ossimOgrGdalTileSource.cpp
Go to the documentation of this file.
1 //*******************************************************************
2 //
3 // License: See top level LICENSE.txt file.
4 //
5 // Author: Garrett Potts
6 //
7 // Description:
8 //
9 // Contains class implementaiton for the class "ossimOgrGdalTileSource".
10 //
11 //*******************************************************************
12 // $Id: ossimOgrGdalTileSource.cpp 20133 2011-10-12 19:03:47Z oscarkramer $
13
14 #include <ossimOgrGdalTileSource.h>
15
17  "ossimOgrGdalTileSource",
21
22 //*******************************************************************
23 // Public Constructor:
24 //*******************************************************************
26  :
30 {
31  theObject = this;
34 }
35
36 //*******************************************************************
37 // Destructor:
38 //*******************************************************************
40 {
42  close();
43
44 }
45
46 //*******************************************************************
47 // Public Method:
48 //*******************************************************************
50 {
52 }
53
54 //*******************************************************************
55 // Public method:
56 //*******************************************************************
58  const char* prefix) const
59 {
61  {
62  theAnnotationSource->saveState(kwl, prefix);
63  }
64  return ossimImageHandler::saveState(kwl, prefix);
65 }
66
67 //*******************************************************************
68 // Public method:
69 //*******************************************************************
71  const char* prefix)
72 {
73  if (ossimImageHandler::loadState(kwl, prefix))
74  {
76  if (open())
77  {
79  {
80  theAnnotationSource->loadState(kwl, prefix);
81  }
82  return true;
83  }
84  }
85
86  return false;
87 }
88
90 {
91  return 0;
92 }
93
95 {
96  return 0;
97 }
98
100 {
102
103  return theGeometry;
104 }
105
107 {
109 }
110
112  const ossimIrect& tileRect, ossim_uint32 resLevel)
113 {
114  return theAnnotationSource->getTile(tileRect, resLevel);
115 }
116
118 {
120 }
121
123 {
125 }
126
128 {
130
131  if(theBounds.hasNans())
132  {
133  return theBounds.ul().x;
134  }
135
136  return theBounds.height();
137 }
138
140 {
142
143  if(theBounds.hasNans())
144  {
145  return theBounds.ul().x;
146  }
147
148  return theBounds.height();
149 }
150
152 {
153  return 32;
154 }
155
157 {
159 }
160
162 {
164 }
165
167 {
169 }
170
172 {
174 }
175
177 {
178  return theAnnotationSource->isOpen();
179 }
180
182 {
184 }
185
187 {
189 }
190
192 {
194 }
195
197 {
198  return theAnnotationSource->getView();
199 }
200
202 {
203  return theAnnotationSource->getView();
204 }
205
207 {
208  return theAnnotationSource->setView(baseObject);
209 }
210
212 {
214  {
215  theAnnotationSource->setProperty(property);
216  }
217 }
218
220 {
222  {
223  return theAnnotationSource->getProperty(name);
224  }
225
226  return 0;
227 }
228
229 void ossimOgrGdalTileSource::getPropertyNames(std::vector<ossimString>& propertyNames)const
230 {
232  {
233  theAnnotationSource->getPropertyNames(propertyNames);
234  }
235 }
236
237 std::multimap<long, ossimAnnotationObject*> ossimOgrGdalTileSource::getFeatureTable()
238 {
240  {
242  }
243  return std::multimap<long, ossimAnnotationObject*>();
244 }
245
247 {
249  {
251  }
252 }
253
255 {
257  {
259  }
260 }
261
263 {
265  {
266  return theAnnotationSource->setCurrentEntry(entryIdx);
267  }
268  return false;
269 }
void setQuery(const ossimString &query)
ossimObject * theObject
ossimRefPtr< ossimImageGeometry > theGeometry
ossimRefPtr< ossimGdalOgrVectorAnnotation > theAnnotationSource
virtual ossimIrect getImageRectangle(ossim_uint32 reduced_res_level=0) const
ossimFilename theImageFile
virtual void close()
ossimUnitType
virtual ossimRefPtr< ossimImageGeometry > getImageGeometry() const
Returns the image geometry object associated with this tile source or NULL if non defined...
bool valid() const
Definition: ossimRefPtr.h:75
virtual std::multimap< long, ossimAnnotationObject * > getFeatureTable()
Pure virtual getFeatureTable method.
virtual ossimRefPtr< ossimImageData > getTile(const ossimIrect &tileRect, ossim_uint32 resLevel=0)
ossim_uint32 height() const
Definition: ossimIrect.h:487
virtual ossim_uint32 getTileHeight() const
Returns the default processing tile height.
const ossimIpt & ul() const
Definition: ossimIrect.h:274
virtual ossimObject * getView()
virtual void setQuery(const ossimString &query)
Pure virtual setQuery method.
RTTI_DEF3(ossimOgrGdalTileSource, "ossimOgrGdalTileSource", ossimImageHandler, ossimViewInterface, ossimEsriShapeFileInterface)
virtual ossim_uint32 getTileWidth() const
Returns the default processing tile width.
ossimPixelType thePixelType
double ossim_float64
virtual ossim_uint32 getNumberOfSamples(ossim_uint32 reduced_res_level=0) const
virtual bool setView(ossimObject *baseObject)
virtual ossim_uint32 getImageTileHeight() const
unsigned int ossim_uint32
Sets the output view.
virtual bool isOpen() const
void setGeometryBuffer(ossim_float64 distance, ossimUnitType type)
virtual ossim_uint32 getNumberOfDecimationLevels() const
ossimScalarType
virtual ossimRefPtr< ossimImageGeometry > getInternalImageGeometry() const
This class defines an abstract Handler which all image handlers(loaders) should derive from...
Retuns the min pixel value.
virtual bool setCurrentEntry(ossim_uint32 entryIdx)
virtual ossim_uint32 getNumberOfLines(ossim_uint32 reduced_res_level=0) const
virtual void setGeometryBuffer(ossim_float64 distance, ossimUnitType type)
Pure virtual setGeometryBuffer method.
virtual ossim_uint32 getNumberOfInputBands() const
bool hasNans() const
Definition: ossimIrect.h:337
ossim_int32 x
Definition: ossimIpt.h:141
float distance(double lat1, double lon1, double lat2, double lon2, int units)
virtual ossim_uint32 getImageTileWidth() const
