Public Member Functions | Static Public Member Functions | Protected Member Functions | Static Protected Attributes | List of all members
ossimImageSourceFactory Class Reference
#include <ossimImageSourceFactory.h>
Inheritance diagram for ossimImageSourceFactory:
ossimImageSourceFactoryBase ossimObjectFactory ossimObject ossimReferenced
virtual ~ossimImageSourceFactory ()
virtual ossimObjectcreateObject (const ossimString &name) const
virtual ossimObjectcreateObject (const ossimKeywordlist &kwl, const char *prefix=0) const
virtual void getTypeNameList (std::vector< ossimString > &typeList) const
- Public Member Functions inherited from ossimImageSourceFactoryBase
virtual ossimImageSourcecreateImageSource (const ossimString &name) const
virtual ossimImageSourcecreateImageSource (const ossimKeywordlist &kwl, const char *prefix=0) const
- Public Member Functions inherited from ossimObjectFactory
virtual ~ossimObjectFactory ()
 ossimObject ()
virtual ~ossimObject ()
 Generic print method. More...
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
static ossimImageSourceFactoryinstance ()
 ossimImageSourceFactory (const ossimImageSourceFactory &)
const ossimImageSourceFactoryoperator= (ossimImageSourceFactory &)
- Protected Member Functions inherited from ossimImageSourceFactoryBase
 ossimImageSourceFactoryBase ()
 ossimImageSourceFactoryBase (const ossimImageSourceFactoryBase &)
const ossimImageSourceFactoryBaseoperator= (const ossimImageSourceFactoryBase &)
virtual ~ossimReferenced ()
static ossimImageSourceFactorytheInstance =NULL
Detailed Description
Definition at line 13 of file ossimImageSourceFactory.h.
◆ ~ossimImageSourceFactory()
ossimImageSourceFactory::~ossimImageSourceFactory ( )
virtual
Definition at line 111 of file ossimImageSourceFactory.cpp.
References ossimObjectFactoryRegistry::instance(), theInstance, and ossimFactoryListInterface< T, NativeType >::unregisterFactory().
112 {
113  theInstance = NULL;
115 }
static ossimObjectFactoryRegistry * instance()
void unregisterFactory(T *factory)
Will remove the factory from the registry.
static ossimImageSourceFactory * theInstance
◆ ossimImageSourceFactory() [1/2]
ossimImageSourceFactory::ossimImageSourceFactory ( )
protected
Definition at line 614 of file ossimImageSourceFactory.cpp.
Referenced by instance().
◆ ossimImageSourceFactory() [2/2]
ossimImageSourceFactory::ossimImageSourceFactory ( const ossimImageSourceFactory )
protected
Member Function Documentation
◆ createObject() [1/2]
ossimObject * ossimImageSourceFactory::createObject ( const ossimString typeName) const
virtual
Creates an object given a type name.
Implements ossimObjectFactory.
Definition at line 126 of file ossimImageSourceFactory.cpp.
References STATIC_TYPE_NAME.
