimBngProjection | , |
"ossimBngProjection" | , | ||
ossimMapProjection | |||
