48 m_intensity(obj.m_intensity),
49 m_bitFlags(obj.m_bitFlags),
50 m_classification(obj.m_classification),
51 m_scanAngleRank(obj.m_scanAngleRank),
52 m_userData(obj.m_userData),
53 m_pointSourceId(obj.m_pointSourceId),
54 m_gpsTime(obj.m_gpsTime),
92 m_record(obj.m_record)
98 if (
this != ©_this)
190 std::ios_base::fmtflags f = out.flags();
192 out << std::setiosflags(std::ios_base::fixed) << std::setprecision(8);
ossim_uint8 m_scanDirection
const ossimLasPointRecord3 & operator=(const ossimLasPointRecord3 ©_this)
ossim_uint8 m_numberOfReturns
virtual ossim_uint16 getBlue() const
virtual ossim_uint8 getEdgeFlag() const
OSSIM_DLL ossimByteOrder byteOrder()
unsigned short ossim_uint16
virtual ossim_uint16 getGreen() const
virtual ossim_int32 getY() const
ossim_uint16 m_pointSourceId
ossimLasPointRecord3()
default constructor
const ossimLasPointRecord3Data & operator=(const ossimLasPointRecord3Data &obj)
ossimLasPointRecord3Data()
virtual ~ossimLasPointRecord3()
destructor
virtual ossim_uint16 getRed() const
Container class for LAS point record type 3.
std::basic_istream< char > istream
Base class for char input streams.
ossimLasPointRecord3Data m_record
ossim_uint8 m_edgeOfFlightLine
virtual ossim_int32 getX() const
virtual ossim_uint8 getReturnNumber() const
virtual ossim_uint8 getNumberOfReturns() const
virtual void readStream(std::istream &in)
Initialize record from stream.
ossim_uint8 m_classification
virtual ossim_int32 getZ() const
void swap()
Performs a swap if system byte order is not little endian.
ossim_int8 m_scanAngleRank
virtual ossim_uint16 getIntensity() const
virtual void writeStream(std::ostream &out)
Writes record to stream.
unsigned char ossim_uint8
std::basic_ostream< char > ostream
Base class for char output streams.
ossim_uint8 m_returnNumber