127 {
128
129  // lets do the filters first
130  if( name == STATIC_TYPE_NAME(ossimBandSelector) ||
131  name == "ossimNativeBandSelectorTileSource" )
132  {
133  //---
134  // For backwards compatibility check old name:
135  // "ossimNativeBandSelectorTileSource"
136  //---
137  return new ossimBandSelector;
138  }
139  else if(name == STATIC_TYPE_NAME(ossimMultiThreadSequencer) || name == "ossimMultiThreadSequencer")
140  {
141  return new ossimMultiThreadSequencer;
142  }
143  else if(name == STATIC_TYPE_NAME(ossimNullPixelFlip))
144  {
145  return new ossimNullPixelFlip;
146  }
147  else if(name == STATIC_TYPE_NAME(ossimElevRemapper))
148  {
149  return new ossimElevRemapper;
150  }
151  else if(name == STATIC_TYPE_NAME(ossimImageRenderer))
152  {
153  return new ossimImageRenderer;
154  }
155  else if(name == STATIC_TYPE_NAME(ossimCacheTileSource))
156  {
157  return new ossimCacheTileSource;
158  }
160  {
161  return new ossimColorNormalizedFusion;
162  }
164  {
165  return new ossimLocalCorrelationFusion;
166  }
167  else if(name == STATIC_TYPE_NAME(ossimSFIMFusion))
168  {
169  return new ossimSFIMFusion;
170  }
171  else if(name == STATIC_TYPE_NAME(ossimBlendMosaic))
172  {
173  return new ossimBlendMosaic;
174  }
175  else if(name == STATIC_TYPE_NAME(ossimMaxMosaic))
176  {
177  return new ossimMaxMosaic;
178  }
179  else if(name == STATIC_TYPE_NAME(ossimHistogramRemapper))
180  {
181  return new ossimHistogramRemapper;
182  }
183  else if(name == STATIC_TYPE_NAME(ossimImageMosaic))
184  {
185  return new ossimImageMosaic;
186  }
187  else if(name == STATIC_TYPE_NAME(ossimElevationMosaic))
188  {
189  return new ossimElevationMosaic;
190  }
191  else if(name == STATIC_TYPE_NAME(ossimPiecewiseRemapper))
192  {
193  return new ossimPiecewiseRemapper;
194  }
196  {
197  return new ossimImageSourceSequencer;
198  }
200  {
201  return new ossimClosestToCenterCombiner;
202  }
203  else if(name == STATIC_TYPE_NAME(ossimRgbToGreyFilter))
204  {
205  return new ossimRgbToGreyFilter;
206  }
207  else if(name == STATIC_TYPE_NAME(ossimNBandToIndexFilter))
208  {
209  return new ossimNBandToIndexFilter;
210  }
211  else if(name == STATIC_TYPE_NAME(ossimImageChain))
212  {
213  return new ossimImageChain;
214  }
215  else if(name == STATIC_TYPE_NAME(ossimPolyCutter))
216  {
217  return new ossimPolyCutter;
218  }
219  else if(name == STATIC_TYPE_NAME(ossimGeoPolyCutter))
220  {
221  return new ossimGeoPolyCutter;
222  }
224  {
225  return new ossimJpegYCbCrToRgbSource;
226  }
228  {
229  return new ossimRgbToJpegYCbCrSource;
230  }
231  else if(name == STATIC_TYPE_NAME(ossimHsiToRgbSource))
232  {
233  return new ossimHsiToRgbSource;
234  }
235  else if(name == STATIC_TYPE_NAME(ossimRgbToHsiSource))
236  {
237  return new ossimRgbToHsiSource;
238  }
239  else if(name == STATIC_TYPE_NAME(ossimHsvToRgbSource))
240  {
241  return new ossimHsvToRgbSource;
242  }
243  else if(name == STATIC_TYPE_NAME(ossimRgbToHsvSource))
244  {
245  return new ossimRgbToHsvSource;
246  }
248  {
249  return new ossimHistogramEqualization;
250  }
252  {
253  return new ossimHistogramMatchFilter;
254  }
256  {
258  }
260  {
261  return new ossimGeoAnnotationSource;
262  }
263  else if(name == STATIC_TYPE_NAME(ossimConvolutionSource))
264  {
265  return new ossimConvolutionSource;
266  }
268  {
269  return new ossimSICDToDetectedImage;
270  }
272  {
274  }
275  else if(name == STATIC_TYPE_NAME(ossimBrightnessMatch))
276  {
277  return new ossimBrightnessMatch;
278  }
279  else if(name == STATIC_TYPE_NAME(ossimScalarRemapper))
280  {
281  return new ossimScalarRemapper;
282  }
283  else if(name == STATIC_TYPE_NAME(ossimBandMergeSource))
284  {
285  return new ossimBandMergeSource;
286  }
287  else if(name == STATIC_TYPE_NAME(ossimFeatherMosaic))
288  {
289  return new ossimFeatherMosaic;
290  }
291  else if(name == STATIC_TYPE_NAME(ossimGridRemapSource))
292  {
293  return new ossimGridRemapSource;
294  }
295  else if(name == STATIC_TYPE_NAME(ossimEquationCombiner))
