17 "ossimValueAssignImageSourceFilter",
22 theAssignType(ossimValueAssignType_GROUP),
119 <<
" Not supported!" << std::endl;
130 const vector<double>& outputValues)
183 T* buf =
static_cast<T*
>(data->
getBuf(band));
205 bool equalFlag =
false;
210 bufArray[band] =
static_cast<T*
>(data->
getBuf(band));
213 for(
ossim_uint32 offset = 0; offset < maxOffset; ++offset)
217 for(band = 0; band<numberOfBands; ++band)
226 for(band = 0; band<numberOfBands; ++band)
258 const char* prefix)
const 306 "output_band[0-9]+)";
315 while(index < numberOfInputs)
317 const char* value = kwl.
find(prefix,
330 while(index < numberOfOutputs)
332 const char* value = kwl.
find(prefix,
345 const char* assignType = kwl.
find(prefix,
"assign_type");
348 if(
ossimString(assignType).trim().downcase() ==
"separate")
This allows one to assign a value to a group of bands.
void executeAssignGroup(T, ossimRefPtr< ossimImageData > &data)
void executeAssignSeparate(T, ossimRefPtr< ossimImageData > &data)
RTTI_DEF1(ossimValueAssignImageSourceFilter, "ossimValueAssignImageSourceFilter", ossimImageSourceFilter)
ossimValueAssignType theAssignType
ossim_uint32 getNumberOfSubstringKeys(const ossimString ®ularExpression) const
ossimValueAssignType getValueAssignType() const
virtual bool loadState(const ossimKeywordlist &kwl, const char *prefix=NULL)
virtual bool saveState(ossimKeywordlist &kwl, const char *prefix=NULL) const
vector< double > theInputValueArray
Numeric to string methods.
virtual void initialize()
Initialize the data buffer.
virtual void loadTile(const void *src, const ossimIrect &src_rect, ossimInterleaveType il_type)
unsigned int ossim_uint32
vector< double > theOutputValueArray
void allocate()
Called on first getTile, will initialize all data needed.
ossimValueAssignImageSourceFilter(ossimObject *owner=NULL)
const vector< double > & getOutputValues() const
virtual ossimRefPtr< ossimImageData > getTile(const ossimIrect &tileRect, ossim_uint32 resLevel=0)
virtual void makeBlank()
void executeAssign(T, ossimRefPtr< ossimImageData > &data)
void setInputOutputValues(const vector< double > &inputValues, const vector< double > &outputValues)
const vector< double > & getInputValues() const
virtual ~ossimValueAssignImageSourceFilter()
const char * c_str() const
Returns a pointer to a null-terminated array of characters representing the string's contents...
void setValueAssignType(ossimValueAssignType type)
