8 #ifndef ossimJob_HEADER 9 #define ossimJob_HEADER 71 ossimJobCallback(std::shared_ptr<ossimJobCallback> nextCallback=0):m_nextCallback(nextCallback){}
73 virtual void ready(std::shared_ptr<ossimJob> job) {
if(m_nextCallback) m_nextCallback->ready(job); }
74 virtual void started(std::shared_ptr<ossimJob> job) {
if(m_nextCallback) m_nextCallback->started(job); }
75 virtual void finished(std::shared_ptr<ossimJob> job) {
if(m_nextCallback) m_nextCallback->finished(job);}
76 virtual void canceled(std::shared_ptr<ossimJob> job) {
if(m_nextCallback) m_nextCallback->canceled(job);}
79 {
if(m_nextCallback) m_nextCallback->nameChanged(name, job);}
82 {
if(m_nextCallback) m_nextCallback->descriptionChanged(description, job);}
85 {
if(m_nextCallback) m_nextCallback->idChanged(
id, job);}
88 {
if(m_nextCallback) m_nextCallback->percentCompleteChanged(percentValue, job);}
90 void setCallback(std::shared_ptr<ossimJobCallback> c){m_nextCallback = c;}
91 std::shared_ptr<ossimJobCallback>
callback(){
return m_nextCallback;}
152 typedef std::list<std::shared_ptr<ossimJob> >
List;
162 ossimJob_RUNNING = 2,
164 ossimJob_FINISHED = 8,
165 ossimJob_ALL = (ossimJob_READY|ossimJob_RUNNING|ossimJob_CANCEL|ossimJob_FINISHED)
168 ossimJob() : m_state(ossimJob_READY), m_priority(0.0) {}
177 virtual void start();
186 return shared_from_this();
196 return shared_from_this();
207 std::lock_guard<std::mutex> lock(m_jobMutex);
210 m_callback->percentCompleteChanged(value, getSharedFromThis());
221 std::lock_guard<std::mutex> lock(m_jobMutex);
244 std::lock_guard<std::mutex> lock(m_jobMutex);
258 m_state = ossimJob_NONE;
276 virtual void setState(
int value,
bool on=
true);
284 std::lock_guard<std::mutex> lock(m_jobMutex);
285 return (m_state & ossimJob_CANCEL);
294 setState(ossimJob_CANCEL);
302 resetState(ossimJob_READY);
310 resetState(ossimJob_RUNNING);
321 std::lock_guard<std::mutex> lock(m_jobMutex);
322 newState = ((m_state & ossimJob_CANCEL) |
323 (ossimJob_FINISHED));
326 resetState(newState);
334 std::lock_guard<std::mutex> lock(m_jobMutex);
335 return m_state & ossimJob_READY;
343 std::lock_guard<std::mutex> lock(m_jobMutex);
344 return (m_state & ossimJob_FINISHED);
352 std::lock_guard<std::mutex> lock(m_jobMutex);
353 return (m_state & ossimJob_FINISHED);
361 std::lock_guard<std::mutex> lock(m_jobMutex);
362 return (m_state & ossimJob_RUNNING);
370 std::lock_guard<std::mutex> lock(m_jobMutex);
371 m_callback = callback;
381 bool changed =
false;
382 std::shared_ptr<ossimJobCallback> callback;
384 std::lock_guard<std::mutex> lock(m_jobMutex);
385 changed = value!=m_name;
387 callback = m_callback;
389 if(changed&&callback)
391 callback->nameChanged(value, getSharedFromThis());
400 std::lock_guard<std::mutex> lock(m_jobMutex);
411 bool changed =
false;
412 std::shared_ptr<ossimJobCallback> callback;
414 std::lock_guard<std::mutex> lock(m_jobMutex);
415 changed = value!=m_id;
417 callback = m_callback;
419 if(changed&&callback)
421 callback->idChanged(value, getSharedFromThis());
430 std::lock_guard<std::mutex> lock(m_jobMutex);
439 bool changed =
false;
440 std::shared_ptr<ossimJobCallback> callback;
442 std::lock_guard<std::mutex> lock(m_jobMutex);
443 changed = value!=m_description;
444 m_description = value;
445 callback = m_callback;
447 if(changed&&callback)
449 callback->descriptionChanged(value, getSharedFromThis());
458 std::lock_guard<std::mutex> lock(m_jobMutex);
459 return m_description;
465 std::shared_ptr<ossimJobCallback>
callback() {
return m_callback;}
480 virtual void run()=0;
const ossimString & id() const
virtual void resetState(int value)
Will clear out the state and the call setState.
virtual void descriptionChanged(const ossimString &description, std::shared_ptr< ossimJob > job)
ossimString m_description
void setCallback(std::shared_ptr< ossimJobCallback > c)
virtual void cancel()
Sets the state if the object as cancelled.
State
This is a Bit vector.
virtual void ready()
Sets the state if the object as ready.
virtual void nameChanged(const ossimString &name, std::shared_ptr< ossimJob > job)
std::shared_ptr< ossimJobCallback > m_callback
void setDescription(const ossimString &value)
virtual void idChanged(const ossimString &id, std::shared_ptr< ossimJob > job)
void setCallback(std::shared_ptr< ossimJobCallback > callback)
virtual void release()
If derived interfaces implement a block this will allow one to release.
std::shared_ptr< ossimJobCallback > m_nextCallback
const ossimString & description() const
void setPriority(double value)
sets the priority of the job
virtual void finished()
Sets the state if the object as finished.
std::shared_ptr< ossimJobCallback > callback()
std::list< std::shared_ptr< ossimJob > > List
virtual void percentCompleteChanged(double percentValue, std::shared_ptr< ossimJob > job)
void setName(const ossimString &value)
Sets the name of a job.
virtual void started(std::shared_ptr< ossimJob > job)
This is the job callback interface It allows one to attach and listen for different states of the job...
std::shared_ptr< const ossimJob > getSharedFromThis() const
This is a convenience method to get the shared representation of this pointer.
void setId(const ossimString &value)
virtual void ready(std::shared_ptr< ossimJob > job)
virtual void running()
Sets the state if the object as running.
virtual void canceled(std::shared_ptr< ossimJob > job)
std::shared_ptr< ossimJob > getSharedFromThis()
const ossimString & name() const
virtual void finished(std::shared_ptr< ossimJob > job)
void setPercentComplete(double value)
When the pernet complete is set for the job it will call any callbacks and nofity percentCompleteChan...
ossimJobCallback(std::shared_ptr< ossimJobCallback > nextCallback=0)