296  {
297  return new ossimEquationCombiner;
298  }
300  {
301  return new ossimConvolutionFilter1D;
302  }
304  {
305  return new ossimImageGaussianFilter;
306  }
307  // Not sure if we want to keep this here
308  else if(name == STATIC_TYPE_NAME(ossimAtbController))
309  {
310  return new ossimAtbController;
311  }
313  {
314  return new ossimIndexToRgbLutFilter;
315  }
317  {
318  return new ossimBumpShadeTileSource;
319  }
320  else if(name == STATIC_TYPE_NAME(ossimSubImageTileSource))
321  {
322  return new ossimSubImageTileSource;
323  }
324  else if(name == STATIC_TYPE_NAME(ossimRLevelFilter))
325  {
326  return new ossimRLevelFilter;
327  }
328  else if(name == STATIC_TYPE_NAME(ossimBandClipFilter))
329  {
330  return new ossimBandClipFilter;
331  }
332  else if(name == STATIC_TYPE_NAME(ossimHsiRemapper))
333  {
334  return new ossimHsiRemapper;
335  }
336  else if(name == STATIC_TYPE_NAME(ossimHistogramWriter))
337  {
338  return new ossimHistogramWriter;
339  }
341  {
342  return new ossimImageHistogramSource;
343  }
344  else if(name == STATIC_TYPE_NAME(ossimRectangleCutFilter))
345  {
346  return new ossimRectangleCutFilter;
347  }
349  {
350  return new ossimCastTileSourceFilter;
351  }
352  // all the image handlers
354  {
356  }
357  else if(name == STATIC_TYPE_NAME(ossimImageSharpenFilter))
358  {
359  return new ossimImageSharpenFilter;
360  }
362  {
363  return new ossim3x3ConvolutionFilter;
364  }
365  else if(name == STATIC_TYPE_NAME(ossimOrthoImageMosaic))
366  {
367  return new ossimOrthoImageMosaic;
368  }
369  else if(name == STATIC_TYPE_NAME(ossimPiecewiseRemapper))
370  {
371  return new ossimPiecewiseRemapper;
372  }
374  {
375  return new ossimMapCompositionSource;
376  }
377  else if(name == STATIC_TYPE_NAME(ossimElevImageSource))
378  {
379  return new ossimElevImageSource;
380  }
381  else if(name == STATIC_TYPE_NAME(ossimMaskFilter))
382  {
383  return new ossimMaskFilter;
384  }
386  {
388  }
389  else if(name == STATIC_TYPE_NAME(ossimBandAverageFilter))
390  {
391  return new ossimBandAverageFilter;
392  }
393  else if(name == STATIC_TYPE_NAME(ossimPixelFlipper))
394  {
395  return new ossimPixelFlipper();
396  }
397  else if(name == STATIC_TYPE_NAME(ossimScaleFilter))
398  {
399  return new ossimScaleFilter();
400  }
402  {
403  return new ossimImageToPlaneNormalFilter();
404  }
406  {
408  }
410  {
412  }
413  else if(name == STATIC_TYPE_NAME(ossimAtCorrRemapper))
414  {
415  return new ossimAtCorrRemapper();
416  }
417  else if(name == STATIC_TYPE_NAME(ossimAtCorrGridRemapper))
418  {
419  return new ossimAtCorrGridRemapper();
420  }
422  {
423  return new ossimEastingNorthingCutter();
424  }
425  else if(name == STATIC_TYPE_NAME(ossimEdgeFilter))
426  {
427  return new ossimEdgeFilter();
428  }
429  else if(name == STATIC_TYPE_NAME(ossimFftFilter))
430  {
431  return new ossimFftFilter();
432  }
433  else if(name == STATIC_TYPE_NAME(ossimWatermarkFilter))
434  {
435  return new ossimWatermarkFilter();
436  }
438  {
439  return new ossimImageGaussianFilter();
440  }
441  else if(name == STATIC_TYPE_NAME(ossimTrimFilter))
442  {
443  return new ossimTrimFilter();
444  }
445  else if(name == STATIC_TYPE_NAME(ossimTwoColorView))
446  {
447  return new ossimTwoColorView;
448  }
450  {
451  return new ossimImageHistogramSource();
452  }
453  else if(name == STATIC_TYPE_NAME(ossimImageSourceFilter))
454  {
455  // this is just a pass through source
456  return new ossimImageSourceFilter;
457  }
458  else if(name == STATIC_TYPE_NAME(ossimMemoryImageSource))
459  {
460  // this is just a pass through source
461  return new ossimMemoryImageSource;
462  }
463  else if(name == STATIC_TYPE_NAME(ossimDilationFilter))
464  {
465  return new ossimDilationFilter();
466  }
467  else if(name == STATIC_TYPE_NAME(ossimErosionFilter))
468  {
469  return new ossimErosionFilter();
470  }
471  return NULL;
472 }
This allows one to assign a value to a group of bands.
