ossimGdalType.cpp
Go to the documentation of this file.
1 //------------------------------------------------------------------------
2 // License: LGPL
3 //
4 // See LICENSE.txt file in the top level directory for more details.
5 //
6 // Author: Garrett Potts
7 //
8 // $Id: ossimGdalType.cpp 14786 2009-06-26 13:35:45Z dburken $
9 //------------------------------------------------------------------------
10
11 #include "ossimGdalType.h"
12 #include <ossim/base/ossimCommon.h>
13
14 ossimScalarType ossimGdalType::toOssim(GDALDataType gdalType)const
15 {
16  switch(gdalType)
17  {
18  case GDT_Byte:
19  {
20  return OSSIM_UCHAR;
21  }
22  case GDT_UInt16:
23  {
24  return OSSIM_USHORT16;
25  }
26  case GDT_Int16:
27  {
28  return OSSIM_SSHORT16;
29  }
30  case GDT_Int32:
31  {
32  ossim_int32 sizeType = GDALGetDataTypeSize(gdalType)/8;
33  if(sizeType == 2)
34  {
35  return OSSIM_SSHORT16;
36  }
37  break;
38  }
39  case GDT_Float32:
40  {
41  return OSSIM_FLOAT;
42  break;
43  }
44  case GDT_Float64:
45  {
46  return OSSIM_DOUBLE;
47  break;
48  }
49  default:
50  break;
51  }
52
53  return OSSIM_SCALAR_UNKNOWN;
54 }
55
56 GDALDataType ossimGdalType::toGdal(ossimScalarType ossimType)const
57 {
58  switch(ossimType)
59  {
60  case OSSIM_UCHAR:
61  {
62  return GDT_Byte;
63  }
64  case OSSIM_USHORT11:
65  case OSSIM_USHORT16:
66  {
67  return GDT_UInt16;
68  }
69  case OSSIM_SSHORT16:
70  {
71  return GDT_Int16;
72  break;
73  }
74  case OSSIM_FLOAT:
76  {
77  return GDT_Float32;
78  }
79  case OSSIM_DOUBLE:
81  {
82  return GDT_Float64;
83  }
85  {
86  break;
87  }
88  default:
89  break;
90  }
91
92  return GDT_Unknown;
93 }
ossimScalarType toOssim(GDALDataType gdalType) const
ossimScalarType
GDALDataType toGdal(ossimScalarType) const
32 bit floating point
16 bit unsigned iteger
64 bit floating point
16 bit signed integer
8 bit unsigned iteger
int ossim_int32