This uses a derivative of Blinn&#39;s bump function to compute a 3-D looking image.
This is a 2 color view of the input.
class ossimEdgeFilter
This filter outputs a single band that is the weighted average of all the input bands retrieved from ...
This implements a closest to center combiner.
Will combine the input data based on a supplied equation.
Performs a spatial blend accross overlapping regions.
This class imlements the fusion algorithm from the paper:
An image mosaic is a simple combiner that will just do a simple mosaic.
#define STATIC_TYPE_NAME(T)
Definition: ossimRtti.h:325
class for symmetric Gaussian filtering implemented as two separable horizontal/vertical gaussian filt...
Cache Tile Source.
class for vertical or horizontal convolution
class ossimHistogramMatchFilter
This implements a Local correlation fusion based on the paper:
class ossimWatermarkFilter Applies an image or watermark to image.
This class manages the sequencing of tile requests across multiple threads.
Class to scan pixels and flip target dn value to a replacement dn value.
This class provides piecewise linear remapping of input pixels to output pixels.
◆ createObject() [2/2]
ossimObject * ossimImageSourceFactory::createObject ( const ossimKeywordlist kwl,
const char *  prefix = 0
) const
virtual
Creates and object given a keyword list.
Definition at line 474 of file ossimImageSourceFactory.cpp.
476 {
477  static const char* MODULE = "ossimImageSourceFactory::createSource";
478
479  ossimString copyPrefix;
480  if (prefix)
481  {
482  copyPrefix = prefix;
483  }
484
485  ossimObject* result = NULL;
486
487  if(traceDebug())
488  {
489  CLOG << "looking up type keyword for prefix = " << copyPrefix << endl;
490  }
491
492  const char* lookup = kwl.find(copyPrefix, "type");
493  if(lookup)
494  {
495  ossimString name = lookup;
496  result = createObject(name);
497
498  if(result)
499  {
500  if(traceDebug())
501  {
502  CLOG << "found source " << result->getClassName() << " now loading state" << endl;
503  }
504  result->loadState(kwl, copyPrefix.c_str());
505  }
506  else
507  {
508  if(traceDebug())
509  {
510  CLOG << "type not found " << lookup << endl;
511  }
512  }
513  }
514  else
515  {
516  if(traceDebug())
517  {
518  CLOG << "type keyword not found" << endl;
519  }
520  }
521  return result;
522 }
#define CLOG
Definition: ossimTrace.h:23
virtual ossimString getClassName() const
Definition: ossimObject.cpp:64
const char * c_str() const
Definition: ossimString.h:396
virtual ossimObject * createObject(const ossimString &name) const
◆ getTypeNameList()
void ossimImageSourceFactory::getTypeNameList ( std::vector< ossimString > &  typeList) const
virtual
This should return the type name of all objects in all factories. This is the name used to construct the objects dynamially and this name must be unique.
Definition at line 524 of file ossimImageSourceFactory.cpp.
525 {
526  typeList.push_back(STATIC_TYPE_NAME(ossimBandSelector));
527  typeList.push_back(STATIC_TYPE_NAME(ossimMultiThreadSequencer));
528  typeList.push_back(STATIC_TYPE_NAME(ossimImageRenderer));
529  typeList.push_back(STATIC_TYPE_NAME(ossimCacheTileSource));
530  typeList.push_back(STATIC_TYPE_NAME(ossimBlendMosaic));
531  typeList.push_back(STATIC_TYPE_NAME(ossimMaxMosaic));
532  typeList.push_back(STATIC_TYPE_NAME(ossimNullPixelFlip));
533  typeList.push_back(STATIC_TYPE_NAME(ossimElevRemapper));
534  typeList.push_back(STATIC_TYPE_NAME(ossimColorNormalizedFusion));
535  typeList.push_back(STATIC_TYPE_NAME(ossimLocalCorrelationFusion));
536  typeList.push_back(STATIC_TYPE_NAME(ossimSFIMFusion));
537  typeList.push_back(STATIC_TYPE_NAME(ossimHistogramRemapper));
538  typeList.push_back(STATIC_TYPE_NAME(ossimImageMosaic));
539  typeList.push_back(STATIC_TYPE_NAME(ossimElevationMosaic));
540  typeList.push_back(STATIC_TYPE_NAME(ossimClosestToCenterCombiner));
541  typeList.push_back(STATIC_TYPE_NAME(ossimRgbToGreyFilter));
542  typeList.push_back(STATIC_TYPE_NAME(ossimNBandToIndexFilter));
543  typeList.push_back(STATIC_TYPE_NAME(ossimImageChain));
544  typeList.push_back(STATIC_TYPE_NAME(ossimPolyCutter));
545  typeList.push_back(STATIC_TYPE_NAME(ossimGeoPolyCutter));
546  typeList.push_back(STATIC_TYPE_NAME(ossimJpegYCbCrToRgbSource));
547  typeList.push_back(STATIC_TYPE_NAME(ossimRgbToJpegYCbCrSource));
548  typeList.push_back(STATIC_TYPE_NAME(ossimHsiToRgbSource));
549  typeList.push_back(STATIC_TYPE_NAME(ossimRgbToHsiSource));
550  typeList.push_back(STATIC_TYPE_NAME(ossimHsvToRgbSource));
551  typeList.push_back(STATIC_TYPE_NAME(ossimRgbToHsvSource));
552  typeList.push_back(STATIC_TYPE_NAME(ossimHistogramEqualization));
553  typeList.push_back(STATIC_TYPE_NAME(ossimHistogramMatchFilter));
555  typeList.push_back(STATIC_TYPE_NAME(ossimGeoAnnotationSource));
556  typeList.push_back(STATIC_TYPE_NAME(ossimConvolutionSource));
557  typeList.push_back(STATIC_TYPE_NAME(ossimSICDToDetectedImage));
558  typeList.push_back(STATIC_TYPE_NAME(ossimBrightnessContrastSource));
559  typeList.push_back(STATIC_TYPE_NAME(ossimBrightnessMatch));
560  typeList.push_back(STATIC_TYPE_NAME(ossimScalarRemapper));
561  typeList.push_back(STATIC_TYPE_NAME(ossimBandMergeSource));
562  typeList.push_back(STATIC_TYPE_NAME(ossimFeatherMosaic));
563  typeList.push_back(STATIC_TYPE_NAME(ossimGridRemapSource));
564  // Not sure if we want to keep this here
565  typeList.push_back(STATIC_TYPE_NAME(ossimAtbController));
566  typeList.push_back(STATIC_TYPE_NAME(ossimIndexToRgbLutFilter));
567  typeList.push_back(STATIC_TYPE_NAME(ossimBumpShadeTileSource));
568  typeList.push_back(STATIC_TYPE_NAME(ossimSubImageTileSource));
569  typeList.push_back(STATIC_TYPE_NAME(ossimRLevelFilter));
570  typeList.push_back(STATIC_TYPE_NAME(ossimBandClipFilter));
571  typeList.push_back(STATIC_TYPE_NAME(ossimHsiRemapper));
572  typeList.push_back(STATIC_TYPE_NAME(ossimHistogramWriter));
573  typeList.push_back(STATIC_TYPE_NAME(ossimImageHistogramSource));
574  typeList.push_back(STATIC_TYPE_NAME(ossimRectangleCutFilter));
575  typeList.push_back(STATIC_TYPE_NAME(ossimElevImageSource));
576
578  typeList.push_back(STATIC_TYPE_NAME(ossimImageSharpenFilter));
579  typeList.push_back(STATIC_TYPE_NAME(ossim3x3ConvolutionFilter));
580  typeList.push_back(STATIC_TYPE_NAME(ossimOrthoImageMosaic));
581  typeList.push_back(STATIC_TYPE_NAME(ossimPiecewiseRemapper));
582  typeList.push_back(STATIC_TYPE_NAME(ossimMapCompositionSource));
583  typeList.push_back(STATIC_TYPE_NAME(ossimCastTileSourceFilter));
584  typeList.push_back(STATIC_TYPE_NAME(ossimEquationCombiner));
585  typeList.push_back(STATIC_TYPE_NAME(ossimConvolutionFilter1D));
586  typeList.push_back(STATIC_TYPE_NAME(ossimImageGaussianFilter));
587  typeList.push_back(STATIC_TYPE_NAME(ossimMaskFilter));
589  typeList.push_back(STATIC_TYPE_NAME(ossimBandAverageFilter));
590  typeList.push_back(STATIC_TYPE_NAME(ossimPixelFlipper));
591  typeList.push_back(STATIC_TYPE_NAME(ossimScaleFilter));
592  typeList.push_back(STATIC_TYPE_NAME(ossimImageToPlaneNormalFilter));
595  typeList.push_back(STATIC_TYPE_NAME(ossimAtCorrRemapper));
596  typeList.push_back(STATIC_TYPE_NAME(ossimAtCorrGridRemapper));
597  typeList.push_back(STATIC_TYPE_NAME(ossimEastingNorthingCutter));
598  typeList.push_back(STATIC_TYPE_NAME(ossimEdgeFilter));
599  typeList.push_back(STATIC_TYPE_NAME(ossimFftFilter));
600  typeList.push_back(STATIC_TYPE_NAME(ossimWatermarkFilter));
601  typeList.push_back(STATIC_TYPE_NAME(ossimImageGaussianFilter));
602  typeList.push_back(STATIC_TYPE_NAME(ossimTrimFilter));
603  typeList.push_back(STATIC_TYPE_NAME(ossimTwoColorView));
604  typeList.push_back(STATIC_TYPE_NAME(ossimImageHistogramSource));
605  typeList.push_back(STATIC_TYPE_NAME(ossimImageSourceFilter));
606  typeList.push_back(STATIC_TYPE_NAME(ossimMemoryImageSource));
607  typeList.push_back(STATIC_TYPE_NAME(ossimPiecewiseRemapper));
608  typeList.push_back(STATIC_TYPE_NAME(ossimImageSourceSequencer));
609  typeList.push_back(STATIC_TYPE_NAME(ossimDilationFilter));
610  typeList.push_back(STATIC_TYPE_NAME(ossimErosionFilter));
611 }
Cache Tile Source.
◆ instance()
ossimImageSourceFactory * ossimImageSourceFactory::instance ( )
static
◆ operator=()
const ossimImageSourceFactory & ossimImageSourceFactory::operator= ( ossimImageSourceFactory )
protected
Definition at line 622 of file ossimImageSourceFactory.cpp.
623 {
624  return *this;
625 }
Member Data Documentation
◆ theInstance
ossimImageSourceFactory * ossimImageSourceFactory::theInstance =NULL
staticprotected
Definition at line 29 of file ossimImageSourceFactory.h.
Referenced by instance(), and ~ossimImageSourceFactory().
